Hi, I have problem with the screen backlight, tryed to change screen cable and inverters and still no backlight. Please help!!!
HP CQ70 no Backlight
Re: HP CQ70 no Backlight
Please i need the bios of CQ70
07263-1
Vitas MB
48.4I501.011Last edited by Pascal Komlassan; 02-11-2017, 03:21 AM.Comment
Hi ,
i've the same problem with an laptop CQ70 .
I tried to change LCD panel, Inverter, LVDS cable and the same problem no backlight.
I tested if i have 3VS but no 3VS on LVDS and when i check the motherboard i seen the D21 and D22 are missing. On pad ( printed trace) of D21 and D22 on the motherboard i found 3VS but not on C364 and not on C374.
I tried to jump on motherboard the lines of D21 and D22 each separately without any result.Comment
I also had corrosion/oxidation on the... -
by frannyjunkSo I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
TIA. -
by turmixHello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
During another reassembly, I made a mistake, and...-
by FallenOne008Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself... -
by trepachkaI am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.-
Channel: Schematic Requests ONLY!
- Loading...
