Need help finding LED backlight fuse [PICS]
+ More Options
Posts
  • mattpd
    • Oct 2012
    • 301
    Re: Need help finding LED backlight fuse [PICS]
    Hello all. I had the same problem as many people here. No back light after replacing the DC jack. I almost gave up, but then I noticed that the ribbon cable from the power button to the motherboard was damaged and causing a short. I cut the very tip of the cable off (where it was damaged) and plugged it back it. Works great now!
    This laptop has had its DC power jack replaced 5+ times, so the cables eventually wore out from removing them so many times.
    • carlforum
      • Nov 2014
      • Phlippines
      #102
      I have the same problem but with other brand (Lenovo Z470)
      Please help me find the fuse for backlight
      TIA
      • carlforum
        • Nov 2014
        • Phlippines
        #103
        I have the same problem but with other brand (lenovo z470)
        Here's the pix
        TIA
        • petobongo
          • Jun 2014
          • 3
          • Portugal
          #104
          finally i found solution for Asus K53sv no backlight....!!!!!!!!!!
          applause for---------> InforEco Torres Novas---->Portugal<----
          • trebo
            • 514
            • Wales, UK
            #105
            Hello petbongo and welcome to Badcaps forum
            How about posting the solution, It would be helpful
            • Krisswe
              • Dec 2012
              • 6
              • Sweden
              #106
              Originally posted by costin_yo
              I fixed it too...you gave me the idea to check on that area with the mobo powered. I found the resistance or whatever is that, that is next to the indicated jumper. The brown thing. It was receiving 19volts but giving out only 6. I jumped it with some solder and it fixed the backlight.(I tested it first with something else for few miliseconds to see if its actually from there) I hope nothing goes wrong on the long term situation.
              Can you mark it in one of your pictures?
              • wyndone
                • Jan 2015
                Hello All,
                I am having the same issue as everyone else only on a different model. NO LED backlight on an Asus V551L laptop. I have picture just no backlight and the screen and cable have been tested on another identical unit and it works fine (picture, backlight, etc.) so it has to be something on this board. I have attached pictures of the board if you need any more, let me know. Any help that could point me in the right direction would be greatly appreciated. Thanks
                • bray
                  • Jan 2015
                  • 5
                  Hi guys, same problem here, different motherboard. It's a friend's computer, HP Pavilion G6-1D44CA, the screen was cracked and she asked me to fix it. Ordered a new screen, installed it, but lost the backlight in the process. I unplugged everything but I'm guessing the LED cable wasn't quite snug when I first tried it.
                  Hooked the old broken screen up, same thing, backlight gone. Put the new screen back on, and if you shine a bright light on it, everything is there. It's an LED so no separate inverter board.
                  Hooked it up to an external monitor via HDMI, works fine.
                  Everything points towards some kind of fuse or continuity error on the motherboard, but I can't figure out what exactly, as there are no fuses labelled. I tested continuity on a few little pieces but they all seem to work, but might have located something.
                  Found a similar thread on Tom's Hardware that had an almost identical motherboard and suggested where the issue might be but didn't really give a solution. I tested continuity on the part, it's a 3-prong resistor (I think?) with continuity from point A to B, but not B to C. Could this be the problem, and if so, can I just jump it? Thanks guys.
                  • selldoor
                    Slow Learner
                    • 7870
                    #109
                    Please can you repost your pictures using manage attachments.
                    It is not a resistor do NOT try to bridge it.
                    • bray
                      • Jan 2015
                      • 5
                      Sorry, wasn't sure how to work it. The thing marked "O" has continuity.
                      • selldoor
                        Slow Learner
                        • 7870
                        #111
                        You have not marked it but "thing" with a 0 on it is likely to be a resistor -zero rated.
                        The 3 legged component is a transistor can you read the number on it looks like 75 or 7S
                        • costin_yo
                          • Sep 2014
                          • 6
                          • Romania
                          #112
                          Sorry guys, Ive been very busy and didnt find time to post soon. A guy here asked me to post and mark the part that i bridget on the asus k53s that I repaired.
                          • bray
                            • Jan 2015
                            • 5
                            Very hard to read but with contrast turned up looks like a 75
                            • selldoor
                              Slow Learner
                              • 7870
                              #114
                              It COULD be one of these - try cleaning it gently with IPA.
                              Why do you think it is bad?
                              • bray
                                • Jan 2015
                                • 5
                                Literally no other reason than that picture posted above from TH forum. I can't see any fuses near the connector and don't have a mobo schematic so I'm completely at a loss with how to find the problem. I just looked at it again under a brighter light and managed to make out the label, A9BV with 1S sideways. No luck after wiping with IPA.
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #116
                                  Thats a few strides from "75" I have had a quick look but cant find it. Perhaps someone will chime in who knows this board, or can tell what it is from the circuit around it.
                                  Is it a very old post on the other forum - perhaps join and pm the writer.
                                  • Krisswe
                                    • Dec 2012
                                    • 6
                                    • Sweden
                                    #117
                                    Didn't work for me, but I never soldered a jumper before so maybe I didn't succeed. I will try to ask a friend if he can help me.
                                    You are supposed to solder on that side you had on the picture?
                                    • wyndone
                                      • Jan 2015
                                      Any ideas on my earlier post guys. I have gotten nowhere. I am trying to get my hands on another of the same unit so I can compare some voltages but so far no luck. Once again any help would be appreciated
                                      • briannulf
                                        • Feb 2015
                                        I have the same issue with Asus V551L. Does anyone here have any knowledge or experience with this model? I noticed Wyndon (appologies if i spelled that name wrong, cant remember the name exactly,lol) already posted pic of this laptop asking the same question. In the right lighting I can see the screen has an image just no light. I saw a video before of a narrow board in the bezel of the screen causing this. but that was not a touchscreen, so i believe this would be different.
                                        • dirtbikesmm
                                          • Jul 2015
                                          Thanks for the picture. I put a dab of solder on the thing marked with a 0 in the picture and it fixed mine. It had resistance when tested. A little tip for everybody that I learned the hard way, REMOVE battery when replacing LCD!
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                          • jshhh
                                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                            by jshhh
                                            Hi guys,
                                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                            Anybody know how to remove this type of fuse?
                                            (The fuse is toward the bottom of the image labeled F2)...
                                            06-17-2025, 01:35 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
                                          • drykid
                                            Matsui 175S microwave fuse replacement
                                            by drykid
                                            I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                                            Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                                            12-21-2020, 01:15 PM
