Asus g713qm-es94 stuck on boot bios problem
  • futadmytro
    • Aug 2020
    • 66
    • Сполучені Штати
    sn^M4NRKD02753616E
    MB- g533-6050a3250201-MB-A03
    Stuck on boot after ROG logo, did not enter to bios
    In flash bios , laprop boot but have video issue
    orig bios
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • AquaMan Ua
    Problem with PANASONIC CF53 laptop after changing BIOS settings
    by AquaMan Ua
    Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
    05-17-2025, 09:40 AM
  • kenkaniff
    HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
    by kenkaniff
    Product Name: HP Pro x360 Fortis 11-inch G9
    System BIOS: U94 Ver.01.08.00 10/06/2023
    Serial Number: 5CG31946F5
    SKU Number: 85W05EC#AK8
    Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
    This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
    I needed to remove bios password...
    10-01-2025, 04:32 AM
