Macbook Pro 13" A1706
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    I have one strange issue with Macbook Pro 13" A1706 (touch bar) 4 TB ports
    Issue is that all 4 ports are working but on one port only one side (when i rotate connector 180 degree there is nothing (ampmeter is not turned on at all) and charger (original apple) is put to protective mode, I have to unplug USB from the power brick to enable it again.
    I've tried multiple USB-C ports (one one side all ports all sides work when i reconnect it to other side both ports work but one only on one side)
    There is no issue problem on the board (no liquid damage, no damaged component), connector is in great condition
    I've also tried to check with thermal camera but nothing lights up ....
  • mon2
    • Dec 2019
    • 14996
    Remove all power. Meter in DIODE mode. Red meter probe to ground. Black meter probe to point to test. Take the measurements of the bad side USB Type C connector and compare the diode mode measurements with a known good connector. It is possible that the ESD TVS diodes are damaged for that side of the USB Type C connector blade.
    • obelix24
      • Jun 2023
      • 300
      • Slovakia
      It looks like this is the bad side
      • mon2
        • Dec 2019
        • 14996
        Share a view of this meter on a good and working port.
        • obelix24
          • Jun 2023
          • 300
          • Slovakia
          This are meassurements from other side (where are two ports) that work both sides
          • PITERPENY
            • Jul 2023
            • 477
            • Ukraine
            If the USB-C port is not rotten, then I think it’s time to change the SD3215 port that doesn’t work
            • mon2
              • Dec 2019
              • 14996
              See a lot of red there in the test results. We recently purchased this tool and it arrived late yesterday. Will test it against some units in the building but suggest that you do the same. Insert this tool into a known good Type C based macbook to compare the results.
              • silver60618
                Macbook Pro A1990 - Battery not detected after connector torn off
                by silver60618
                Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
                Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
                11-12-2025, 06:36 PM
              • rilley
                MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                by rilley
                I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                And the resistor L4004 is literally burned.
                From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                07-10-2024, 01:57 AM
              • Strolch
                MacBook A1990 26 Pin Connector
                by Strolch
                Hello, can anyone tell me where I can get this 26-pin FPC connector? What is the connector for?So that one's also for the Touch Bar. I thought only the FPC at the top was for the Touch Bar. But where can I get it? I can't find the connector online. I only found the 22nd pin. Thank you....
                09-03-2025, 01:11 AM
              • Danielreinaa
                HELP need password bios Macbook A1706
                by Danielreinaa
                Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                09-07-2024, 03:47 PM
              • capon5153
                Macbook A1706 works perfectly but no data on USB C
                by capon5153
                hello,
                so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                06-22-2025, 09:42 AM
