ESD damage to laptop's USB ports
  • jarl
    • Oct 2009
    • 57
    Laptop: Inspiron 600m
    A couple of days ago, while trying to diagnose another PC (i.e. lots of moving a thumb drive between my laptop and the "patient"), the USB ports on my laptop stopped working. I'm almost sure the problem was due to static electricity.
    Symptoms:
    Almost any USB-powered device I connect to either port returns a "device not recognized". Self-powered devices work fine (i.e. external DVD burner). Self-powered devices work fine when connected through the docking station. I measured the power line on the USB ports and it's indeed at +5V
    I'm trying to find information about what might have been fried on the ports. Both of them stopped working at the same time, so whatever it is is shared between the two. Furthermore, it seems to fail only when the current is relatively high, so my guess is that a PTC got damaged by the ESD. However, before I start to change parts, I'd like to know if this sounds reasonable, or if there's something else in the USB circuits that would have been fried before the PTC(s).
    Opinions?
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: ESD damage to laptop's USB ports
    usually, double-USB ports (stacked on top of each other) share one fuse for +5V.
    at least on normal PC motherboards..
    some of them are self-resetting, some are ordinary surface mount fuses. might be semi-dead, as self-powered devices work fine..
    • gretti
      • Jan 2011
      • 28
      I have had that same issue before on a 600m. I had to reflow the southbridge to get the USBs to work again. However since they work working before you started swapping USB drives, I don't know if this is your problem. Did you remove the board from the case? you may have cracked a solder joint somewhere.
      • jarl
        • Oct 2009
        • 57
        Thank you for your answers,
        @gretti: do you mean that after a static discharge you had to reflow the southbridge?
        The mobo has been out of the case once or twice, but it was a really long time ago, so I tend to believe the problem has nothing to do with a crack or anything like that. I have read about other people who have had similar problems, who are using their peripherics with a powered hub and stuff like that. But I'm moving this laptop all the time and having an extra cord is not an option.
        @scenic: I think only *very* cheap USB devices use fuses as their main protection against discharges (it seems to be "forbidden" on the USB spec), and most probably these laptops use a self-resetting device (a PTC?). Also, if it was a fuse (it looks like sometimes there are fuses as an extra protection), there wouldn't be 5V on the USB port, right?
        So, the question remains: on these particular laptops (ok... I suspect they use a similar approach on several computers), what gets fried when there's a ESD?
        • ablacon64
          • Jan 2011
          • 89
          Maybe it's nothing about ESD, check the data terminals soldering, one may be cracked.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            i see the problem
            you have a the i855 chipset. you need a new mainboard. they like to randomly blow the usb... my latitude d400 did last week and i just fixed it with a new mainboard.
            sorry to have to tell you that, but thats what it likely is.
            sigpic
            (Insert witty quote here)
            • jarl
              • Oct 2009
              • 57
              Hello ratdude,
              I can't find anything about failed i855 chipsets. What are the symptoms? When these chipsets "blow" the USB, does it continue working with self-powered devices?
              If the USB ports were dead I would just assume it was something major. However, since there is 5V in the power line, and self-powered devices work fine, my guess is that whatever current-limiting device is used to protect these ports was damaged by ESD. Also, do you know if the USB ports on the docking station are driven by the laptop's chipset? Because those are working without flaw.
              Now, why my insistence it *probably* has to do with ESD: I was (and continue to be) shocked by ESD several times that day, except I was being careful to touch bare metal before handling ESD-sensitive devices (laptop & memory stick) every time I had to move around. After many hours of work (i.e tired/sleepy), I unplugged the thumb drive and had to stand up to pick up a CD (and walk on a carpet) with the thumb drive in my hand. When I plugged the thumb on the laptop it didn't work. I assumed I had fried the thumb drive but, alas, it was something else. I think it's too much of a coincidence that any mobo crack / chipset error / etc. showed up it's rear end right then and there. Of course I may be wrong, but to me this points to a ESD problem
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                no, the opposite happens. you have power and overcurent monitoring but the data part dies. by blow the usb, i meqnt the usb function of the chipset goes (but anything connected is A-OK).
                symptoms:
                - NO usb function
                - controller detected in device manager (windows ) or lspci (linux via terminal)
                - 5v+ still exists on ports
                - all other devices function
                the best way to test for 5v+ would be to find something that just power will make it do something (ipod (charging), some usb mice, usb book light, etc.)
                It was mentioned in my dead usb thread:
                https://www.badcaps.net/forum/showthread.php?t=13143
                it was more of a noticed pattern be a member who has seen a LOT of laptops. what causes it is not to my knowledge but it id a chipset issue, only fixable by a trip to ebay for a new mainboard. hopefully you can get it cheaper than i did since your model has a socketed cpu (while mine is a soldered BGA).
                if you do not mind not being able to boot from usb, the other option is a usb 2.0 PCMCIA card. you should still have power from the dead ports, so the card's power cord can be plugged in. cheaper and easier, but bulkier and uglier (and non-bootable). If yours has the bluetooth module in it (iirc you model has that option), then you will not be able to use the module with this option.
                sigpic
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  sounds like the same problem the ICH5 southbridge (used on socket 478 boards with i865 and i875 chipset) used to have..
                  http://en.wikipedia.org/wiki/Intel_ICH5#ICH5
                  • jarl
                    • Oct 2009
                    • 57
                    Thank you for the answers, people, but as I stated on the original post the USB ports *are working*. The only problem (albeit a large one) is that there doesn't seem to be enough power to drive non-self-powered devices. Again, I can use external DVD drives, external hard drives, etc, as long as those devices don't draw their power from the USB port.
                    The USB spec requires 500mA to be available at the ports; the USB-specific current-limiting devices I have seen usually cite 1.5A as the upper limit (check for instance the TI TPS2062). I don't think this ports are providing more than a few (50mA? How much a thumb drive requires?) mA. My guess is that a device like this is fried, but I can't find any mention of these things on the 600m
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      sounds like a cold/cracked solder joint in the 5v...
                      sigpic
                      • jarl
                        • Oct 2009
                        • 57
                        Well... it looks like it as a self-resetting device after all.
                        I left the laptop disconnected and without a battery for several hours in preparation for "exploratory surgery", and after my last post I decided to open it up. I decided to try the USB port once more, though, to make sure I had the symptoms of the problem straight. Lo and behold, the USB ports have accepted everything I have thrown at them
                        Just for the record: when the problem first showed up I tried removing the battery but it didn't help. Either I didn't removed it long enough, or the ESD was still present, or -something-. Leaving the laptp for a few hours without any power source did the trick.
                        I just hope the life of the device wasn't shortened... This laptop is the one I use when I need to abuse a machine.
                        Thanks for taking the time to answer!
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          you should be fine.
                          glad it is self curing... wish my issue was... but oh well, at least I got a nicer cpu out of it.
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            fate is a B****, isn't it... my rear usb port has done the exact same thing as described. the left one works, as does the internal one for the bluetooth... once i have time to leave it for a few hours w/o battery, I will try that.
                            sigpic
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Keep in mind the amp limit on USB is 0.5 amps per port. [ 500 milliamps. ]
                              Most modern laptop hard drives exceed that.
                              Mann-Made Global Warming.
                              - Dr Seuss
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                45min wait w/o battery didn't fix it.
                                bummer
                                at least I have a hub... for mice and game controllers only (no rumble).
                                sigpic
                                • tronxkid
                                  • Jun 2011
                                  • 20
                                  Is it possible to provide +5v to the faulty USB port and fix it?
                                  I mean USB data pins are working So If we can provide external +5v It should work (I guess so)
                                  If its not possible, please tell us why?
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    That would probably work if you also disconnect the original power source.
                                    Bear in mind the USB power has filtering to prevent EMI from coming through the attached cable and feeding the EMI back into the motherboard's power rails. [The length of attached cable inheirently acts as an antenna.]
                                    EMI on your +5v rail won't make for a stable system.
                                    Also there is presumably some kind of over-current and surge protection to protect both the device and the motherboard.
                                    [This may simply be a fuse.]
                                    IOW: It could be done but it's not as simple as installing jumper wires.
                                    - Dr Seuss
                                    • tronxkid
                                      • Jun 2011
                                      • 20
                                      thanks for the input pcbonez. I think I should learn more about power management of USB and stuff. Actually I thought about installing jumper wires.
                                      • joshnz
                                        • Feb 2011
                                        • 969
                                        • New Zealand
                                        Powered usb hub is the way to go.
                                        My pc
                                        CPU : AMD PHENOM II x4 @ 3.5Ghz
                                        MB : ASUS M4A89TD PRO USB3
                                        RAM : Kingston ValueRAM 16gb DDR3
                                        PSU : Cooler Master 850W Silent Pro
                                        GPU : ATI Radeon HD 6850
                                        • abajor
                                          A2141 minor liquid damage, U3100 TOP port dead. Periodically boots to 20V ~1A on other USBC ports
                                          by abajor
                                          Just wondering if anybody has seen this issue. I'm assuming that all of the CD3217's are semi functional for the chips to request 20V from the PSU.
                                          This unit had some soda spattered up into the side vent. I ultrasonic cleaned the board, now getting this weird sometimes requesting 20V behavior, then it goes back to 5.2V ~ 25mA The U3200 jack cycles.
                                          I'm hoping this is just an issue with some components between the TOP Jack and U3100 and not U3100 itself.
                                          Not seeing anything unusual on thermals just some of the power supply inductors getting warm when it's requesting...
                                          08-25-2025, 01:13 PM
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
                                          Toshiba Satellite L70-C-10V Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite L70-C-10V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L70-C-10V boardview and L70-C-10V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 05:30 AM
                                          Toshiba Satellite L50D-B-14D Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite L50D-B-14D Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-14D boardview and L50D-B-14D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:59 AM
                                          Toshiba Satellite L50-C-1J5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite L50-C-1J5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50-C-1J5 boardview and L50-C-1J5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
