E5500 - not functioning on AC
  • spleenharvester
    • Mar 2010
    • 903
    Schematic:
    Works fine on battery (I do not have one but the seller took a picture), does not charge or run from AC.
    There is a daughterboard with the DC jack on that does not appear in the schematic. When ACIN is read from a point on this board, it gets the full 19V. Yet when it is connected to the motherboard, this voltage falls to about 5.8v - a voltage found in quite a few places around the voltage regs.
    So clearly, the fault is on the motherboard somewhere.
    Volts tested:
    +PWRSRC: generated by BQ24275. Reads 2.45v.
    +PWR_SRC_VCHARGER: 0v
    Suspect the 5.8v is VCHGR, which supplies BQ24275.
    What could be causing this huge drop in voltage? I can't find any shorts anywhere.
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: E5500 - not functioning on AC
    Is this one of the dells that will only work and charge with a dell adapter?
    If it is and the centre pin signal is not correct I dont think it will work.
    Have you another "Proper" dell charger you can try it with.
    • spleenharvester
      • Mar 2010
      • 903
      Actually that's a good point. I've checked the center pin on that silly 8-pin jack and there is 0v. Could that be the issue?
      Also, the 5.8V is CHAGER_SRC, so at least I have something to work with on this horrid schematic.
      It's a genuine Dell adapter and very deffo working, powers my Dell X1 okay.
      • spleenharvester
        • Mar 2010
        • 903
        Wait just checked again, apparently the center pin has 13V now. Strange.
        • spleenharvester
          • Mar 2010
          • 903
          It gets weirder. Certain voltages are present - found +3.3v on both the power button and PC57, which seems to imply TPS51116 is working. When the power button is pressed, there is a "bzzzzzzz" sound on the motherboard.
          All this occurs even while that phantom 6V is there.
          Any ideas?
          • tomodachi
            • Apr 2012
            • 603
            • Turkey
            too mainstream I know but, shorted capacitor.. maybe ?
            • tomodachi
              • Apr 2012
              • 603
              • Turkey
              Or maybe a value losing component ?
              • spleenharvester
                • Mar 2010
                • 903
                Possible but I'm not entirely sure why a short would pull the adapter down to 6V. Perhaps a resistor gone wonky?
                Plus I've just realised: the fault cannot be on the PWR_SRC line because that would cause the laptop to be completely dead on both AC and battery.
                So the fault must be on either +DC_IN, +DC_IN_SS, PWR_SRC_VCHGR, or +VCHGR.
                CHAGER_SRC is connected to PWR_SRC so the fault can't be there.
                What doesn't help is I can't reliably test any FETS. According to my DMM every single 4835 on the board is open circuit. That's what I get for buying a cheap ass DT830B.
                • spleenharvester
                  • Mar 2010
                  • 903
                  Okay hang on. Is DCIN the charger or the battery? I can find both ACIN and DCIN on the schematic and I'm not sure if one of them is typo'd (this schematic is full of them) or if one of them refers to battery.
                  • spleenharvester
                    • Mar 2010
                    • 903
                    LM393 is recieving 0v even though it should be connected to DC_IN_SS. Also two of its legs read shorted, but I'm not sure which, because there's no orientation markers or anything.
                    • spleenharvester
                      • Mar 2010
                      • 903
                      PQ53 - 2N7002 appears to be faulty. Conducts only from source to drain and not source to ground (open circuit). The ones next to it are fine.
                      Could this be dragging the voltage down?
                      (edit, I remember a similar issue on a 6715s, where apparently this was normal? Suddenly not so hopeful)
                      (Note +DC_IN reads 6v, +DC_IN_SS reads about 5.5V)
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        While a MOSFET is in OFF state, Its normal to only find the forward bias drop of the body diode, 0.5 to 0.6 volts on diode test.
                        PQ52 is a digital transistor with built in base divider resistors. You will not get normal diode test readings.
                        Its is not possible for a good AC adapter to be continuously loaded to 6v, it would shut down.
                        • spleenharvester
                          • Mar 2010
                          • 903
                          The AC adapter is deffo fine, tried in two other laptops, stable reading of 19.5v.
                          Though my attention has turned back to the DC jack board. Checked again and VIN is 12~13v (it sort of briefly hits 19v and then droops back down). So it's possible the fault is actually there.
                          Though all that's really on the board is a few ceramic caps, inductors and a diode. :s
                          • spleenharvester
                            • Mar 2010
                            • 903
                            More testing. With the DC jack board plugged in, the two outermost terminals (VIN) at the back read 6v.
                            The middle pin reads -1.2v (yes, you read that right).
                            The minus sign caught my attention. Any ideas?
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              Where are you using as meter ground? Not the LAN socket?
                              Else it is an open in a ground path somewhere maybe.
                              • spleenharvester
                                • Mar 2010
                                • 903
                                Tried several places, including the USB ports and the jack's ground itself. Same readings.
                                Might try removing components from the daughterboard to try and figure out where this drop to 13v is happening.
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  Try taking measurements with the meter referenced to the outer sleeve of the AC adapter's plug if you can get a probe on to it while its plugged into the laptop.
                                  • spleenharvester
                                    • Mar 2010
                                    • 903
                                    Just tried it, same measurements unfortunately. 6V with daughter+motherboard, 13V on daughterboard only.
                                    EDIT: Wait sorry, misunderstood your comment, I'm getting 19V!
                                    • spleenharvester
                                      • Mar 2010
                                      • 903
                                      So I'm guessing there's an open ground somewhere after all?
                                      • rievax_60
                                        • May 2012
                                        • 897
                                        • australia
                                        Yes, or the socket is faulty.
                                        Will you update your profile?
                                        I like to see where other members are from.
                                        • Fernon@Repair
                                          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                          by Fernon@Repair
                                          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                          VCCIO voltage ok
                                          VCCSA Voltage OK
                                          VCCPLL Voltage OK
                                          Ram Voltage ok
                                          RamVTT OK
                                          VPP 2.5 OK
                                          But No Core Voltage
                                          and i want to this vrm ic datasheet or pinout (ISL69269)
                                          anyone have this ic pinout voltages?...
                                          06-25-2025, 07:19 AM
                                        • electron_jj
                                          Panasonic TH-L42D25A checking the PSU output voltage
                                          by electron_jj
                                          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                          08-29-2021, 08:13 AM
                                          Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                          I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                          The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                          Now...
                                          06-09-2024, 10:57 AM
                                          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                                          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                                          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                                          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                                          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                                          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                                          Based on Intersil's Robust Ripple Regulator...
                                          11-05-2024, 03:24 PM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
