PS5 Edm-010 No Power - Help identifying missing capacitor
  • krob80
    • May 2025
    Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
    It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
    When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
    I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached). I am a relative novist when it comes to these things so I'm hoping someone can confirm if these pissing caps can cause this no power issue, and if so, would anyone know a part number so I can order replacements?
    Thanks for your help!
    ​​​Click image for larger version
  • LaPCon_IT
    • Sep 2022
    • 81
    • Malta
    1uF 10V
    • krob80
      • May 2025
      Thank you! Any idea what size it would be? It looks like it could be a 0402 but it's hard to say. Also, in your opinion, would this cause a no power issue? Thanks again!
      • LaPCon_IT
        • Sep 2022
        • 81
        • Malta
        Yes, 0402. 10mA could point to SB area (check there for shorts) But first replace the caps, fuse and check power draw again.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • reessi
          HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
          by reessi
          I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
          It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
          What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
          I have checked these lines in diode mode and they seam normal -> 600.
          I have checked to see if they come on for even a fraction of a second...
          07-15-2025, 09:14 AM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
          03-31-2024, 02:12 PM
