Gateway (shudder) NV59C63u charges battery, blue LED when powered, then shuts down
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Gateway (shudder) NV59C63u charges battery, blue LED when powered, then shuts dow
    Your problem has nothing to do with the power button. Just check pin 2 (lid_sw) on the connector to see if it is high.
    Firtsly, I should check all connectors for shorted pins.
    • dj_ricoh
      • 2073
      apparently the only additional board it has its the power button!
      the board its new(apparently)
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3593
        • slovakia
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          switch is 3.19V on it whether on or off ,should drop to 0v when pressed looks like the switch is o/c or no ground in that case ribbon cable damaged.
          • withalligators
            • Jun 2013
            • 267
            Pin 2 LID_SW is at 3.37 on or off with the lid open.
            When I test pin 9 ON/OFFBTN, I do get 0.02V while the button is depressed. As soon I release the button, it goes up to 3.26 or so. Most of the time, sometimes, it stays at 0.02V until I take the probe off and put it back on. In which case it jumps back up.
            Very strange, I wonder how much of my testing is user error.
            • atsio
              • Oct 2013
              • 819
              • Greece
              #26
              As I told you. Your problem has nothing to do with the power board.
              Check if you have shorted pins on all connectors (i.e. LVDS).
              • withalligators
                • Jun 2013
                • 267
                OK, I've been testing for continuity between pins on various ports. Not knowing what should and shouldn't have connectivity, I get some beeps no the RAM pins, some on the LVDS, a split second of it with various pins and pin 1 on the power board port.
                How do I know where there is supposed to be continuity and where it's a short?
                Cheers,
                Alex
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  #28
                  When I say shorted pins I mean bended pins.
                  • withalligators
                    • Jun 2013
                    • 267
                    I went over it with a magnifying lens, I don't see anything that looks bent or pressed together.
                    Any ideas of where I would look to find the most likely shorts based on the behavior of the computer?
                    • dj_ricoh
                      • 2073
                      #30
                      i wanna ask you this again to be 100%
                      bought it from ebay with new status?
                      • withalligators
                        • Jun 2013
                        • 267
                        yeah. and it looks new too. No wear on the inside of any of the ports. Doesn't mean it's not bad.
                        • withalligators
                          • Jun 2013
                          • 267
                          But since the symptoms are the SAME with the old board, I feel like it's got to be one of the original components. CPU, Power button module, or something else.
                          • withalligators
                            • Jun 2013
                            • 267
                            Any opinions on what you'd replace first, guys? CPU or power button module? Or tell the seller I think I got a bad board?
                            • withalligators
                              • Jun 2013
                              • 267
                              Ok, I went with the power button module board. I'll update if it does anything
                              • dj_ricoh
                                • 2073
                                #35
                                find a intel Pentium processor like this one P6200 .
                                maybe you can find it cheap.
                                • withalligators
                                  • Jun 2013
                                  • 267
                                  Any reason why you chose the pentium? If it's cost, I can find i3 1st generation on ebay for less than $10 often.
                                  Cheers,
                                  Alex
                                  • withalligators
                                    • Jun 2013
                                    • 267
                                    Ok, solved. It WAS a bad, yet new, motherboard. The seller sent me another, I put everything in, and it booted right up. I then discovered the screen was also bad, but that's easy.
                                    Thanks for the input guys.
                                    Cheers,
                                    Alex
                                    • dj_ricoh
                                      • 2073
                                      #38
                                      pfiu!
                                      good news at last!
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        Originally posted by withalligators
                                        When I got it, if you pressed the power button, the blue LED would light up, but that was it. The fan spins, but no screen illumination, nothing. After a few seconds, it would turn itself off, then back on again and the fan would spin, but everything else would be the same and it wouldn't shut itself off.
                                        Possibly a bad socket. Sounds like identical symptoms to my Maximus II Gene (LGA 775) before being RMA'ed in 2013. It had F-ed up socket pins.
                                        Even though laptops apparently never used LGA.
                                        ASRock B550 PG Velocita
                                        Ryzen 9 "Vermeer" 5900X
                                        Arc A770 16 GB
                                        eVGA Supernova G3 750W
                                        Alienware AW3423DWF OLED
                                        • huzo
                                          HP Omen shuts down when loading OS
                                          by huzo
                                          The model is 15ec-1061nm
                                          Board number is DAG3EDMB8D0​
                                          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                          10-29-2024, 12:05 AM
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
                                        • Hannibal_Hector
                                          Samsung UN39EH5003FXZA won't stay powered off
                                          by Hannibal_Hector
                                          Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
                                          03-02-2021, 07:57 PM
                                        • baglaivlad
                                          A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
                                          by baglaivlad
                                          Hello everybody!
                                          Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
                                          After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
                                          11-20-2024, 08:14 AM
                                        • samuelphirik
                                          Dell inspiron 15 7567 sudden shuts down
                                          by samuelphirik
                                          Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
                                          During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
                                          I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
                                          Now I've noticed that laptop...
                                          07-02-2023, 05:45 AM
