FX553VE-DM318T(FX553v) not POSTING
  • claws77
    • Apr 2024
    • 99
    • India
    #41
    Does it have to be exact same bios chip?
    i have mx25c6473f from a desktop motherboard.
    Both are 64 mb.🤷‍♂️
    This will be my segue into owning a hot air rework station.
    • m1ch43lzm
      • Mar 2019
      • 415
      • Peru
      #42
      Opening the BIOS in UEFITool - Descriptor region says this:
      Flash chips in VSCC table:
      C22017 (Macronix MX25L64)
      EF4017 (Winbond W25Q64)
      EF6017 (Winbond W25Q64)
      C84017 (GigaDevice GD25x64)
      20BA17 (Micron N25Q064)
      Either one is compatible, if the other chip you have is actually MX25L6473F it looks like it's compatible, according to the datasheet for that chip the device ID is C2 20 17, which is in that list
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
      • q2v5
        Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
        by q2v5
        Lenovo T480s
        Model 20L8-S3TE00
        Board ET481-U10
        Chip MX25L12873F
        Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
        2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
        The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
        08-15-2024, 10:40 PM
      • Neddsme
        Bios partially corrupted somehow and now warm boot doesn't work which is critical
        by Neddsme
        Hie.
        I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
        Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
        I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
        I managed to run Windows troubleshooting and...
        02-04-2022, 05:57 AM
      • Max029
        Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
        by Max029
        I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
        I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
        TY,
        08-18-2024, 08:28 PM
