Siemens PA3515
  • senchire
    • Dec 2012
    • 190
    • Bosnia
    Siemens PA3515
    Hello guys, I went to reball this one (yes it has been reworked by someone who was not careful with removing of the black epoxy).
    So here is the picture is this a dummy pad or not?
  • dj_ricoh
    • 2073
    Re: Siemens PA3515
    its that solder? or the pad its fubar?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3588
      • slovakia
      Re: Siemens PA3515
      i think that pin was repaired. not many guys doing that
      • senchire
        • Dec 2012
        • 190
        • Bosnia
        Re: Siemens PA3515
        The pad is destroyed not fixed. Since he destroyed the mask whole dummy pad (yea its dummy) is lifted and it looks like its fixed .
        Today everyone tries to do reworks ^^.
        • javieromex
          Black Epoxy on bios chip
          by javieromex
          Hi friends, I have a Lenovo E14 Gen 2 Type 20TA laptop with serial number MJ-0GWZSZ TYPE 20TA-002CUS. Intel Core ™ i5-1135G7. It has Winbond 25R256JVEQ BIOS which has black epoxy resin. I have 2 questions. What method do you use to remove the epoxy? and the second, what chip do you use to program it if you have the TL866 II Plus programmer? Thanks in advance.
          11-28-2024, 06:20 PM
        • Thermaltake
          Fujitsu Siemens Amilo Xa 3530
          by Thermaltake
          Hi, I got this Fujitsu Siemens Amilo Xa 3530 Model: MS2244. from a friend and it is powering On, but only functional keys lights up, fan spins and nothing else, screen is black no backlight, and it's staying like that forever. I tried other memory that I know is working, I tried to empty capacitors by holding power button without battery but still nothing. I didn't try new cmos battery, need to disassemble it first to try that. But I don't think even if cmos battery is dead it would give some backlight and picture...I kind of think it's chipset or gpu dead.
          I read something on google that...
          02-01-2024, 12:34 PM
        • mengpo
          Siemens RVS21.831, Looking for References, Models, and Values of These Components
          by mengpo
          Following a short circuit on the controller board of my heat pump, I'm looking to replace the components shown in the photos. All I know is that they are diodes (but I'm not sure what type), and I haven't been able to find their equivalents.
          The one on the left says: 15A 5BA
          The one on the right says: DTZ S47 or DTZ 547
          Does anyone know how to identify them?
          Thank you very much for your help!
          FYI, the card is a siemens RVS21.831
          02-15-2025, 10:50 AM
        • johancraftech
          Help needed with Siemens S11868502 D SIM24 ECU component value/s
          by johancraftech
          Foremost, I am not an ecu specialist. This ECU: Siemens S11868502 D SIM24 (Ford KA 1.3 Petrol) ended on my bench. It was previously worked on by an unknown technician. The only information I have at hand, is that the owner replaced the ignition coil as the latter caused one of the IGBT's in the ECU to short. The IGBT I can source and replace, but it seems that the previous technician removed 2 components (most probably resistors in a mini-melf package): see attached photo. It seems that schematics and/or board view files does not exist. If there are any ECU specialists that can assist in identifying...
          02-05-2025, 06:28 AM
          Fujitsu-Siemens Amilo Sa3650 Laptop Schematic
          Wistrton S13...
          11-05-2024, 02:37 PM
