MacBook Pro A2289 (820-01987-A) No boot or Display, but boots to DFU and shows status bar only
  • saisoni20
    • Feb 2022
    • 117
    Hi everyone.
    Recently got MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no Caps Lock, no life except the fan is spinning. But it is able to connect to DFU mode and recognized by another MacBook. I tried to revive but the process ends when the MacBook usually should show an Apple logo with a progress bar and giving me error AMRestoreErrorDomain error 9. I don't have CPU Vcore.
    Now I can't able to connect to DFU mode either.
    On the USB meter I got 20V/0.9A power draw, and keep looping. The fan is spinning. No image (I checked with a bright flash light), no sound, no CapsLock activity. Found similar case on repair wiki: https://old.repair.wiki/w/A2289_2020_13%22_MacBook_Pro
    PP0v95_S0_CPUVCCIO_REG_R is present 0.9V.
    What should I check next? is there any power sequence for this model?
    Looking forward for your help.
  • mon2
    • 14781
    Check resistance to ground on PP2v5_NAND_SSD_0. No power during resistance checks.
    • mon2
      • 14781
      What is the voltage to ground of ppbus_g3h? Stable?
      Be sure your usb cable is of quality. We use a 40G rated one from Amazon. Short as possible.
      From Rossmann forum on this model :
      So machine is in some kind of power cycle.
      No DFU possible, if AWAKE and SLPS2R voltages are not stable.
      • saisoni20
        • Feb 2022
        • 117
        Hi mon2
        Thanks for the replay.
        I have checked PP2v5_NAND_SSD0 it's 200k.
        ppbus_g3h is 12.62V while it's turn on.
        When it try to boot and draws 1.12A at that time ppbus_g3h drop down to 10.24V.
        I am using apple original type-c cable. Still I'll order one from amazon.
        • mon2
          • 14781
          What is the power rating of your external power adapter? Suggest a 100W power delivery unit or higher for testing. Be sure that the USB Type C cable is an active cable with an e-marker else the passive USB Type C cables will not support the higher current. TBH - not sure if the Apple original cable is active Type C design or not. However, 20V @ 1.12A is ~22W so not so demanding but be sure your power adapter is original or of quality. When I was in Asia last October - saw many offering 140W and higher bricks with GAN3 semiconductors making them smaller than the last generation of adapters. Many were not CSA / cUL listed, etc. so would not trust those.
          • saisoni20
            • Feb 2022
            • 117
            Hi mon2
            Thanks for your support.
            Luckily I got another Mac and I swapped the board and it's working.
            Now I need to figure out what is causing problem to not booting into original mac assembly.
            Appreciated for you help.
            Cheers!!
            • baglaivlad
              MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
              by baglaivlad
              Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
              Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
              01-09-2024, 09:55 PM
            • Flasman90
              Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
              by Flasman90
              Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
              My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
              What I have done so far:
              - All of the routine diagnostic methods including...
              08-29-2025, 08:38 AM
            • Woodsworth
              MacBook Pro A2289 no signs of life except clicking trackpad and charging
              by Woodsworth
              I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
              "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
              It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
              03-15-2024, 04:06 AM
            • modtool
              Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
              by modtool
              Dear friends,
              a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
              I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
              I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
              Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
              10-25-2025, 05:09 AM
            • Grandoni Manuel
              MacBook a2289 water damage
              by Grandoni Manuel
              Hello to all ! I follow you but this is first time write !!
              your forum is the best !!
              so I’ve a2289 with water damage ! In first time other friend have clean and work ! But after some time stop working !
              now, I open the MacBook and I see a lot of corrosion near backlight circuit (I attach some photos about that ) I think the problem is on backlight maybe bcs do strange boot then reboot (attach video ) I change some thing on the circuit like :
              q8400
              q8401
              D8410
              and the resistor R8431
              if I check PPVIN SOSW LCDBKLT_R I’ve 12,9v
              on...
              04-03-2025, 06:45 PM
