Dell N5110 Not Power ON
  • shijeesh
    • Mar 2011
    • 65
    Dell N5110 not Power ON and charing not working.
  • khaahk
    • Dec 2013
    • 812
    • Estonia
    Re: Dell N5110 Not Power ON
    Sad to hear that, mate. Take it to repair shop.
    • shijeesh
      • Mar 2011
      • 65
      When I press the power button power LED glowing at the same time OFF. The standby voltage ic TPS51123RGER-GP hot and 3D3V_AUX_S5, 5V_AUX_S5 voltages are normal but no 5V_S5 and 3D3V_S5.
      • sparker1
        • Sep 2011
        • 343
        If getting hot it may be shorted. What about removing it and checking pads for shorts. If no shorts replace TPS51123. The schematic is available here https://www.badcaps.net/forum/showthread.php?t=28239. Page 41 has the voltages for the various pins with 5V.
        • sparker1
          • Sep 2011
          • 343
          Now I have the same problem with a Toshiba A500 and TPS51117 getting hot and not having correct voltages.
          • khaahk
            • Dec 2013
            • 812
            • Estonia
            If TPS is hot without pressing power button, then check VREG3 and VREG5 for shorts. VREG3 is more likely (EC, BIOS or LAN). If you have lab PSU, then use it.
            • mohsin00
              • Oct 2014
              • 8
              • pakistan
              My n5110 got shorted when I was trying to fix my touchpad while the laptop was on. I accidentally dropped a small screw on the board and it died right away. After inspection i found out that there is no 3.3v_s5 or 5v_s5 but i did have Vreg3 and Vreg5 voltage. I also noticed the whole 3.3v_s5 rail is shorted. I lifted up the mosfets of TPS51123 and TPS51123 itself but still couldn't find the short. Can anyone help me with this stupid short which I can't find?
              • reaper57
                • Sep 2014
                • 216
                • Norway
                I think that you might be looking at an ICs short and not at a short in a MOSFET.
                I recommend tracing the points that you shorted to the components they are attached to. And testing those if possible.
                Can you also post pictures of the shorted area?
                P.S. Have you tested the power supply? And what happens to it's output voltage when plugged into the laptop?
                Keyboard not detected, press F1 to continue...
                • shijeesh
                  • Mar 2011
                  • 65
                  3V_5V_EN this voltage is not stable sometime 0.9v or 1.09v .Normal voltage 3V_5V_EN ? What is the actual voltage of 3V_5V_EN.
                  • khaahk
                    • Dec 2013
                    • 812
                    • Estonia
                    This is a control signal to turn on SMPS, without it only the LDO outputs will have voltage. It should be at least 3.3V to turn the SMPS on, the logical low level can be anything reasonable below it. Look for short at VREG3 and VREG5. Have you measured resistance at these points?
                    • mohsin00
                      • Oct 2014
                      • 8
                      • pakistan
                      I did check other IC's as well but still no luck.
                      IC's that I checked by lifting them to find a shot are
                      TPS51311 = 1.8V_S0 (takes 3.3v_S5 as input)
                      TPS51116 =1.5v
                      ISL95831= VCC core
                      Bios
                      3.3v mosfet
                      5v mosfet
                      TPS51123 = only vreg3 and vreg5 voltages. I disconnected the 5v rail and 3.3v rail by lifting up the inductors. No short before the inductor though, I think the IC is gone( it gets hot when i plug the supply).
                      The capacitor on PCH(HM67) is also showing a short
                      I feel that HM67 is causing the short and considering removal of PCH (quite expensive here)
                      Any suggestion?
                      • shijeesh
                        • Mar 2011
                        • 65
                        There is no short at VREG3 and VREG5. Yesterday I got display but few seconds same problem, again I check this 5V_S5 and 3D3V_S5 is 0.5v only.
                        • shijeesh
                          • Mar 2011
                          • 65
                          Help me sir
                          • alihomee
                            • Dec 2012
                            • 1594
                            • malaysia
                            just change two caps around 3v 5v ic if u can upload pics of that area i can point out that filters
                            • shijeesh
                              • Mar 2011
                              • 65
                              This is the VREG3 and VREG5 image.
                              • alihomee
                                • Dec 2012
                                • 1594
                                • malaysia
                                ehat is the ic num
                                • shijeesh
                                  • Mar 2011
                                  • 65
                                  5v/3d3v(tps51123rger)
                                  • shijeesh
                                    • Mar 2011
                                    • 65
                                    Sir please help me.
                                    • hazardus
                                      • Apr 2014
                                      • 105
                                      How do you know there is no short on VREG3 and VREG5?
                                      • bluestone
                                        • Jun 2011
                                        • 343
                                        • Ghana
                                        have this same problem with dell Inspiron N5010 and N5030, tps chip get hot when charger is plugged in
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
                                          05-29-2024, 02:01 PM
                                        • Mark01
                                          Dell Optiplex 7490 AIO - red power led after flash
                                          by Mark01
                                          Hi guys,
                                          This is my first post! ๐Ÿš€
                                          I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
                                          Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                          07-04-2025, 12:54 PM
                                        • zlr8r
                                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                          by zlr8r
                                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                          Ill try and give as much info as I can.
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                          Then it started getting weirder!
                                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                          12-12-2023, 09:31 PM
                                        • LimesKey
                                          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                                          by LimesKey
                                          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                                          10-17-2025, 05:33 PM
