After change screen no video
+ More Options
Posts
  • MDY
    • Jan 2014
    • 75
    • Spain
    After change screen maybe with battery on, no video on screen. I do have video on VGA out. Screen is LED 40 pins. What can I check on it? I do have 19V on LVDS cable.
  • dj_ricoh
    • 2073
    Re: After change screen no video
    the cable its bad
    p.s. did you saw sparks? if not your ok. i know that case but it makes sparks then your f k
    if it makes sparks it will not even power
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      dj,
      y sparks happen?
      • dj_ricoh
        • 2073
        i change the mobo then ( the problem then it had no backlight and i forgot the bat on)
        dude i`m sorry for you. if you manage to fix it i wanna work for you as a apprentice.
        • lefos
          • Nov 2013
          • 321
          • Greece
          Have you checked for any fuse near the lvds connector? Does it have picture but no backlight?
          • kisk
            Computer Tech
            • Jan 2014
            • 78
            What is the laptop model? Were you changing a cracked screen or a different screen with no picture?
            • Francisco.s
              • 686
              • Spain
              Probably the sio (embedded controller) has died. Usually the pins that control brightness, have no serial protector resistance, (connected directly) so current trough this pin became extremely high, destroying this sio output.
              Try to cut this trace, and supply a fix 3,3v at connector brightness pin.
              The schematic will help.
              • MDY
                • Jan 2014
                • 75
                • Spain
                Thanks to all for replay. I do have image, but no backlight.
                I checked datasheet of screen LP156WH4 and I have:
                pin2 3.3V
                pin3 3.3V
                pin4 3.3V
                pin 36 (LED_EN) 0,26V
                pin 38,39,40 - 19V
                I think problem is pin 36 (LED_EN) 0,26V. I checked the same pin in motherboard and I have the same 0.26V
                I think in this pin I should have 3V to enable backlight on/off, right??
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Yes exactly. I have the exact same problem with a Lenovo X200 that someone brought in a couple days ago. The backlight died after a water spill on the board. I have managed to fix the 20v power trace (a fuse blown and some corrosion), but i have LED_EN shorted to ground, so still no backlight.
                  I'll let you guys know if i manage to fix it.
                  A working TV? How boring!
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    I did fix the Lenovo - i lifted the BACKLIGHT_ON (aka LED_EN) pin from the display connector and wired it to 3.3v from somewhere else on the board. The laptop lost ability to turn the screen backlight off but that's better than no backlight at all. It does turn off when the laptop is put into sleep or shut down, so that's good enough. It's back to the owner now.
                    • nickscott818
                      Banned
                      • Jan 2014
                      • 6
                      I had the same problem when I had replaced the sony vaio screen. It was not showing anything on the screen. I double checked the wires again found that the cable connecting to the mother board was out.
                      • MDY
                        • Jan 2014
                        • 75
                        • Spain
                        Hi Th3_uN1Qu3
                        I found that pin 34 is System PWM Signal input for dimming and also has to have 3V
                        By the way, what did you put on the cable to aislate?
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Hot glue.
                          • MDY
                            • Jan 2014
                            • 75
                            • Spain
                            Hot glue.
                            Yesh, but do you use this one? http://www.leroymerlin.es/img/r25/04...2218640_ls.jpg
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Something like that.
                              • iZakre
                                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                by iZakre
                                Hello everybody!
                                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                The thing is that I had installed TeamViewer and could log into the computer...
                                02-19-2023, 02:27 PM
                              • Ryan.man
                                by Ryan.man
                                02-04-2025, 12:23 PM
                              • ferah831208
                                HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
                                by ferah831208
                                I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
                                12-07-2024, 04:02 PM
                              • smic717394
                                by smic717394
                                07-25-2024, 10:16 AM
                                HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                09-12-2024, 02:00 PM
