Macbook Pro 13" A1706
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    I have one strange issue with Macbook Pro 13" A1706 (touch bar) 4 TB ports
    Issue is that all 4 ports are working but on one port only one side (when i rotate connector 180 degree there is nothing (ampmeter is not turned on at all) and charger (original apple) is put to protective mode, I have to unplug USB from the power brick to enable it again.
    I've tried multiple USB-C ports (one one side all ports all sides work when i reconnect it to other side both ports work but one only on one side)
    There is no issue problem on the board (no liquid damage, no damaged component), connector is in great condition
    I've also tried to check with thermal camera but nothing lights up ....
  • mon2
    • Dec 2019
    • 14027
    Remove all power. Meter in DIODE mode. Red meter probe to ground. Black meter probe to point to test. Take the measurements of the bad side USB Type C connector and compare the diode mode measurements with a known good connector. It is possible that the ESD TVS diodes are damaged for that side of the USB Type C connector blade.
    • obelix24
      • Jun 2023
      • 291
      • Slovakia
      It looks like this is the bad side
      • mon2
        • Dec 2019
        • 14027
        Share a view of this meter on a good and working port.
        • obelix24
          • Jun 2023
          • 291
          • Slovakia
          This are meassurements from other side (where are two ports) that work both sides
          • PITERPENY
            • Jul 2023
            • 455
            • Ukraine
            If the USB-C port is not rotten, then I think it’s time to change the SD3215 port that doesn’t work
            • mon2
              • Dec 2019
              • 14027
              See a lot of red there in the test results. We recently purchased this tool and it arrived late yesterday. Will test it against some units in the building but suggest that you do the same. Insert this tool into a known good Type C based macbook to compare the results.
              • rilley
                MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                by rilley
                I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                And the resistor L4004 is literally burned.
                From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                07-10-2024, 01:57 AM
              • Danielreinaa
                HELP need password bios Macbook A1706
                by Danielreinaa
                Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                09-07-2024, 03:47 PM
              • capon5153
                Macbook A1706 works perfectly but no data on USB C
                by capon5153
                hello,
                so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                06-22-2025, 09:42 AM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • obelix24
                A1706 - Macbook pro - one USB-C port only 20V 0A
                by obelix24
                I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                There were some broken pads under CD3215 but i've recreated them.
                What should be...
                05-22-2024, 08:04 AM
