Asus A6J laptop: No bootable device insert boot disc ...
  • _max_
    • Dec 2012
    • 46
    • Italy
    Hi there,
    my laptop ASUS A6J shows an interesting problem.
    After any fresh OS installation (i.e. Windows 8, Vista or Linux), it boots immediately without any problem.
    But if the laptop remains powered off for a tens of minutes, then it does not boot and shows the error:
    No bootable device. Please insert boot disc and press any key to continue...
    It sounds strange because the BIOS always reads the hard disk correctly.
    The SMART functionality also does not show any issue, as well as various HDD tools used for diagnosis (i.e. Hiren's CD, Windows check).
    I have also tried to replace the hard disk, but the problem persists.
    Thus I thought to a battery CMOS problem (since it is older than 10y), I replaced the CR2032 but the issue
    remains exactly the same: cold boot does not work, warm boot is fine (i.e. by booting from a CD/DVD).
    Now the laptop is disassembled on my lab.
    I would check defective caps or whatelse you suggest. The question is that most of the components are SMD...
    It looks a bit difficult for a noob as I am to identify defective parts, capacitors included.
    Thank you for any suggestion.
    Thanks for your help
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Asus A6J laptop: No bootable device insert boot disc ...
    It could be a symptom of a dying CR2032 battery. Especially with a 3 year old and later board.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • _max_
      • Dec 2012
      • 46
      • Italy
      As I wrote, I replaced the CR2032 battery with a new one but has not changed practically nothing...
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        First of all, google for a schematic of ASUS A6J. find your keyb. controller ic and check for cold.
        • _max_
          • Dec 2012
          • 46
          • Italy
          I had absolutely no success in looking for a6j schematic... Can someone address me to the right place, please ?
          • Francisco.s
            • 686
            • Spain
            Here you are.
            Please comment.
            • _max_
              • Dec 2012
              • 46
              • Italy
              Originally posted by Francisco.s
              Here you are.
              Please comment.
              Thank you Francisco, that's what I was looking for.
              The revision is for A6Jc, while the exact laptop model is A6JA-Q002H, I don't know if there are huge differences between models c and a.
              Can I ask where I can look for such schematic diagrams? Your answer, even in PM, would be greatly appreciated
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Have you made sure the 'new' battery is not bad? A lot of times you will get batteries (especially small watch-type ones) from the stores that are a few years old, and they are sometimes dead by then!
                (My grandparents love cheapo-batteries, so they come to me very often wanting something to be repaired, when it's just a dead 'new' battery :P)
                Muh-soggy-knee
                • _max_
                  • Dec 2012
                  • 46
                  • Italy
                  Yes, the battery is good and new.
                  After a lot of intensive MemTest86+ without any evidence of failure, the warm reboot went fine. Thus I have replaced the SoDimm module and the hard disk, and a new OS has been installed again. The first boot went fine, but unfortunately the cold boot has exactly the same issue...
                  Today I would prepare the main board for a reflow attempt ...
                  • Francisco.s
                    • 686
                    • Spain
                    I have no other schematic for that model, and I found it in a webpage, that is not working now.
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • jrodefeld
                      Asus laptop won't boot (no power) - possible bad caps?
                      by jrodefeld
                      I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                      The model:
                      Asus Zenbook Pro Duo UX582L
                      I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                      However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                      09-02-2024, 04:55 PM
                    • survivalbloke
                      Razer laptop - won't boot to bootable media - very odd
                      by survivalbloke
                      This is really weird. We got in a Razer laptop "Blade Stealth 13"
                      • Late 2019
                      • model RZ09-03100EM1
                      • product version: 2.04
                      • SN:BY2011A79600458
                      • BIOS version 1.02
                      • EC firmware v 1.01
                      • MCU firmware version 1.00.06.00
                      It came in because it was in a Windows 11 auto repair/BSoD loop. There were no dump files present on the drive which was odd. I attempted to boot into a Windows bootable USB and after selecting the USB, I would get a Windows logo and progress circle, then the system would halt and I get a BSoD. Each time the stop code is different. I have tried bootable...
                      04-11-2023, 05:37 PM
                    • acata
                      Asus X450LC REV 2.2 can't boot to anything
                      by acata
                      I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                      Power on normally. Boot to bios ok.
                      But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                      10-10-2023, 05:15 AM
                    • futadmytro
                      Asus g713qm-es94 stuck on boot bios problem
                      by futadmytro
                      sn^M4NRKD02753616E
                      MB- g533-6050a3250201-MB-A03
                      Stuck on boot after ROG logo, did not enter to bios
                      In flash bios , laprop boot but have video issue
                      orig bios...
                      06-25-2025, 08:07 AM
