Hi friends, I have a Lenovo E14 Gen 2 Type 20TA laptop with serial number MJ-0GWZSZ TYPE 20TA-002CUS. Intel Core ™ i5-1135G7. It has Winbond 25R256JVEQ BIOS which has black epoxy resin. I have 2 questions. What method do you use to remove the epoxy? and the second, what chip do you use to program it if you have the TL866 II Plus programmer? Thanks in advance.
Black Epoxy on bios chip
Tags: None
I believe you may be referencing the wrong flash onboard. Hunt around for another similar flash device. This pic is of a Winbond W25R256 which is a secure flash device with a replay protection counter feature. Do not believe that you will be able to properly program this device. Wait on others to comment but there should be another standard flash bios onboard.
For the epoxy, low heat (100-150C) should allow this compound to become brittle and flake off with tweezers. -
This is the worst part of Lenovo. They put this black glue on almost every chip nowadays.Earlier it was only under BGA chips but now even core ic has it.
This epoxy wont melt at temps suggested by mon2. You can use a glue cutter knife very carefully to remove the glue to some extent and then flux and hot air gun to lift it.
Be careful not to cut the trace on PCB.
I managed to remove a thinkengine chip in this way without damaging the PCB pads.Comment
according to the schematics the W25R256JV is the only SPI flash on the board.
This black glue is called underfill. If you search for "underfill tools" you will get some tools that might help a little bit.Comment
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by SMDFleaCommon SPI bios chip programming Questions and Answers
Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
A: If you can`t read from it how do you expect to write to it ?.
Q: Why is my bios chip unreadable ?.
A: The programmer is faulty or has a worn or broken zif socket.
The USB cable is frayed,connector pins worn or some other physical damage.
Not enough amperage or voltage to power the programmer properly.
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
by JoWedHello Community,
I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...-
Long story short:
- dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
- gave the computer to his son a couple years later
- son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
- too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
(seems like the story was not that short)
He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8... -
by inck243Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
The BIOS...-
- Loading...
