E5500 - not functioning on AC
  • spleenharvester
    • Mar 2010
    • 894
    Re: E5500 - not functioning on AC
    Done
    It gets weirder. When testing from the outer sleeve of the adapter to DCIN, there's a full 19V. Almost everywhere else - the CPU caps, USB power, the whole lot - reads 13.3V. When taking readings from ground shields etc, this reading is 0v.
    Also 19-13.3 gives us the ~5.8V that was showing up everywhere earlier.
    :s
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • rievax_60
      • May 2012
      • 897
      • australia
      Originally posted by spleenharvester
      Done
      :s
      That is normal when a ground is open. leave the meter referenced to the plug sleeve. Start taking measurements at the socket's ground pins, gradually moving away from the socket. When you measure anything other than 0v, means that you have gone passed the open circuit fault.
      EDIT: second thoughts, that does sound odd.
      • rievax_60
        • May 2012
        • 897
        • australia
        Or just do continuity tests from the plug sleeve. Less risk of doing extra damage.
        • spleenharvester
          • Mar 2010
          • 894
          Okay this is getting stranger. Measuring the voltage between the PSU's outer sleeve and the jack's ground sleeve, I get ~0.07v.
          If I take a reading between the PSU's outer sleeve and DCIN, I get 19v.
          If I take a reading between the jack's ground sleeve and DCIN, I get 14v, which slowly drops to about 11.8v.
          If I then measure the voltage between the PSU's outer sleeve and the jack's ground sleeve, I get about 3.1v, which gradually drops back to 0.07v.
          All this is happening with the daughterboard only.
          So either the sleeve is faulty or a cap somewhere?
          • spleenharvester
            • Mar 2010
            • 894
            Just had an idea. Is it worth getting some wire, and connecting the ground from the motherboard to the outer sleeve of the PSU barrel, and seeing if it works?
            Since it is the ground on the board that reads 13v. Or would this damage it?
            • spleenharvester
              • Mar 2010
              • 894
              I think the problem is the DC jack. There is no continuity between the adapter sleeve and the jack's sleeve - on my Dell X1 they are connected.
              Would it be silly to just bridge the adapter with the ground sleeve to see if it works?
              • rievax_60
                • May 2012
                • 897
                • australia
                #27
                It should be ok if you connect the earth sleeve to the socket pins that you are certain are ground.
                • spleenharvester
                  • Mar 2010
                  • 894
                  Just did it, I can't get my hands to stay steady enough to see if it POSTs (I have a tremor) but we get lights and power!
                  So is this deffo the jack then and nothing else? Or is there still possibly a dodgy cap?
                  Last time I tried to replace one of these silly 8-pin jacks, I resorted to using a heatgun, and the PCB snapped before the jack came off :/
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    #29
                    A faulty socket is what everything points too. Maybe you can see the problem with it if you look inside the hole.
                    • spleenharvester
                      • Mar 2010
                      • 894
                      Just tried again, it POSTs!
                      Guess all I can do now is try a new jack. Given the two grounds don't even seem to be connected on the jack I think that's all it really can be.
                      Thanks for all your help man, it would still be a doorstop otherwise!
                      • spleenharvester
                        • Mar 2010
                        • 894
                        Eugh.
                        Replaced the jack today. Worked perfectly for a few boot cycles. Now we're back at exactly the same problem in the first place. Open ground at jack.
                        I've ordered a brand new daughterboard in the hope that may fix it.
                        • spleenharvester
                          • Mar 2010
                          • 894
                          Replaced the daughterboard entirely and it's been working fine all day so far. Really odd - I fail to see how a daughterboard can kill a jack.
                          • Fernon@Repair
                            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                            by Fernon@Repair
                            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                            VCCIO voltage ok
                            VCCSA Voltage OK
                            VCCPLL Voltage OK
                            Ram Voltage ok
                            RamVTT OK
                            VPP 2.5 OK
                            But No Core Voltage
                            and i want to this vrm ic datasheet or pinout (ISL69269)
                            anyone have this ic pinout voltages?...
                            06-25-2025, 07:19 AM
                          • electron_jj
                            Panasonic TH-L42D25A checking the PSU output voltage
                            by electron_jj
                            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                            08-29-2021, 08:13 AM
                            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                            Now...
                            06-09-2024, 10:57 AM
                            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                            Based on Intersil's Robust Ripple Regulator...
                            11-05-2024, 03:24 PM
                          • ruletero
                            Acer a515-43 low battery charge voltage
                            by ruletero
                            Hi
                            Acer A515-43
                            LA-H801P
                            Fail: Does not charge battery, has low voltaje on connector.
                            Laptop didn't want to turn on, only charge led blinked.
                            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                            10-24-2022, 02:31 PM
