Warning-hp dv9000,dv9200,dv9500 "new" motherboard
  • tw2005
    • Oct 2011
    • 6458
    Probably not many people still interested in these but I wanted to share a recent bad experience.
    Beware of EBAY advertised "Sealed HP New" "2nd Generation Video Chip" "Improved" motherboards.
    I paid over $200 + international freight for a DV9000 series INTEL MB with the NVIDIA GO7600 chip and 512M of video ram.
    This was advertised as A brand-new, unused, sealed HP new, 2nd generation improved over original realease board.
    What I received was a 2006 built board including the NVIDIA video chip also 2006 model in a heat sealed anti-static bag.
    Anyone who knows this model would also know 2006 would be the very beginning of the production run for this model laptop. It was a 2006 release model.
    On top of this there was evidence of previous screwdriver impressions on the cpu locking screw and the power button LED intermittently worked.
    I queried the seller who assured me the board would not be an issue. They also had a high satisfaction rating, so I took their word.
    By the time I got around to installing this I estimate I got about 2.5- 3 months recreational use out of this and then the Video chip failed.
    I got an apology from this seller but no support.
    They are based in Connecticut, United States of America.
    This is what happens when the alarm bells ring but you still put your faith and trust in people.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Warning-hp dv9000,dv9200,dv9500 "new" motherboard
    You should have gotten a 8600. Anyway, hit it with the hot air gun and you'll get another 3 months out of it, more if you do a little case mod. I cut a hole underneath the GPU heatsink on my dv9000 and installed a small fan with thermal control. Working great since.
    A working TV? How boring!
      If you don't leave feedback on eBay, you have about 3 months to file a dispute.
      • tw2005
        • Oct 2011
        • 6458
        I've tried the oven trick and had the chip bubbling away but could only get a couple of weeks out of it. I have not been able to work out what exactly is a normal temp for the chip to run at but the best I could get was 55C usually 60-65C.
        I have seen 2009 production GO7600 chips which supposedly have different substrate material.
        • tw2005
          • Oct 2011
          • 6458
          I disputed it with the seller but he assured it would be ok but it just happens sometimes I guess. it's nice to trust people once in a while but it's hurts being let down.
          Already left positive feedback and more then 3 months now. i should have installed it straight away and used it heavily because it would have failed within the 60 day wty he gave.
          Foolish of me, the odds were stacked against resurrecting this laptop.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            If you keep it under 60 it'll work good. Also try not to drop the laptop, once reflowed the BGA is sensitive to physical shocks as well.
            How does it behave when it dies? Artifacts or just no video at all? If you've done it in the oven and it artifacts but otherwise boots up and loads windows, no BSOD and normal resolution, not 640x480, then it's the video RAM not the GPU.
            I don't know the 7600, but on the 8000 series the RAM chips are on both sides of the mobo, and it's usually the ones on the top, that go under the keyboard and have no heatsinking of any kind, that fail. You're going to need a heat gun to do those. I got creative and cut out a piece of aluminum from an old notebook HDD caddy, and applied thermal grease to it so that the RAM chips on top dissipate some heat thru the top cover and keyboard. Seems to be working fine since (2 months). Well, the GPU failed in the meantime, but that's another story... And that's quite a hack i did to its case, but it's doing a great job. https://www.badcaps.net/forum/showth...t=18907&page=3
            Also if you haven't used flux, that would explain why it failed again so quickly.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              let me ask something, how do you get flux under the chip? that area is very very tiny to get flux into
              also, your problem was you got an nvidia motherboard for a dv6/7/9 series. Those are so inherently flawed cause of this same issue. You should of looked for a dv board with an ati chip
              • mattbrad2
                • Jan 2011
                • 122
                Liquid flux using a syringe. Just a few drops is all you need. HP didn't make any dvxxxx series with ATI. This was only on the more recent dvx series and even these are only marginally better.
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  I remember at our old shop people bringing in those (usually 6000) and the boss getting this local electronics guy to replace the motherboard inside them with one that had an intel or ati chipset (that guy had TONS of boards for the dv series)
                  • lti
                    • May 2011
                    • 2549
                    Is it possible to replace the board with one that uses Intel graphics?
                    • mattbrad2
                      • Jan 2011
                      • 122
                      The DVx7xx series were Intel GMA (complete with Intel CPU and northbridge) however a few connections were different. For example, the ribbon cable for the wireless switch was different and the right most USB port has a different cable end. Also the fan/heatsink is different for obvious reasons. Given this, its still possible however you need to also replace the bottom housing and get a matching CPU/GPU heatsink and fan.
                      You do bring up an excellent point though since the Intel series of these were rock solid. This is common practice at my shop especially for the Dell D6x0 nVidia models that come in with GPU problems. I replace them with Intel discrete boards and the customer is much happier.
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Slight decrease in graphics performance is a small price to pay for a cooler, more reliable system!
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Mm, i have (or more accurately - had - as i got ripped off with a board with just 128MB VRAM) a dv9750ed, and it had the 8400M on it.
                          Uh, slight is a gross understatement. I couldn't use an intel integrated if i tried.
                          • mattbrad2
                            • Jan 2011
                            • 122
                            There were a few minor revisions that had nvidia GPU's. Same thing with the DVx5xx series. Most of those were nVidia but a few had Intel GMA. I agree with the graphics performance in games. I remember my son trying to run Minecraft on my E4300 with Intel GMA and Core2 with 8GB RAM. I told him it would play it just fine. Boy was I wrong! Most people (at least my customers) only play farmville so its all good
                            • tw2005
                              • Oct 2011
                              • 6458
                              Another conned victim posted this video recently. Beware of this seller. http://www.youtube.com/watch?v=nU36uwEKTFs
                              • 999999999
                                • Sep 2006
                                • 774
                                ^ lol, Man VS Sealed Bag.
                                Emerald is still selling the questionable boards, I wonder if those who are duped by them aren't making formal fraud complaints to ebay and if they are, who needs to be contacted that ebay is ignoring those.
                                People need to understand that HP does not send out mainboards for end users to swap, there is no source for a "new" board except to buy from HP which in small volume is no cheaper than buying from them yourself as the former option would mean both the middleman seller and ebay markup too.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  I already have and they assure me that they are investigating although I don't believe it. There's definitely a pattern developing with his feedback. I feel really stupid because I new it was not right when I got it but he's a smooth operator.
                                  I've also made the point to Ebay about the supply and availabilty of these boards in fact according to HP online they're no longer available.
                                  It's simply all
                                  The ultimate insult is the fact he charges about $100 more than anyone else for this rubbish.
                                  My main reason for posting is to get it out there that 'it's fake but just yesterday he managed to sell another DV9000 board and another victim i guess.
                                  If anything becomes of Ebay I'll be sure to post it.
                                  Here's what has been said.
                                  Hi Gerard,
                                  Thanks for writing back to eBay regarding your transaction with
                                  ‘emeraldlaptopparts'.
                                  I can certainly understand how this situation has caused you. Although
                                  our role is simply to provide a place for buyers and sellers to trade, I
                                  will contact your seller regarding this matter.
                                  With this, please keep your communication line open for any update from
                                  your seller. I'm looking forward that this matter will be resolved soon.
                                  Thanks for choosing eBay.
                                  Regards,
                                  Rey B.
                                  eBay Customer Support Team
                                  _______________________________
                                  Original Message Follows:
                                  Form Message: %43301% 031704
                                  D_ID061120120308D_ID/W_ID265670822W_ID/S_ID015S_ID/C_ID5032981230C_ID
                                  User Feedback: 130
                                  User State: ?01
                                  Browser info: Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1;
                                  Trident/5.0)
                                  Topics
                                  Message: Thanks for your response however I'm rather skeptical at the
                                  generic response you have given. It's the same blurb I've read before
                                  when I've made other reports.
                                  This seller's fraudulent items are still listed and for the record the
                                  Motherboard I purchased is no longer available from HP so this guy must
                                  be really clever since he can source new boards from HP.
                                  You may also like to view this video. http://www.youtube.com/watch?v=nU36uwEKTFs
                                  This was another Ebayer who got conned but appears got lucky and got his
                                  money back.
                                  You need to remove this guys listings as he is luring people with his
                                  high feedback % and fancy words.
                                  I have already informed emeraldlaptops of the not as described item upon
                                  receipt and also of it's subsequent failure. I have also suggested he
                                  should replace/refund or partially refund given I notified at day one
                                  the goods were not as described.
                                  Your PayPal protetion is too restrictive for these situations where you
                                  give the seller the benefit of the doubt and the item does in deed turn
                                  out to be defective outside the 45day dispute period. This guy is
                                  selling this defctive boards close to $100 more than anyone else
                                  correctly advertising there's as secondhand or refurbished.
                                  I'm $240 down the toilet on this guy, How about a little PAYPAL
                                  protetion and getting some of my money back/ i've suggested $100 to him
                                  but communications have ceased.
                                  You are providing this seller with a medium to fraudulently obtain money
                                  from good ebayers under a false pretences.
                                  Previous Message Follows
                                  Hi Gerard,
                                  Thank you for contacting eBay about a defective motherboard that you
                                  bought from emeraldlaptopparts.
                                  Gerard, please be assured that we have taken appropriate action on
                                  emeraldlaptopparts? account. We take your report seriously and we won't
                                  tolerate members with such inappropriate behavior and take action when
                                  necessary. As you may know, for privacy reasons and for legal purposes
                                  as well we are unable to provide specific information regarding the
                                  result of our investigation and also the actions that we have taken. I
                                  also hope that it assures you that your personal account history will
                                  not only remain private but constantly protected as well.
                                  Thank you for choosing eBay and have a good day ahead.
                                  Regards,
                                  Aries P.
                                  Form Message
                                  D_ID060920121958D_ID/W_ID5032926514W_ID/S_ID15S_ID
                                  User Feedback: 130
                                  User State: 01
                                  Report a My World module > MyWorld.ReportAbuse
                                  Reporting member: gerard67cars 130
                                  Reported member: emeraldlaptopparts 1012
                                  Module Reported: MyWorld.ReportAbuse
                                  Reason for report: Fraudulently listing HP DV series motherboards as
                                  "NEW, SECOND GENERATION, IMPROVED VIDEO CHIP" I purchased one of these
                                  and there is no way it was new or 2nd gen beacause the board and every
                                  component including the NVIDIA GO 7600 video chip was 2006 production.
                                  2006 was the very first year these were manufactured. There was also a
                                  screwdriver impression on the CPU mount screw.
                                  Given the class action taken against HP and NVIDIA which has determined
                                  these to be defective from the beginning and ordering compensation, this
                                  seller is therefor selling known defective items.
                                  I contacted this seller immediately but was assured this board would be
                                  ok but "it should have been " one of the newer boards. He's a conman.
                                  This board has predictably failed and just after 3 months of light use
                                  with NVIDIA video chip failure just as pretty muc every other DV series
                                  laptop with this chip.
                                  • glovecaps
                                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                    by glovecaps
                                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                    11-25-2024, 04:23 PM
                                  • Docus
                                    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                    by Docus
                                    Hi everyone 😀,
                                    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                    1. I already own the exact same model, but its plastic chassis is badly damaged.
                                    06-10-2025, 04:24 PM
                                  • Archimedes
                                    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                    by Archimedes
                                    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                    Fans are spinning. Blindly could install windows11 and got the device manager...
                                    07-30-2024, 05:14 PM
                                    ASUS P5GC-MX motherboard recap
                                    by momaka
                                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                    So here is what the motherboard looked like with its original caps:
                                    CPU VRM area up close…...
                                    01-27-2021, 11:59 PM
                                  • dragon3x
                                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                    by dragon3x
                                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                    power on.
                                    Here are some examples :
                                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                    switching supply area).
                                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                    than 6.3 V.)
                                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                    I replaced capacitors with aluminum-polymer.
                                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                    03-21-2025, 02:46 PM
