HP Probook 450 G8 Boardview+Schematics - screen backlight issue
  • trepachka
    • Oct 2022
    • 457
    I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
    Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
    Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
    • 22035
    What is the motherboard model number ?
    Beginner's guidelines
    https://www.badcaps.net/forum/troubl...r-s-guidelines
    1.1.3 Motherboard model number
    • trepachka
      • Oct 2022
      • 457
      Model# DAX8QAMB8D0 REV
      • trepachka
        • Oct 2022
        • 457
        Any pointers as to where to locate the screen backlight fuse?
          • 22035
          I`ve seen it on a few of the paid sites.You`ll just have to wait for someone to post it or go and buy it
          Don`t know sorry. Post pictures of both sides of the board if you can, and a close up shot of the LVDS connector
            • 22035
            DAX8QAMB8D0 schematic & boardview
            • ScHAmPi
              Samsung UE48JU7000 screen issue after backlight replacement
              by ScHAmPi
              Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
              I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
              07-15-2024, 05:41 AM
            • HTR-Informatique
              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
              by HTR-Informatique
              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
              I also changed the screen because the PC fell and the screen was broken.
              I changed the battery with a new and original battery.
              I also had corrosion/oxidation on the...
              02-09-2025, 06:51 AM
            • Cornito
              Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
              by Cornito
              Hello Team,
              I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
              Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
              Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
              08-08-2024, 08:09 AM
            • turmix
              AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
              by turmix
              Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
              The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
              At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
              During another reassembly, I made a mistake, and...
              01-29-2024, 03:48 AM
            • Cornito
              TCL 65C715 backlight issue
              by Cornito
              Hello team,
              I'm back with another topic.
              It's a 65C715 TCL tv with backlight issue.
              But the problem is a bit strange.
              When I took this tv from the marketplace backlight didn't work but picture was ok.
              Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
              Putting all back together the tv worked fine for weeks. => Contact issue??
              Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
              06-09-2024, 02:24 AM
