need help with my Toshiba l755 backlight
  • new
    • Oct 2014
    • 157
    • canada
    i have a problem with my Toshiba satellite l755 . there's a very dark faint light that i can hardly see the image . when i plugged it to external monitor it is working fine . replaced the lcd cable and replaced the screen itself . still the same problem .. can someone please tell me where could be the problem . i have tested the power and the PF2 fuse they are ok . where is other fuses i can check . i appreciate the help .
    p:s it was working fine till it bricked due too bad flash rom then i gave it to someone to reflash the bios . he brought it back working with no backlight .
    can reflashing the bios cause this issue ?does the bios has anything to do with the led backlight being so dark .
    thanks
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3616
    • slovakia
    Re: need help with my Toshiba l755 backlight
    maybe. u better try flashing it again
    • Agent24
      I see dead caps
      • Oct 2007
      • 5021
      • New Zealand
      Never heard of bad BIOS stopping backlights but I suppose it's possible depending on how it all works.
      Unless he screwed something when he had the thing apart.
      -David VanHorn
      • siddiq
        • Dec 2011
        • 121
        • Ghana
        You need to specify your motherboard model number so I can look at a schematic and help you out.
        • new
          • Oct 2014
          • 157
          • canada
          i have read online that EC bios control part of the backlight so not sure if is it possible flashing the wrong EC bios can cause the backlight to back out .as i said there is display only you will notice it if you look very closer with a light on .you will notice a very faint image .but still work just fine on external monitor
          • new
            • Oct 2014
            • 157
            • canada
            just my question here , does the EC has anything to do with the backlight ??? i read some post from someone here . he had the same issue as me and a guy told him you either have a faulty dim switch or dead EC ???? so i believe if the EC totally dead the laptop won't boot at all . right ?
            • khaahk
              • Dec 2013
              • 806
              • Estonia
              EC usually has output that drives the backlight enable circuit. Sometimes just this output of ec is dead, then the laptop will work fine otherwise.
              If the schematics is correct, then DISPON signal is not driven by EC in your case
              • Agent24
                I see dead caps
                • Oct 2007
                • 5021
                • New Zealand
                I forgot about the EC. That makes sense, it could affect it
                -David VanHorn
                • new
                  • Oct 2014
                  • 157
                  • canada
                  so reprogramming the EC can fix that issue ? or the chip needs to be replaced ?
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5021
                    • New Zealand
                    It would need to be reprogrammed, just like main BIOS. Since you had a bad flash that is possibly the problem.
                    -David VanHorn
                    • new
                      • Oct 2014
                      • 157
                      • canada
                      this board is intel not AMD .. the guy who programmed the bios told me he programmed U29 the main bios and he programmed U10 the EC bios ..... just wonder maybe he programmed the wrong chip
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5021
                        • New Zealand
                        I don't think there are any other chips to program.
                        -David VanHorn
                        • new
                          • Oct 2014
                          • 157
                          • canada
                          so the EC and the main bios is only one chip or 2 separate chips ?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5021
                            • New Zealand
                            Physically separate. That's why you have two different reference designators, U29 and U10. You should be able to find them on the schematic.
                            -David VanHorn
                            • new
                              • Oct 2014
                              • 157
                              • canada
                              so u10 and u29 is the right chips ... there are lots of chips on this board looks like the bios ...
                              • new
                                • Oct 2014
                                • 157
                                • canada
                                can someone provide me with the right U10 and U29 rom files i can pass them to him to reprogram he might got the wrong files . i appreciate all the help
                                • new
                                  • Oct 2014
                                  • 157
                                  • canada
                                  the motherboard is intel not AMD
                                  • new
                                    • Oct 2014
                                    • 157
                                    • canada
                                    also when the backlight very dim (very dark)you can't see it till you put a flash light on the screen . is that a sign of bad EC ????
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5021
                                      • New Zealand
                                      Just means the backlight is not on. Doesn't tell anything of why. There are many things that could cause the backlight to fail.
                                      EC was suggested as he reprogrammed it, if it does indeed control the backlight it may be wrongly controlling it if it has wrong or corrupt firmware. But I can't say for sure it is the problem.
                                      -David VanHorn
                                      • new
                                        • Oct 2014
                                        • 157
                                        • canada
                                        can someone please provide me with the right EC firmware to try with . i'll give it to him to reprogram the EC again . hopefully this will fix the issue
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • YvD-Electronics
                                          Request BIOS files to flash Toshiba C55-A-1TX laptop
                                          by YvD-Electronics
                                          I need the BIOS (bin files) to re-flash the BIOS chips on a toshiba laptop.
                                          Why I am pretty sure I need this to repair?
                                          1) Power supplies seem OK.
                                          2) Battery has been replaced, is charging well ... also not the CMOS battery CR2032, also not OK without RAM, or 1 or the 2 RAM modules (RAMS are OK).
                                          3) Laptop does really rare (seems random things) with the 3 leds (power, net, ...)
                                          4) In the past, when trying to restart 100 times via power button, it was sometimes succeeding, now no more.
                                          08-09-2024, 10:05 PM
