A1466 Dead and Not turning on. Had repaired it before
  • MyronViegas
    • Aug 2022
    • 8
    • India
    Hi guys, I have an A1466 (820-00165-A) board which came in dead, had corrosion on R7181 near ISL6259 chip. I removed corrosion and replace R7181 and the macbook powered on.
    After sometime I didn't get any light on the charger but fan was spinning and I was getting battery charge logo on the screen, so I replaced the ISL6259 chip and it came on! everything was working fine.
    (NOTE: Customer had previously got the battery replaced from another shop and it was third party bad quality)
    I had used my test SSD and my known good original battery.
    When I plugged in my customers SSD and battery, The macbook came on 3-4 times, but after that it went to login screen, I typed password and the display became glitchy.
    Now, I dont get any post on the macbook but fan is spinning. It spins once, stops for a few secs and starts again. I have noted when it starts spinning for the first time All voltages are present, but when it stops and starts again there are no voltages present.
    Please help
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: A1466 Dead and Not turning on. Had repaired it before
    820-00165 or 820-3437 ?
    • MyronViegas
      • Aug 2022
      • 8
      • India
      820-00165
      • reformatt
        • Feb 2020
        • 1541
        If you are getting all voltages, including CPU Vcore, twice, then it reverts back to S5 state, this is usually CPU related. It's something I've seen on many 820-00165 boards and I'm 99.9% sure reballing the CPU would resolve it. I don't have the right gear to pull a CPU off one of these boards to prove that. But I've spent enough time on double pulse boards to rule out everything but the CPU.
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          check if ppbus_g3h is stable at 8.6 volt the whole time when it power on off and so on.
          • MyronViegas
            • Aug 2022
            • 8
            • India
            ppbus_g3h goes to 8.50 from 8.55 when it power off and on
            • Stephen
              A2338 M1 Not turning on - Repaired slightly but still having issues
              by Stephen
              Repaired a customers computer, had a faulty APL 1097 chip and replaced, all well, not shorted anymore, however I am finally getting 12.28Volts on PPBUS_AON, however it stays at 12.28 and doesn't increase to the normal 12.60 Volts. I read that this is the cause
              • If the voltage is approximately 12.28-12.35V, it may indicate a communication issue between the SOC and PMICs, or corrupt firmware.
              ​Can someone point to me what would be the next step to fix this. I can feel we are getting close to fixing this board, however this is a data recovery and we need to fix the computer to recover the data....
              02-26-2024, 02:25 PM
            • Ancient1
              I repaired a dead JBL Flip 6
              by Ancient1
              No sign of life : Disconnecting the battery reset the Firmware and solved it
              Judging by the Charger getting hot : It charged fine . Replugging it drew ~220mA for 15 seconds than 0.00 = Bat. IC negotiations.
              Key combinations didn't solve the problem
              Opened to inspect the board but it looked mint ( <2Yr old device ) , opening involves disconnection the Battery. Battery measured 4.2V .
              Decided an hour later to reconnect the Battery and check On/Off - maybe the Firmware was reset as it does in laptops ( needs V to keep the settings )
              Works fine...
              12-25-2023, 03:12 AM
            • double_DD
              How can I be sure that my EC chip is dead?
              by double_DD
              As the title suggests, how can I be sure that my EC chip is really dead?
              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
              03-12-2025, 07:47 AM
            • mcplslg123
              Macbook A1466 Dead
              by mcplslg123
              Macbook Air A1466
              Logic board:820-3437B
              Problem: It came as dead-no light at all on magsafe.
              Steps taken:On observation under microscope, Found U1900 badly corroded on pin1-2-3-4. Desoldered the Ic, cleaned the tracks and resoldered it. No corrosion anywhere else, no liquid damage. MB started,fan spinned and there was chime,I turned it off & left it on the table overnight.Next morning the mb refuses to start-magsafe remains green(not going orange) and no fan spin. Consumption fluctuating up and down from 0.008A to 0.330A on dc bench supply. Lifted U1900 again...
              04-20-2021, 08:38 AM
            • disorder
              ps5 edm-033 dead after hdmi/usb ports destroyed
              by disorder
              hello guys,
              i need help to repair a edm-033 ps2
              history : as always hdmi port and usb ports destroyed after unplugged
              after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
              so i changed it
              now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
              but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
              i don't see any projection of liquid metal on pcb.
              01-14-2025, 12:48 PM
