Dell AL440LX power on switch circuit help required
  • Powderfanupnorf
    • Mar 2024
    • 16
    Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
    So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
    My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to another location on the board (if there is one) and also happy to run patch wires in place of damaged tracks. From what I have managed to zoom into there is what looks to be a capacitor missing which connects to one of the pins. So then what is it I need?
    Well if someone has one of these boards and can take some high res photos of the area around the power on header pins on both sides of the board that would be awesome. Further if anyone can identify a suitable smd capacitor I could/should use in place of the missing component that would also be great. Finally can someone explain the circuit from the atx power socket to these header pins,and via the switch to ground? This is so I can check where I have broken tracks and where I need to install patch wires etc.
    My understanding is the standby voltage comes in then goes to one of the power on pins (among other places), the switch then momenterally grounds this to turn on the psu and start up the motherboard proper.
    Really any accurate information would be greatfully received. Really dont want to be buying a second motherboard if I can help it but that may be my only way to get the information I need to fix this one.
    Ok now for the photo dump.
    Thanks in advance
    Michael
    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-06-2024, 05:30 AM
  • fab13
    Nintendo Switch lite charging chip heats up and does not short circuit
    by fab13
    Hello everyone
    Small technical problem on a Nintendo Switch lite
    Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
    After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
    When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
    Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
    09-16-2023, 04:59 AM
  • Natob82
    Micro Momentary Push Switch?
    by Natob82
    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
    12-21-2022, 05:22 AM
  • SluggerB
    Help making a switch work the opposite way with a relay
    by SluggerB
    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
    02-07-2025, 07:57 PM
  • alltvrepairs
    UE55NU7170 Power Supply Circuit required BN4400932B
    by alltvrepairs
    Anyone has a circuit diagram for this Samsung Power supply pls?
    QP801CS shorted. Blu Cap is not cracked.
    05-06-2024, 03:58 AM
