HP G62-b24ST no power, blinking light
  • tomodachi
    • Apr 2012
    • 612
    • Turkey
    I just had a G62 today with no power fail,
    As I check, when plug in adaptor, 19 volt is not stable and constantly changing on motherboard, and power led near power button is blinking, which making me think it is a short component problem, checked all mosfets and diodes on mobo and no trouble found then desoldered all jumpers of 19V in all sections to find out but no change, lately tried to take out CPU & RAM s but problem goes on,
    did anyone faced this fail before or anyone can link me schematic ?
    I m uploading 3 pictures including both sides and HP mobo part number,
    Thanks in advance,
    http://uploadpic.org/v.php?img=LUiWxo8MjK
    http://uploadpic.org/v.php?img=lHnAqHKT4U
    http://uploadpic.org/v.php?img=oTe9J3kGM3
  • mattbrad2
    • Jan 2011
    • 122
    Re: HP G62-b24ST no power, blinking light
    Constantly changing? What ranges? On the 19v rail, it's usually all or nothing. Highly unlikely something is causing it to fluctuate. This series has a horrible problem of the battery / power management IC going bad. Depending on the board, it'll be TI or ISL. Are you getting 3v from at least one of the battery charging terminals?
    • tomodachi
      • Apr 2012
      • 612
      • Turkey
      yes, I can see 3.3V on charging terminals
      • mattbrad2
        • Jan 2011
        • 122
        Then your problem is not with the 19v rail. Your 3v buck controller is doing its job however the 5v rail is probably your problem. Often these are both controlled from the same PWM. ISL, TI or Maxim. A schematic will help you locate the correct one but often times they are located near the battery terminals or at the DC jack.
        • tomodachi
          • Apr 2012
          • 612
          • Turkey
          Thanks for helping matt, I will check intensively and let you know result,
          Best regards
          • shacker
            • Dec 2012
            • Italia
            hi all,
            do you have solved?
            thanks.
            • tomodachi
              • Apr 2012
              • 612
              • Turkey
              Originally posted by shacker
              hi all,
              do you have solved?
              thanks.
              Been a long time and I m not sure if I was succeeded or failed about that mobo, sorry man.
              • jakobsen
                • May 2013
                • Denmark
                Hi
                I have a G62 b36eo - with allmost same problem.
                It works fine when on battery - But plug in AC has no effect:
                no light in dc jack - no response at all.
                I have found schematics and tryed debugging a bit.
                1. When AC pluged in, m31aacin keeps oscillating on/off
                Any common error to check around the max8731 power mm ic?
                Regards Jørgen
                copenhagen Denmark
                • loser18
                  • Nov 2013
                  • 274
                  OK...
                  Pretty similar problem HERE:
                  HP G62-107sa
                  Quanta AX1 ( DA0AX1MB6F0 )
                  Power LED light (on power connector) is OK...
                  When switch on power board light for a sec. than cut off...
                  NO fan spinning...
                  1.After inspecting the mobo found the PL11 is burnt & PR248 had some residue (assume from blown PL11)
                  2.Changed PL11 (R56D 752s) for (R56 948H6X) here I'm not sure if they're compatible...
                  3.Checked the BIOS voltages=looks OK...
                  4.Checked 2 MOSFETS around (PQ64 & PQ65)
                  5.PQ65 getting 19V on drain = IS IT NORMAL???
                  6.NO VOLTAGE ON PQ64 DRAIN = IS IT NORMAL???
                  7.Tested PU1 & pin20 (LGATE) gives me 0V
                  8.IF PU1 is bad (RT8152C) is there any alternative part as can't get this PMIC...
                  ANY HELP WOULD BE APPRECIATED!!!THX!!!
                  • leiangelo5
                    • Apr 2016
                    • Philippines
                    hi guys. can i have a copy of the schmatics an boarview for this laptop. I have the same problem. thankyou
                    • razor_amd
                      • Sep 2013
                      • 77
                      • Serbia
                      Here
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • lapfix
                        HP OMEN NO power no light
                        by lapfix
                        HP OMEN : DAG35DMBAD0
                        NO power ,no short ,no corrusion
                        Consumption : when charger plg in = 0.004 amp
                        Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                        when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                        No light at power button led
                        All coils resistances :
                        Pl 2001 =3v measured with kohm.
                        pl 2004 = 5v measured with kohm
                        pl 6001 = 49.7ohm
                        pl 4012 = vccsa = 24.4 ohm
                        pl 3001 =...
                        11-03-2025, 07:48 AM
                      • huzo
                        HP 470 G5 blinking amber light no power
                        by huzo
                        The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                        So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                        I've tried flashing the bios...
                        interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                        06-08-2023, 04:08 PM
                      • ipatch
                        troubleshooting microsoft surface pro 4 no power no led charge light
                        by ipatch
                        hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                        10-05-2023, 11:59 AM
                      • Sus256
                        HISENSE 65E7KQ PRO - no boot
                        by Sus256
                        Hi all!
                        HISENSE 65E7KQ PRO
                        RSAG7.820.13512 - chassis
                        MT9618BAATAB - cpu
                        RSAG7.820.12059 - power
                        HD650Y3U77 - panel
                        KLM8G1GETF - emmc
                        The TV does not turn on, the standby indicator is on. All voltages are present.
                        Emms is dead. Not readable, not detected.
                        Replaced emmc.
                        But with another dump there is no launch
                        Terminal log
                        UART
                        AC_ON
                        RPMB key is not yet programmed
                        HASH1_VERSION=0x00000000 64bit
                        E-B
                        FDE enabled
                        layout pattern onebin by SAR7,0...
                        06-01-2025, 02:11 AM
