eMachines E527: No Speaker Output
  • speedypro
    • Feb 2013
    • 561
    Headphone output works but not speakers. Tried known working speakers but nothing. Any help or schematic?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: eMachines E527: No Speaker Output
    Here is the e525 can you gives the motherboard number.
      I do not believe it has speaker level output, only line level output for feeding the powered speakers.
      • dj_ricoh
        • 2073
        • uk
        BUDM on U26 pin 35,36 , 37 , 38 are the same?
        its this chip doing the output for the speakers?
        • speedypro
          • Feb 2013
          • 561
          I have replaced U26 with a new one but same issue. That was the first ic that came to mind but that is not the case.
          • whaldsz
            • Apr 2013
            • 395
            • Philippines
            Check the amplifier (U29 - TPA6017) if it is receiving signal from U26.
            • speedypro
              • Feb 2013
              • 561
              Sorry. I only replaced U29 so I guess I should do the same wth U26. @whaldsz, I will replace as I have no tools to test signal.
              • fddizon
                • Sep 2011
                • 555
                • Philippines
                try replacing stereo jack. as far as i know, if plug is removed, the signal will be redirected to line going to speakers. there are switch inside the jack to mute speaker when stereo plug is inserted.
                correct me if im wrong
                • speedypro
                  • Feb 2013
                  • 561
                  Replaced U26 and it worked
                  U26
                  Thanks!
                  • dj_ricoh
                    • 2073
                    • uk
                    Nice job!
                    • whaldsz
                      • Apr 2013
                      • 395
                      • Philippines
                      so you replaced U29 and it worked?
                      • dj_ricoh
                        • 2073
                        • uk
                        apparently yes!
                        I had a acer that did the same thing.
                        it work with headphones but in my case it could have been the jack that did not unlock the internal speakers from that jack.
                        • tmcw
                          Stereo speakers to mono speaker
                          by tmcw
                          I picked up this set of powered PC speakers, no name brand, power cord to one of the speakers, and two audio cables coming out of it, one going to the other speaker, and the other to a 3.5mm jack for plugging into an audio out source.
                          So, a typical cheap powered PC speakers setup.
                          Now, the sound is pretty decent, I must admit, from the 4 ohm, 3W speaker, but I say "speaker", because it's just coming out of one of the speakers, and not the one with the power cord coming out of it. The other speaker is ok, it's just the electronics going to it has probably a fried...
                          05-12-2021, 08:04 AM
                        • RetroComputingGrotto
                          Behringer MS16 Speakers - Low Volume on One Speaker
                          by RetroComputingGrotto
                          I've had a set of speakers come in with the fault of not powering on.
                          I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
                          1 random loose nut and part of a BIC Biro pen.
                          After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
                          05-20-2024, 07:29 AM
                        • Califauna
                          Help with boom box modification
                          by Califauna
                          Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
                          I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
                          From factory the specs of the boom box are:
                          -Power Input: DC 5V
                          -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
                          -Drivers:
                          -2 x Woofer, 70mm, 10Ω, 70mm,15W
                          -2 X Tweeter, 8Ω, 30mm,10W x 2
                          -Frequency...
                          12-04-2021, 01:53 PM
                        • DrDos
                          Unit runs but no speaker output kenwood KR-6030
                          by DrDos
                          I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                          09-14-2025, 09:57 PM
                        • paparazzo79
                          mini PC HP Elitedesk connecting speakers to headphone output?
                          by paparazzo79
                          Hi guys.
                          I have this mini PC HP Elitedesk which has 2 headphone outputs on front.
                          May I connect speakers with/without amplifier to that output without harm to the PC?
                          I have 2 types of speakers regular one without amplifier (just getting power over usb port) and second type is 2.1 system with subwoofer (probably have amplifier on sub).
                          I may also buy USB sound card but I see that card has also headphone output marked with headphone icon.
                          08-19-2023, 12:33 AM
