This wasn't supposed to work...
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Replaced a nvidia 8400 in a Packard Bell laptop i just got. Altho the chip moved no problem when i poked it, it took away three pads on the edges when i lifted it... All 3 with visible traces.
    My first time lifting pads in quite a while. Normally, the board would have been scrap, but having no other choice, i decided to try and fix them. Notice the really tiny wire in the middle of each of the lifted pads.
    Was quite the adventure to get wires soldered to the traces AND then tin them without them getting unsoldered again. But the end result? Soldered the replacement chip on and everything works fine.
    A working TV? How boring!
  • 3d0
    • Jan 2014
    • 159
    • BiH
    Re: This wasn't supposed to work...
    I don't see any lifted pads :P
    Well done!
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      u did really a great work!!!! what king of wire did u use for repair ? 0.1mm or normal awg30 ?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        I didn't have wire thin enough, so i cut a piece of fresh desoldering wick and pulled the wire from that. Took me about 1 hour to solder 3 tiny pieces of wire... But in the end, it was worth it.
        And just in case you didn't believe me, here it is all back together. I like that, just like its 17" brother, this one has a little subwoofer too so it sounds nice. Actually what i did is i traded its big brother in working condition for this one with bad video, and some cash.
        Now to take more pics and put it up for sale, as i don't have much use for it. The reason is right there at its left and it's called Lenovo R61i. That one deserves a topic of its own, sometime later.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4958
          • New Zealand
          Nice solder job. I can just imagine how much fun that was...
          -David VanHorn
          • trebo
            • 514
            • Wales, UK
            great job, perseverance at its best, enjoyable ending
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              "Fun" is an understatement. When i saw what happened i was like #@!&, but then i thought i've got nothing to lose anyway, so i put a new tip on my iron and went ahead with it. And... it worked.
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                wich bga station do you have? i got one and after one reball, vga give same error
                • sorinac
                  • Jul 2013
                  • 123
                  • Romania
                  if vga give same error after reball the it's most possible faulty
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Ghetto'd it together myself. Hot air station + stand + 41x41mm BGA nozzle + preheater = BGA rework tool. Wouldn't attempt removing big chips like those on desktop cards, but for laptops it works fine. I only use leaded solder too, i reball even chips i buy new. Lower soldering temperatures make it easier to work with higher success rates. Broke only one board in the past year.
                    I don't do too many reballs so investing in a proper BGA station would be pointless. I do 4-5 a month at most.
                    Agree with sorinac here: chip's faulty if it does the same after reballing. Nvidia chips dated 2006-2008 are to replace on sight with new one, for them a reball doesn't last more than a reflow, because the problem is with the solder bumps inside the chip, not the balls under the BGA.
                    • orientalsniper
                      • Apr 2013
                      • 459
                      What do you use for stenciling?
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        I use direct heat stencils.
                        • orientalsniper
                          • Apr 2013
                          • 459
                          Sorry for hijacking, but got any link for the product you are using?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            What do you mean? Can't figure out which product you are asking about.
                            • orientalsniper
                              • Apr 2013
                              • 459
                              The direct heat stencil tool you are using.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                As in what do i use to reflow the balls? Same hot air station. The key to successful reballing using a hot air wand is to use as low a temperature as possible. For this i take a piece of leaded solder and increase the temperature until it liquefies with the wand at 5mm from the solder, and use that temperature, no higher. That way i'm certain i won't overheat the chip. Don't worry if it takes a couple minutes for all the balls to stick, it's better to be a little patient.
                                When there's a few stubborn ones, i put some flux over them and go with the wand one more time in that area, and they're all good.
                                For removing the stencil, i let it cool down completely then set the temp to 250C and the air on max, and blow on the stencil for 10-20 seconds. This activates the flux without melting the solder, so the stencil comes off easily. Some people prefer removing it while it's still warm, but if you do it too soon you damage the balls and have to do it all over again. It's safer this way.
                                • orientalsniper
                                  • Apr 2013
                                  • 459
                                  I actually meant which stencil tool are you using, can you tell me your model or the page where you bought it from? Do you vouch for it? This is an example: http://www.zeppelincomputers.com/dat...stencils_4.jpg
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    I actually use the same crap you posted in the picture. Cheap and nasty but it does the job. Getting the balls reflowed on the sides where the holders are can take a while tho.
                                    Some people prefer taping the stencil to the chip with aluminum tape and reball it without using a holder/jig, you may look into that.
                                    • xboxhaxorz
                                      • Jan 2011
                                      • 196
                                      My vision isnt the greatest but there doesnt appear to be any lifted pads obviously because you repaired it duh
                                      Trace repair is TIME CONSUMING, as you now realize and using the desoldering braid is a great way to repair them
                                      When doing trace repair it is always best to use lead free solder for the repair so that when you use lead solder balls you dont take it high enough to melt the trace repair solder
                                      The other option in trace repair is NOT repairing the trace lol and simply solder the trace to the solder ball on the chip which i tend to avoid and perform actual trace repair
                                      So if you can do trace repair, which you have that would put you on a expert soldering level
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        Now that's a good idea... Thanks. I used 60/40 solder for the repair as that's what i use on everything (well, the balls are 63/37 but apart from that...). Worked fine but that's to note down for the future.
                                        • hollox123
                                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                          by hollox123
                                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                          1. Laptop keyboard doesn't work
                                          2. The backlight on the laptop keyboard doesn't work
                                          3. The x2 side LEDs (red) on the laptop don't work
                                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                                          05-11-2025, 08:05 AM
                                        • resistor83
                                          lenovo 330s-15ikb, led num lock key always on and numbers don't work
                                          by resistor83
                                          hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
                                          I tried updating the bios but the problem remains
                                          https://s...
                                          05-29-2025, 08:06 AM
                                        • Forumzboard899
                                          PAD repair? What are pads?
                                          by Forumzboard899
                                          This is a Roland MC-505 synthesizer I bought used years ago and 1 of the knobs was bent.
                                          Eventually it started 'ghost editing' by changing the parameter of this knob on its own.
                                          I resoldered the 5 pins on this knob (the two larger solder spots above these 3 smaller ones is for the same knob).
                                          Then it started happening again, or maybe the knob stopped working totally (I set it aside months ago and forgot about it).
                                          I bought a replacement knob/Potentiometer but when I recently opened it up, it seems the previous repair...
                                          03-07-2022, 05:30 PM
                                        • langbaobao
                                          DIY 3D-Printer WSON8 Pogo Pin Adapter
                                          by langbaobao
                                          Hi.
                                          I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                                          I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                                          01-08-2024, 05:58 PM
                                          DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
                                          by sam_sam_sam
                                          I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
                                          If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
                                          One —>the LEDs might be bad
                                          Two —> the buck converter or regular might be bad
                                          Three —> the controller might not...
                                          08-08-2023, 05:12 PM
