MacBook A2289 820-01987
  • Zparts01
    • Nov 2021
    • 107
    I have a problem I'm hoping someone can help me with. I have an A2289 MacBook that had some liquid damage. After repairing any areas that had corrosion, I was able to get it to show 20v but only .01a on the multimeter. It was consistent on all ports, however I could not get the MacBook to go into DFU mode. I read that I should refllash U4770 and after grabbing the bin from this site I did just that. After soldering the chip back on the board, now I have DFU mode, but the thing is, it won't revive or restore, giving me the error that the device left the DFU state or something to that effect. The strange part is that I do notice the DFU screen in Apple Configurator very briefly indicates something has reset just before it fails, but then goes straight back to showing DFU mode again. It's like it won't come out of DFU now or something. Any idea what the problem could be? Also, the battery of this MacBook is an unknown status. Is it possible that a bad battery could be the cause of the issue or can DFU restore be completed with a bad battery?
  • mon2
    • 14677
    Fault may be with the SMBUS lines linked to the battery. Carefully measure the voltage to ground of each pin on the battery pack. Of particular interest are the SMBUS SCL and SDA lines. If either is shunted to ground, this will halt all SMBUS / I2C communications with the host and is a deal breaker for the boot process.
    • Zparts01
      • Nov 2021
      • 107
      They are both reading 3.28v with the battery connected and the MacBook plugged in. Should that be 3.3v?
      • Zparts01
        • Nov 2021
        • 107
        I once again removed U4770 and erased the chip, then put it back on the board. Still stuck in DFU. As soon as I plug it in, it goes to DFU and won't exit DFU mode even when I try to revive or restore. I've looked around and can't find any into to help with this. Seems like most people either have problems getting it into DFU or revive or restore just fails. My problem is that it always goes back into DFU on its own after it fails. It does say now something like DFU must have been started from an external source, but error is still 4014. I've tried with and without the battery plugged in and using the the external Apple power supply, but still the same problem.
        • mon2
          • 14677
          Error code 4014 = appears to be a NAND flash fault on assorted Apple products. Can you confirm the voltage rails for the nand flash?
          • luckydip
            • Aug 2016
            • 165
            • uk
            Sorry to hijack this thread but its a NAND related question. Working on a Air 820-02016, had extensive liquid damage around SPI/SOC which I hopefully sorted. Machine powers straight to DFU but when I restore get the 4014 error. Checked all the awake around NAND
            PP0V88_AWAKE_NAND, PP1V25_AWAKE_NAND, PP2V5_AWAKE_NAND all present.
            Any other power rails to check or dead NANDS? thanks
            • Zparts01
              • Nov 2021
              • 107
              I didn't get to this message before now mon2, but I have re-flashed the original bin to U4770 and now I'm getting 20v and every 20 seconds the amps go up to between 0.45 - 0.50 amps, then start back at zero and climb back up. Not after some time goes by I get a timeout "Gave up waiting for device to transition from DFU state to DFU state. [com.apple.MobileDevice.MobileRestore – 0xFCA (4042)" Also, under thermal camera I see small pulses of heat coming from U6903 if that information helps.
              • mon2
                • 14677
                Measure the voltage to ground of PP3V3_G3H_RTC (created by U6903). If this power rail is not 3v3 -> remove all power -> meter in resistance mode -> measure the resistance to ground of PP3V3_G3H_RTC @ L6900 or L6901.
                • Zparts01
                  • Nov 2021
                  • 107
                  It's reading 3.315v so I guess it's not that. Any other thoughts about what it might be?
                  • luckydip
                    • Aug 2016
                    • 165
                    • uk
                    Are all voltages for U5420 steady?
                    • Zparts01
                      • Nov 2021
                      • 107
                      I shall check that when I can get back to it tomorrow luckydip! Thanks
                      • Zparts01
                        • Nov 2021
                        • 107
                        With the battery disconnected and the power plugged in and the MacBook is in DFU mode and I get 0.44v, then it starts to drop quickly once I check the pins on U5420.
                        • Zparts01
                          • Nov 2021
                          • 107
                          and there is zero volts if it's not in DFU mode. Any idea what it could be luckydip or mon2?
                          • Zparts01
                            • Nov 2021
                            • 107
                            No one has anymore ideas?
                            • Zparts01
                              • Nov 2021
                              • 107
                              I changed U7710 and U8110 and also U6903 and still same problem.
                              • mon2
                                • 14677
                                A bad battery may be to blame. Can you source a known good battery from Amazon or similar for testing? It can be returned if not needed. Alternatively, recommend Mobile Sentrix (Canada). Same conditions apply - they will take it back if not required.
                                A2289 / 820-01987 no power | Page 2 | Rossmanngroup Forums
                                • Zparts01
                                  • Nov 2021
                                  • 107
                                  Thanks mon2! I was thinking about the battery, but I had seen so many post for this board that say you can restore in DFU without a battery or power supply connected that I just wasn't sure if that could be it (I've tried all the different ways, but I do think the battery is almost completely flat anyway). I do use Mobile Sentrix Canada for most of my parts so I guess I will give it a try and let you know!
                                  • Zparts01
                                    • Nov 2021
                                    • 107
                                    Sadly with a new battery no change at all. I am stumped. What else could it be?
                                    • Zparts01
                                      • Nov 2021
                                      • 107
                                      Just to add, my voltages for the following all are good, but they are not stable, they go to the correct voltage, then to 0v looping. They loop every few seconds. Here are the measured voltages ...
                                      L7660 PP3V3_G3H 3.3V
                                      L7806 PPVDDCPU_AWAKE 0.75V
                                      L7810 PPVDDCPUSRAM_AWAKE 0.8V
                                      L7811 PPOV82_SLPDDR 0.82V
                                      L7813 PP1V8_SLPS2R 1.8V
                                      L7814 PP1V1_SLPS2R 1.1V
                                      L7817 PPOV9_SLPDDR 0.9V
                                      F7000 PPBUS_G3H 12.2V​
                                      • mon2
                                        • 14677
                                        What is the voltage and current draw range on the usb C meter? The power adapter is rated to support this logic board? Is the power adapter the original from Apple? Is the power cable the one from Apple or 3rd party? Is it an active cable with e-marker and rated for 100 watts?
                                        • lab10.haifa
                                          Macbook Pro A2338 820-02020 Stuck on RESTORE MODE
                                          by lab10.haifa
                                          Good day, friends. Got this problem with M1 macbook - it starts, chimes, tries to boot and stuck with a message "support.apple.com/mac/restore"
                                          It works with DFU mode, but it's cannot be restored. With "revive" function - same problem. Internal restore mode doesn't work, as well as Internet Recovery.
                                          There is no damage on the motherboard. No short circuits.
                                          Could it be a NAND problem? (but usually, if NAND is dead - mac simply wouldn't turn on)
                                          Thanks....
                                          10-08-2025, 02:55 AM
                                        • Flasman90
                                          Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
                                          by Flasman90
                                          Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
                                          My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
                                          What I have done so far:
                                          - All of the routine diagnostic methods including...
                                          08-29-2025, 08:38 AM
                                        • bluestone
                                          MacBook A2289 Restore Error
                                          by bluestone
                                          Recently is seems all the A2289 boards that I am trying to revive or restore using Apple Configurator 2 gives me error -1
                                          Have anyone experienced this and how to resolve it?...
                                          05-06-2022, 11:03 AM
                                        • Woodsworth
                                          MacBook Pro A2289 no signs of life except clicking trackpad and charging
                                          by Woodsworth
                                          I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
                                          "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
                                          It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
                                          03-15-2024, 04:06 AM
                                        • modtool
                                          Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
                                          by modtool
                                          Dear friends,
                                          a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
                                          I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
                                          I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
                                          Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
                                          10-25-2025, 05:09 AM
