Dell inspiron 3168 (15299-2) no power
This topic has been answered.
  • madura2010
    • Feb 2021
    • 32
    • Sri Lanka
    Dell inspiron 3168 (Board no=15299-2) no power with battery and charger.No charging.
    But after removing battery, worked perfectly.
    next day again no power.Then check 19v section.section ok.mosfet driving perfectly.
    But 3v LDO was not generated.Then i checked the enable signal of the ic.It is perfect according to datasheet.Then i checked the impedence.It is perfect(444).So i replaced the 3v ic.Then worked.
    Again next day, same issue.then i decided to disconnect the ldo line by cutting the path.After that LDO generated well.Then again connecting the path leads to cutoff 3v ldo.Impedence of the ldo line is 444.But KBC vdd pin impedence is 70.Should i want to replace KBC.It is nuvoton NPCE985 non programmable ic.There is a issue in the keyboard as well.customer said thatbkeyboard function well.but during power on sessions, keyboard also not working.
    My problem is that, why sometimes generating LDO and working perfectly and during the session of no power, after disconnecting KBC power, LDO regenerates and disappear after connecting KBC power.What should i do?Highly appreciated any comment.
  • Answer selected by madura2010 at 02-02-2024, 08:00 PM.
    madura2010
    • Feb 2021
    • 32
    • Sri Lanka
    Highly appreciated your assistance.I will replace it after online purchase
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Link schematic if its available. What is the name of the 3V PWM ic? ENABLE LDO status?
      • madura2010
        • Feb 2021
        • 32
        • Sri Lanka
        dell 3168 schematic .
        [MOD EDIT]
        Reminder: rules and organization of this section -> https://www.badcaps.net/forum/troubl...f-this-section
        If you request/offer BIOS/schematics/boardviews, please post in the appropriate subsection, and you can link to it in the troubleshooting topic.
        • madura2010
          • Feb 2021
          • 32
          • Sri Lanka
          3v ic sys8286brac
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Voltage on pin5/11/12/17 of SY8286BRAC
            01.When its working
            02.When its not working.
            • madura2010
              • Feb 2021
              • 32
              • Sri Lanka
              voltages on SY8286BRAC
              01.when it is working
              pin5=19v
              pin11=18.96v
              pin12=3.3v
              Pin17=3.3v
              02.when it is not working.
              pin5=19v
              pin11=18.96v
              pin12=3.3v
              Pin17=0v
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                The requirement of SY8286BRAC is all fullfilled for generating LDO under both the scenario-so something is wrong on 3V LDO line. I'll suggest to cut the track of 3V LDO and inject 3V/5A on consumer side of LDO. What is the current draw on your dc power supply?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Also give resistance to GND measurement of 3V LDO(after cutting the track) on both sides preferably in ohms mode(meter at 200K scale.
                  • madura2010
                    • Feb 2021
                    • 32
                    • Sri Lanka
                    cutting 3v ldo line generates 3v ldo all the time.
                    injecting 3v 5a in OCP mode does draw only small current less than 0.01amps.no short is displaying.
                    cutting Ldo line.
                    impedence of the end close to the 3v ic=444
                    impedence of the other end=70
                    thank you for assisting.highly appreciated the assistance.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      I always prefer resistance to gnd measurement in ohms mode and not diode mode. Since its not a dead short on LDO line,its advisable to remove the SIO and see if resistance to GND on consumer side of LDO jumps up. You can also inject 3V on pin19 of SIO and see if it becomes hot. Keep the LDO track cut for the time being.
                      • madura2010
                        • Feb 2021
                        • 32
                        • Sri Lanka
                        I have injected 3v to pin 19 of SIO.only around 100ma consuming.No heat at all on SIO.I will check the resistance to ground after removing SIO and inform.Thank you for the precious assistance.Highly appreciated
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          SIO should'nt consume 100mA on voltage injection at pin19. I beleive its partially shorted.
                          • madura2010
                            • Feb 2021
                            • 32
                            • Sri Lanka
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              You should remove the SIO and check resistance on pin19 of SIO again before ordering. We're still not 100% sure that SIO is bad.
                              • zlr8r
                                Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                by zlr8r
                                hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                Ill try and give as much info as I can.
                                Dell Inspiron 17 (7786) Laptop
                                Service Tag: 5J0NHT2
                                Bios: 1.9.0
                                When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                Then it started getting weirder!
                                Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                12-12-2023, 09:31 PM
                                DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                09-12-2024, 02:15 PM
                              • Scaff
                                Dell Inspiron 7506 2-in-1 HELLCAT 19859-1 - No power
                                by Scaff
                                I've had trouble with the power on this device since I got it. It always shut down with no warning and would often fail to power up. Dell's advice has been to disconnect the power and battery, wait, then reconnect and boot. Letting the battery run down completely also helped. I had them come out at one point and they said they replaced the board. This helped for a while but then it just stopped powering on. At this point it's well out of warranty. I missed the chance to get them to come out again because life. Current situation is it shows zero signs of life with both barrel...
                                06-08-2025, 01:46 AM
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
