MacBook A2289 820-01987
  • Zparts01
    • Nov 2021
    • 107
    Hi mon2! The voltage on the usb C meter is 20v and 0.01a, then climes to 0.11a for a sec, then loops back to 0.01a. The reading is the same for both usb C ports on both sides. I am using the 61W USB-C Power Adapter and cable that came with the MacBook, but I have also tried another 96w Apple Charger as well with the same results. Also, might be worth nothing that it's the exact same readings even if the battery is connected or not.
    • mon2
      • Dec 2019
      • 14495
      Check the resistance to ground of each inductor onboard. Searching for any improper loads on the rail. A low resistance reading is a suspect.
      Check resistance to ground on PP2v5_NAND_SSD_0.
      • Zparts01
        • Nov 2021
        • 107
        Thanks mon2 I will have to check it and get back to you!
        • Zparts01
          • Nov 2021
          • 107
          Resistance to ground on PP2v5_NAND_SSD_0​ is .427
          • mon2
            • Dec 2019
            • 14495
            That is a diode mode voltage reading which looks ok.
            Meter in lowest resistance scale. Then measure the resistance to ground of this same voltage rail in ohms.
            • Zparts01
              • Nov 2021
              • 107
              31.32 ohms.
              • Zparts01
                • Nov 2021
                • 107
                That's with red on ground and black on component. Other way around it starts at 11.1 and starts to drop.
                • Zparts01
                  • Nov 2021
                  • 107
                  Does that number look correct?
                  • Zparts01
                    • Nov 2021
                    • 107
                    Anyone?
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 674
                      Source a good known battery like mon2 stated. Whoever said you don’t need a battery to DFU is some what correct and incorrect. But most likely you will need a good known battery to DFU correctly. Try that first then proceed further
                      sigpic
                      MEOWING IN THE IMPOSSIBLE UNIVERSE!
                      • Zparts01
                        • Nov 2021
                        • 107
                        Thanks Stephen, but you may have missed that I have already tried a brand new known working battery. That was not the issue. I was trying to find out what the resistance to ground on PP2v5_NAND_SSD_0 should be.
                        • Zparts01
                          • Nov 2021
                          • 107
                          I guess no one has any idea's what I might try next?
                          • mon2
                            • Dec 2019
                            • 14495
                            What is the voltage to ground of the following?
                            I2C_PWR_SDA_R2
                            I2C_PWR_SCL_R2
                            I2C_THMSNS_SCL_R0
                            I2C_THMSNS_SDA_R0
                            I2C_SENSE_SCL
                            I2C_SENSE_SDA
                            Click image for larger version  Name:	i2c_ISL9240.png Views:	0 Size:	346.5 KB ID:	3239222
                            • Zparts01
                              • Nov 2021
                              • 107
                              Hi mon2! Thanks for your reply. The readings for I2C_PWR_SDA_R2 and I2C_PWR_SCL_R2 are looping from 0v - 1.8v over and over again. The other areas you mentioned have zero voltage.
                              I2C_THMSNS_SCL_R0 = 0v
                              I2C_THMSNS_SDA_R0 = 0v
                              I2C_SENSE_SCL = 0v
                              I2C_SENSE_SDA = 0v​
                              • mon2
                                • Dec 2019
                                • 14495
                                For each of these i2c lines that are at 0 volts, check them in diode mode.
                                Remove all power, meter in diode mode. Red meter probe to ground. Black meter probe to point to test.
                                Post each diode mode measurement.
                                • Zparts01
                                  • Nov 2021
                                  • 107
                                  Thanks mon2! I will do this for sure and post the readings once I have them. I'm off for a week so can't get at it right now! Cheers!
                                  • Zparts01
                                    • Nov 2021
                                    • 107
                                    Hi mon2! The readings are ...
                                    I2C_THMSNS_SCL_R0 = 0.489
                                    I2C_THMSNS_SDA_R0 = 0.488
                                    I2C_SENSE_SCL = 0.519
                                    I2C_SENSE_SDA = 0.519​
                                    • mon2
                                      • Dec 2019
                                      • 14495
                                      These are good diode mode readings. With the posted values, these lines are not shorted.
                                      What are the voltage readings to ground for the following points?
                                      SMBUS_3V3_BATT_SCL ; expecting each to be @ 3v3 but confirm
                                      SMBUS_3V3_BATT_SDA
                                      See attached. Check the voltage to ground of PP1V8_G3S. What is the measurement?
                                      • Zparts01
                                        • Nov 2021
                                        • 107
                                        SMBUS_3V3_BATT_SCL ; Cycling back and forth between 3v3 and 2.75
                                        SMBUS_3V3_BATT_SDA ; Cycling back and forth between 3v3 and 2.75
                                        Zero voltage to ground on PP1V8_G3S​
                                        • Zparts01
                                          • Nov 2021
                                          • 107
                                          Does that give you any idea what it could be?
                                          • Flasman90
                                            Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
                                            by Flasman90
                                            Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
                                            My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
                                            What I have done so far:
                                            - All of the routine diagnostic methods including...
                                            08-29-2025, 08:38 AM
                                          • bluestone
                                            MacBook A2289 Restore Error
                                            by bluestone
                                            Recently is seems all the A2289 boards that I am trying to revive or restore using Apple Configurator 2 gives me error -1
                                            Have anyone experienced this and how to resolve it?...
                                            05-06-2022, 11:03 AM
                                          • Woodsworth
                                            MacBook Pro A2289 no signs of life except clicking trackpad and charging
                                            by Woodsworth
                                            I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
                                            "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
                                            It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
                                            03-15-2024, 04:06 AM
                                          • saisoni20
                                            MacBook Pro A2289 (820-01987-A) No boot or Display, but boots to DFU and shows status bar only
                                            by saisoni20
                                            Hi everyone.
                                            Recently got MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no Caps Lock, no life except the fan is spinning. But it is able to connect to DFU mode and recognized by another MacBook. I tried to revive but the process ends when the MacBook usually should show an Apple logo with a progress bar and giving me error AMRestoreErrorDomain error 9. I don't have CPU Vcore.
                                            Now I can't able to connect to DFU mode either.
                                            On the USB meter I got 20V/0.9A power draw, and keep looping....
                                            01-29-2024, 08:20 PM
                                          • Flasman90
                                            Macbook Pro DFU Restore Issues
                                            by Flasman90
                                            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                            08-30-2025, 10:27 AM
