MacBook Pro 14" M1 Pro Issue (Works but issues)
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    No water damage, customer brought in MacBook Pro 14" A2442 M1 Pro. No water damage present, could not restore the machine but finally got it to restore after multiple attempts. Now the computer installed OS and it is activated. It now restarts and restarts every 3-10 seconds CONSTANTLY. Again no visible water damage, took the board out to inspect and still no signs of damage. Mint condition looking laptop. Computer turns on yes and has Sonoma, however JUST keeps restarting, no crash reports nothing, just KEEPS restarting every 3 seconds, sometimes it was instant back to back like 1 second to 2 seconds, then it would go up to 10 seconds than restarted again. When the computer sits for a good minute without being turned on it stays on the os longer but no longer than 1 minute. Any ideas or suggestions would be great!
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Re: MacBook Pro 14" M1 Pro Issue (Works but issues)
    Bump anyone got ideas?
    sigpic
    • oxonater
      • Oct 2012
      • 77
      • uk
      Could be the LAS putting it to sleep, had many issues with these machines try disconnecting it seeing if machine stays on does sound like a sleep/wake issue.
      Hope this helps ;@}
      OXY
      • volinakis
        • Jan 2021
        • 2875
        • N/A
        turn it off and press and hold D - it should run diagnostic.
        • UngaBungaMacbook
          • Jan 2023
          • 8
          • Eesti
          disconnect trackpad and see if it still restarts
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            Thanks wil check all of these tomorrow
            sigpic
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              Tried lid sensor, same result. Disconnects track pad, same result. Plugged up meter it gets 5Volts then sometimes turns on and hits 20Volts. The orange light disappeared and no 20Volts. Turns on at 5Volts. Then shuts off. I’m debating if the battery is faulty. But when it turns on it holds a charge and stays on off power. But still shuts down. And when it shuts off it doesn’t turn on for like 30 seconds. Then sometimes instant off when it turns on. Still same result with lid sensor connected and disconnected. I’m debating if we should order a battery replacement to see if this is the issue, since macbook batteries cause tons of issues
              sigpic
              • mon2
                • 14713
                Order the battery from Mobile Sentrix. Risk free as well and they have a proven track record.
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 674
                  Ordered will come back with my findings
                  sigpic
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 674
                    Battery came in, same issue. Turns on holds charge after about 1-2 mins dies and turns on again and again.
                    sigpic
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 674
                      usb c meters dying when plugged in. Then turning back on. Causing malfunction with meters. All ports trip the laptop to restart but no water damage and laptop turns on.
                      sigpic
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 674
                        Laptop does turn on eventually the. Does. Seems after I plugged a connection into USB c it died immediately.
                        sigpic
                        • UngaBungaMacbook
                          • Jan 2023
                          • 8
                          • Eesti
                          try swapping out ISL (U5200 if i remember correct). All power goes thru there, sounds like somekind of heat issue, it works 2-3 minutes gets hot and shuts down, when its cooled it works again.
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 674
                            That is exactly what it does. I’ll try that out with a donor board.
                            sigpic
                            • Stephen
                              Meow Meow MEOW!
                              • Apr 2020
                              • 674
                              Bump, so I am assuming there is no ISL U5200 chips online is there? I am assuming I will need a donor board
                              Because I recall ISL 9240 was a problem back then now we can get it however I am assuming same issue for these boards now?
                              sigpic
                              • Stephen
                                Meow Meow MEOW!
                                • Apr 2020
                                • 674
                                OOPS, looking at the board it indeed is an ISL 9240 LOL I can order one
                                sigpic
                                • Stephen
                                  Meow Meow MEOW!
                                  • Apr 2020
                                  • 674
                                  hmm, this board uses an ISL 9420HI which is a chip we have now it is not powering on. So I am assuming it is using a different type? looking at them now it is an ISL9240HIB3 while the other is an ISL 9240HI so these are not the same WELL DAMN
                                  Update: So it looks like the ISL 9420HI BR is the same as ISL 9240HI ? I am seeing china selling this as ISL 9240. Can someone clarify that this is correct? I will be ordered a few of these in hopes I repair this board finally
                                  sigpic
                                  • Stephen
                                    Meow Meow MEOW!
                                    • Apr 2020
                                    • 674
                                    update: replaced with a known good working ISL9240HIB3 from a donor board, board turns on now. However we are back at the same issue again, constantly turning off after about 2 mins and turning back on.It seems it gets warm enough then it turns itself off completely afterwards. So it looks like the ISL 9240HI is not the issue after all. Any updates on what is causing this issue? We have a good working donor board (Activation locked) and used the ISL for this one and it now turns on. Just trying to see where else to look to get this board to stay on and stop turning itself off.
                                    So basically the computer turns itself off instantly then turns itself on immediately and loads OS just fine then dies and repeats. This is what has been done so far
                                    New OEM battery replaced, same issue holds charge
                                    Donor ISL9240HIB3 from Working board, turns on but still continues.
                                    Checked for shorts on board but no shorts. So there is something on this board making this computer turn itself off and on, previous battery was doing this as well and new battery as well so ruled out the battery .
                                    sigpic
                                    • Stephen
                                      Meow Meow MEOW!
                                      • Apr 2020
                                      • 674
                                      Bump?
                                      sigpic
                                      • kevingill
                                        • Jun 2013
                                        • 152
                                        • England
                                        Were you able to run diagnostics? Fearing a thermal sensor has gone AWOL
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                          🛠 Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • Flasman90
                                          Macbook Pro DFU Restore Issues
                                          by Flasman90
                                          I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                          - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                          - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                          08-30-2025, 10:27 AM
                                        • pcbmaniac
                                          MacBook A1278 (3115) No PPBUS_G3H Issue
                                          by pcbmaniac
                                          Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                                          I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                                          1. U7000 Measurements:
                                            • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                                          2. Resistors:
                                            • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                                          Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                                          • If I also decide to replace the SMC, do I need to order it pre-programmed,
                                          12-02-2024, 04:12 PM
                                        • Ugur87
                                          MacBook Air M4 A3240 Brand New Water Damage no Image
                                          by Ugur87
                                          I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                                          08-28-2025, 01:09 PM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
