After change screen no video
  • MDY
    • Jan 2014
    • 75
    • Spain
    After change screen maybe with battery on, no video on screen. I do have video on VGA out. Screen is LED 40 pins. What can I check on it? I do have 19V on LVDS cable.
  • dj_ricoh
    • 2073
    Re: After change screen no video
    the cable its bad
    p.s. did you saw sparks? if not your ok. i know that case but it makes sparks then your f k
    if it makes sparks it will not even power
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      dj,
      y sparks happen?
      • dj_ricoh
        • 2073
        i change the mobo then ( the problem then it had no backlight and i forgot the bat on)
        dude i`m sorry for you. if you manage to fix it i wanna work for you as a apprentice.
        • lefos
          • Nov 2013
          • 321
          • Greece
          Have you checked for any fuse near the lvds connector? Does it have picture but no backlight?
          • kisk
            Computer Tech
            • Jan 2014
            • 78
            What is the laptop model? Were you changing a cracked screen or a different screen with no picture?
            • Francisco.s
              • 691
              • Spain
              Probably the sio (embedded controller) has died. Usually the pins that control brightness, have no serial protector resistance, (connected directly) so current trough this pin became extremely high, destroying this sio output.
              Try to cut this trace, and supply a fix 3,3v at connector brightness pin.
              The schematic will help.
              • MDY
                • Jan 2014
                • 75
                • Spain
                Thanks to all for replay. I do have image, but no backlight.
                I checked datasheet of screen LP156WH4 and I have:
                pin2 3.3V
                pin3 3.3V
                pin4 3.3V
                pin 36 (LED_EN) 0,26V
                pin 38,39,40 - 19V
                I think problem is pin 36 (LED_EN) 0,26V. I checked the same pin in motherboard and I have the same 0.26V
                I think in this pin I should have 3V to enable backlight on/off, right??
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Yes exactly. I have the exact same problem with a Lenovo X200 that someone brought in a couple days ago. The backlight died after a water spill on the board. I have managed to fix the 20v power trace (a fuse blown and some corrosion), but i have LED_EN shorted to ground, so still no backlight.
                  I'll let you guys know if i manage to fix it.
                  A working TV? How boring!
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    I did fix the Lenovo - i lifted the BACKLIGHT_ON (aka LED_EN) pin from the display connector and wired it to 3.3v from somewhere else on the board. The laptop lost ability to turn the screen backlight off but that's better than no backlight at all. It does turn off when the laptop is put into sleep or shut down, so that's good enough. It's back to the owner now.
                    • nickscott818
                      Banned
                      • Jan 2014
                      • 6
                      I had the same problem when I had replaced the sony vaio screen. It was not showing anything on the screen. I double checked the wires again found that the cable connecting to the mother board was out.
                      • MDY
                        • Jan 2014
                        • 75
                        • Spain
                        Hi Th3_uN1Qu3
                        I found that pin 34 is System PWM Signal input for dimming and also has to have 3V
                        By the way, what did you put on the cable to aislate?
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Hot glue.
                          • MDY
                            • Jan 2014
                            • 75
                            • Spain
                            Hot glue.
                            Yesh, but do you use this one? http://www.leroymerlin.es/img/r25/04...2218640_ls.jpg
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Something like that.
