Dell Inspiron N5010 no power!
  • JGAN
    • Aug 2012
    • 28
    Hey guys,
    I got a Dell Inspiron N5010 that isn't getting any power. The power brick is 100% good (I use it with other laptops all the time), but the battery does not seem to charge, there are no lights or sounds, and of course it won't boot.
    I would like to fix this, but unfortunately these laptop schematics (N5010 here) are just way too complicated for my elementary training. I have checked PU4502 as detailed in this post, and got 19.4v at the source and gate, and 0.4v at the drain. Not sure what any of this means though?
    Could use some help! Thanks in advance
    JGAN
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Dell Inspiron N5010 no power!
    Probably problem with PU4501 (charger IC)
    • tomodachi
      • Apr 2012
      • 602
      • Turkey
      please post the voltage on power button, you should read 3.3V,
      if there is 3.3v you should flash the EC bios chip with a good dump.
      • spleenharvester
        • Mar 2010
        • 903
        Originally posted by JGAN
        Hey guys,
        JGAN
        https://www.badcaps.net/forum/showthread.php?t=29233 Checked that IC? Seems to be common.
        Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
        • atsio
          • Oct 2013
          • 819
          • Greece
          Gate voltage on PU4502 should be 1.72 voltage (just above minimum threshold voltage of AO4407A (1.7v)).
          To get that voltage PQ4501 must get HIGH voltage to its gate from ACOK pin of charger.
          ACOK should be high if there is 2.5v at pin 2 (ACIN) of charger and charger is functioning.
          • JGAN
            • Aug 2012
            • 28
            Sorry to disappoint you all, but I ended up breaking one of the ZIF connectors on the board and I figured I might as well replace the whole thing now. I appreciate all your help though, maybe next time!
            • alihomee
              • Dec 2012
              • 1576
              • malaysia
              check 3v and 5v supply and clear pictures also can help
              • ghojariya abdul
                • Jul 2014
                • 39
                • india
                hi guys,
                please help me. i have a dell 5010 laptop with power on password.
                can anybody tell me how to crack t. please......
                • zlr8r
                  Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                  by zlr8r
                  hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                  Ill try and give as much info as I can.
                  Dell Inspiron 17 (7786) Laptop
                  Service Tag: 5J0NHT2
                  Bios: 1.9.0
                  When I received this , it would only flicker on the KB backlight for a second, then off and on.
                  Then it started getting weirder!
                  Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                  12-12-2023, 09:31 PM
                • madura2010
                  Dell inspiron 3168 (15299-2) no power
                  by madura2010
                  Dell inspiron 3168 (Board no=15299-2) no power with battery and charger.No charging.
                  But after removing battery, worked perfectly.
                  next day again no power.Then check 19v section.section ok.mosfet driving perfectly.
                  But 3v LDO was not generated.Then i checked the enable signal of the ic.It is perfect according to datasheet.Then i checked the impedence.It is perfect(444).So i replaced the 3v ic.Then worked.
                  Again next day, same issue.then i decided to disconnect the ldo line by cutting the path.After that LDO generated well.Then again connecting...
                  01-28-2024, 09:10 PM
                  DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                  This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                  09-12-2024, 02:15 PM
                • Scaff
                  Dell Inspiron 7506 2-in-1 HELLCAT 19859-1 - No power
                  by Scaff
                  I've had trouble with the power on this device since I got it. It always shut down with no warning and would often fail to power up. Dell's advice has been to disconnect the power and battery, wait, then reconnect and boot. Letting the battery run down completely also helped. I had them come out at one point and they said they replaced the board. This helped for a while but then it just stopped powering on. At this point it's well out of warranty. I missed the chance to get them to come out again because life. Current situation is it shows zero signs of life with both barrel...
                  06-08-2025, 01:46 AM
