Identifying a Power Switch and Function
  • mikay786
    • Aug 2014
    • 765
    Hi Guys, I'm looking to get a Lenovo IdeaCentre A310 back up and running which has got problems with the power switch. It's a 6 pin switch which I am unfamiliar with. Only ever seen 2 pin ones and 4 pins ones before.
    So I assume with this switch two pins will be for LED, Power Switch, Reset switch?
    What I plan to do is short two of the pins with a bit of cable to see if I can get the board to jump start.
    I am assuming the 2 central pins running through the yellow bit are for the LED?
    Which ones will be for the power switch and does anyone know where to find a replacement?
  • selldoor
    Slow Learner
    • 7870
    Re: Identifying a Power Switch and Function
    I suppose you could test how the switch operates by putting your meter in ohms across the joints ( without the power on) If the switch works.
    • mikay786
      • Aug 2014
      • 765
      Switch is dead, the clicky bit has disintegrated.
      I was hoping I could just replace with a simpler on / off switch, perhaps with reset. LED/Reset are not exactly crucial.
      • selldoor
        Slow Learner
        • 7870
        I cant tell - is it a slide switch or a press down switch - wouldnt have thought you could
        have two operations on a press switch is it not just an off/on with a led?
        • mikay786
          • Aug 2014
          • 765
          Press down
          Perhaps it is just on/off and led, I was just guessing there was perhaps a reset function due to number of pins.
          • mikay786
            • Aug 2014
            • 765
            SW1 and Triangle pins / positive?
            or
            triangle pin and opposite (L3) pin / positive?
              • 30955
              jump across the top pair of pins.
              it's just a 4pin push switch with an led inlaid over the button.
                It looks like momentary switch with LED. The typical set up is the top right pin with an arrow is internally connected to the bottom right pin, the top left is also internally connected to the bottom left pin. When the button is push, the electrical contact will be made between the top/bottom left side terminals to the right top/bottom right side terminals.
                • mikay786
                  • Aug 2014
                  • 765
                  Cheers so to jump I need to make contact with SW1 pin and the Triangle pin
                  Do you know of any momentary switch with a LED I could use?
                  If not a normal 4 pin momentary switch will suffice.
                    • 30955
                    http://www.rapidonline.com/electroni...with-led-71701
                    looks pretty close.
                    • mikay786
                      • Aug 2014
                      • 765
                      Wow thanks, spent a good few hours yesterday trying to find something similar to no avail.
                      Only difference being the one on the board is a SMD
                      Wish I had discovered this forum earlier!
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        http://www.aliexpress.com/item/Up-to...937973285.html
                        • mikay786
                          • Aug 2014
                          • 765
                          And it lives!!
                          Thanks guys, as above were the correct pins to jump, thanks. Have been waiting on the PSU which was delivered today, so tried the jump and booted up fine.
                          Going to go with the non SMD variant as can pick up from local farnels for £0.50p and just cut and bend the pins back. Will that be ok?
                          Cuople of other things I need to work on as well which I will report on once I have placed the new switch (cracked PCB for Bluetooth button only, just a single trace)
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            remove the switch frmo another scrap board , they have a lot to use , and they saved me a lot
                            • selldoor
                              Slow Learner
                              • 7870
                              I would have thought so if you can get them to the same position as the pads
                              Was/is the old one glued to te board for stability
                              • mikay786
                                • Aug 2014
                                • 765
                                No had like plastic locating pin underneath
                                I think I found something similar that is surface mounted from farnells. What you think, will it do
                                http://uk.farnell.com/e-switch/tl324...vdc/dp/2115628
                                compared to the through hole
                                http://uk.farnell.com/multicomp/tll-...led/dp/9472010 -
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  Personally I would try the 50p one (tight - born in Yorkshire!!) have you looked at the data sheets for the placing of the pins.on both and does the height matter. Also is it just a low voltage switch - not mains.
                                    • 30955
                                    bend the pins,
                                    the smd one will hit you for £15 delivery from the u.s.!!!
                                    • mikay786
                                      • Aug 2014
                                      • 765
                                      Yorkshireman here too so went el cheapo for the 50p ones Bought a few just in case I screwed up which was a likelihood
                                      Originally posted by stj
                                      bend the pins,
                                      Indeed, when she told me they had to me shipped over from US, no thanks love!!
                                      Updates to follow
                                      • mikay786
                                        • Aug 2014
                                        • 765
                                        Feeeew I nearly went and ****** it up!
                                        I should have pointed out this was my first time working on a board and properly with a soldering iron, have done a little soldering before just joining wires etc. Have got a desoldering gun which is brilliant for through hole stuff but this was a surface mounted switch.
                                        So what did the noob do
                                        Along with melting some plastic bits he pulled a pad up!!!
                                        But thank god it seems it wasn't crucial to the switch working, and here my finished job
                                        Yay, well the LED doesn't work, perhaps its linked to the pad I ripped up but the switch, on/off does work perfectly YAAAY
                                        Might pop some glue around the switch to make sure it is sturdy?
                                        I could of gotten my brother in law to do it but where's the fun in that feels so good knowing you have brought back something to life
                                        • Powderfanupnorf
                                          Dell AL440LX power on switch circuit help required
                                          by Powderfanupnorf
                                          Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                                          So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                                          My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                                          06-24-2024, 01:24 PM
                                        • krob80
                                          PS5 Edm-010 No Power - Help identifying missing capacitor
                                          by krob80
                                          Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
                                          It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
                                          When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
                                          I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
                                          05-15-2025, 04:24 PM
                                          09-06-2024, 05:59 AM
                                        • CdDvdFlash
                                          LTL Acorn 5210A Trail Camera Power Switch
                                          by CdDvdFlash
                                          I have an LTL Acorn 5210A trail camera and the power switch needs replacing, there is only one site I found that sell them but they want 12 pounds each I'm in Australia so thats $24 but I see these switches are in all sorts of devices everywhere so I'm hoping to find a cheaper one, I dont know what the pinout is for these switches but I have taken apart the camera down to just the board and removed the switch and hooked up a battery pack (4x AA batteries) to see what the voltages are at the traces where the switch was. In the picture of just the switch it is currently in the off position, it moves...
                                          08-06-2023, 09:12 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
