ESD damage to laptop's USB ports
    Laptop: Inspiron 600m
    A couple of days ago, while trying to diagnose another PC (i.e. lots of moving a thumb drive between my laptop and the "patient"), the USB ports on my laptop stopped working. I'm almost sure the problem was due to static electricity.
    Symptoms:
    Almost any USB-powered device I connect to either port returns a "device not recognized". Self-powered devices work fine (i.e. external DVD burner). Self-powered devices work fine when connected through the docking station. I measured the power line on the USB ports and it's indeed at +5V
    I'm trying to find information about what might have been fried on the ports. Both of them stopped working at the same time, so whatever it is is shared between the two. Furthermore, it seems to fail only when the current is relatively high, so my guess is that a PTC got damaged by the ESD. However, before I start to change parts, I'd like to know if this sounds reasonable, or if there's something else in the USB circuits that would have been fried before the PTC(s).
    Opinions?
    Re: ESD damage to laptop's USB ports
    usually, double-USB ports (stacked on top of each other) share one fuse for +5V.
    at least on normal PC motherboards..
    some of them are self-resetting, some are ordinary surface mount fuses. might be semi-dead, as self-powered devices work fine..
      I have had that same issue before on a 600m. I had to reflow the southbridge to get the USBs to work again. However since they work working before you started swapping USB drives, I don't know if this is your problem. Did you remove the board from the case? you may have cracked a solder joint somewhere.
        Thank you for your answers,
        @gretti: do you mean that after a static discharge you had to reflow the southbridge?
        The mobo has been out of the case once or twice, but it was a really long time ago, so I tend to believe the problem has nothing to do with a crack or anything like that. I have read about other people who have had similar problems, who are using their peripherics with a powered hub and stuff like that. But I'm moving this laptop all the time and having an extra cord is not an option.
        @scenic: I think only *very* cheap USB devices use fuses as their main protection against discharges (it seems to be "forbidden" on the USB spec), and most probably these laptops use a self-resetting device (a PTC?). Also, if it was a fuse (it looks like sometimes there are fuses as an extra protection), there wouldn't be 5V on the USB port, right?
        So, the question remains: on these particular laptops (ok... I suspect they use a similar approach on several computers), what gets fried when there's a ESD?
          Maybe it's nothing about ESD, check the data terminals soldering, one may be cracked.
            i see the problem
            you have a the i855 chipset. you need a new mainboard. they like to randomly blow the usb... my latitude d400 did last week and i just fixed it with a new mainboard.
            sorry to have to tell you that, but thats what it likely is.
            sigpic
            (Insert witty quote here)
              Hello ratdude,
              I can't find anything about failed i855 chipsets. What are the symptoms? When these chipsets "blow" the USB, does it continue working with self-powered devices?
              If the USB ports were dead I would just assume it was something major. However, since there is 5V in the power line, and self-powered devices work fine, my guess is that whatever current-limiting device is used to protect these ports was damaged by ESD. Also, do you know if the USB ports on the docking station are driven by the laptop's chipset? Because those are working without flaw.
              Now, why my insistence it *probably* has to do with ESD: I was (and continue to be) shocked by ESD several times that day, except I was being careful to touch bare metal before handling ESD-sensitive devices (laptop & memory stick) every time I had to move around. After many hours of work (i.e tired/sleepy), I unplugged the thumb drive and had to stand up to pick up a CD (and walk on a carpet) with the thumb drive in my hand. When I plugged the thumb on the laptop it didn't work. I assumed I had fried the thumb drive but, alas, it was something else. I think it's too much of a coincidence that any mobo crack / chipset error / etc. showed up it's rear end right then and there. Of course I may be wrong, but to me this points to a ESD problem
                no, the opposite happens. you have power and overcurent monitoring but the data part dies. by blow the usb, i meqnt the usb function of the chipset goes (but anything connected is A-OK).
                symptoms:
                - NO usb function
                - controller detected in device manager (windows ) or lspci (linux via terminal)
                - 5v+ still exists on ports
                - all other devices function
                the best way to test for 5v+ would be to find something that just power will make it do something (ipod (charging), some usb mice, usb book light, etc.)
                It was mentioned in my dead usb thread:
                https://www.badcaps.net/forum/showthread.php?t=13143
                it was more of a noticed pattern be a member who has seen a LOT of laptops. what causes it is not to my knowledge but it id a chipset issue, only fixable by a trip to ebay for a new mainboard. hopefully you can get it cheaper than i did since your model has a socketed cpu (while mine is a soldered BGA).
                if you do not mind not being able to boot from usb, the other option is a usb 2.0 PCMCIA card. you should still have power from the dead ports, so the card's power cord can be plugged in. cheaper and easier, but bulkier and uglier (and non-bootable). If yours has the bluetooth module in it (iirc you model has that option), then you will not be able to use the module with this option.
                sigpic
                  sounds like the same problem the ICH5 southbridge (used on socket 478 boards with i865 and i875 chipset) used to have..
                  http://en.wikipedia.org/wiki/Intel_ICH5#ICH5
                    Thank you for the answers, people, but as I stated on the original post the USB ports *are working*. The only problem (albeit a large one) is that there doesn't seem to be enough power to drive non-self-powered devices. Again, I can use external DVD drives, external hard drives, etc, as long as those devices don't draw their power from the USB port.
                    The USB spec requires 500mA to be available at the ports; the USB-specific current-limiting devices I have seen usually cite 1.5A as the upper limit (check for instance the TI TPS2062). I don't think this ports are providing more than a few (50mA? How much a thumb drive requires?) mA. My guess is that a device like this is fried, but I can't find any mention of these things on the 600m
                      sounds like a cold/cracked solder joint in the 5v...
                      sigpic
                        Well... it looks like it as a self-resetting device after all.
                        I left the laptop disconnected and without a battery for several hours in preparation for "exploratory surgery", and after my last post I decided to open it up. I decided to try the USB port once more, though, to make sure I had the symptoms of the problem straight. Lo and behold, the USB ports have accepted everything I have thrown at them
                        Just for the record: when the problem first showed up I tried removing the battery but it didn't help. Either I didn't removed it long enough, or the ESD was still present, or -something-. Leaving the laptp for a few hours without any power source did the trick.
                        I just hope the life of the device wasn't shortened... This laptop is the one I use when I need to abuse a machine.
                        Thanks for taking the time to answer!
                          you should be fine.
                          glad it is self curing... wish my issue was... but oh well, at least I got a nicer cpu out of it.
                          sigpic
                            fate is a B****, isn't it... my rear usb port has done the exact same thing as described. the left one works, as does the internal one for the bluetooth... once i have time to leave it for a few hours w/o battery, I will try that.
                            sigpic
                              Keep in mind the amp limit on USB is 0.5 amps per port. [ 500 milliamps. ]
                              Most modern laptop hard drives exceed that.
                              Mann-Made Global Warming.
                              - Dr Seuss
                                45min wait w/o battery didn't fix it.
                                bummer
                                at least I have a hub... for mice and game controllers only (no rumble).
                                sigpic
                                  Is it possible to provide +5v to the faulty USB port and fix it?
                                  I mean USB data pins are working So If we can provide external +5v It should work (I guess so)
                                  If its not possible, please tell us why?
                                    That would probably work if you also disconnect the original power source.
                                    Bear in mind the USB power has filtering to prevent EMI from coming through the attached cable and feeding the EMI back into the motherboard's power rails. [The length of attached cable inheirently acts as an antenna.]
                                    EMI on your +5v rail won't make for a stable system.
                                    Also there is presumably some kind of over-current and surge protection to protect both the device and the motherboard.
                                    [This may simply be a fuse.]
                                    IOW: It could be done but it's not as simple as installing jumper wires.
                                    - Dr Seuss
                                      thanks for the input pcbonez. I think I should learn more about power management of USB and stuff. Actually I thought about installing jumper wires.
                                        Powered usb hub is the way to go.
                                        My pc
                                        CPU : AMD PHENOM II x4 @ 3.5Ghz
                                        MB : ASUS M4A89TD PRO USB3
                                        RAM : Kingston ValueRAM 16gb DDR3
                                        PSU : Cooler Master 850W Silent Pro
                                        GPU : ATI Radeon HD 6850
