Macbook A1706. 820-00239-A doesn't see SSD questionmark folder
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    Re: Macbook A1706. 820-00239-A doesn't see SSD questionmark folder
    Can the same be done during repair work?
    • mon2
      • Dec 2019
      • 14672
      Visually looks ok but does not hurt to perform a quick test across each pair of pads as a confirmation.
      • PITERPENY
        • Jul 2023
        • 461
        • Ukraine
        I checked, everything is beeping. replaced U8600. did not help. everything remains the same
        • PITERPENY
          • Jul 2023
          • 461
          • Ukraine
          Do you think it's worth resoldering the SSD chip?
          • mon2
            • Dec 2019
            • 14672
            No. For now leave the ssd alone.
            Earlier wanted to link this video by Paul:
            https://youtu.be/WbuRSUitwCw?si=Qa3GSW2fGYU-mQfm
            Give it a review.
            • reformatt
              • Feb 2020
              • 1506
              Could be a dead SSD controller. The whole area is underfilled and a complete PITA to rework.
              If you are going down that route, you might want to consider the iBoff SSD upgrade kits for T1 systems. I just did one on an A1707 and it works great. Only downside is you need a 2230 or 2242 sized NVMe SSD, and it must be single sided. You get the list of SSD's he has tested as working once you purchase the kit (doesn't want to make it public as the prices of those drives would naturally go up).
              Main thing this board needs are the PCIe lanes to the PCH, reset line and 3.3V.
              https://www.tindie.com/products/ibof...for-a1706-mbp/
              • PITERPENY
                • Jul 2023
                • 461
                • Ukraine
                #27
                this is a good idea but I'm a newbie and it's still early)))
                ssd controller do you mean U8600? I replaced it. or did you mean something else? Around the U8600 and SSD chips, all voltages fluctuate and are normal.
                • PITERPENY
                  • Jul 2023
                  • 461
                  • Ukraine
                  #28
                  Give it a review.
                  what Paul says in the video, I checked the first one (PICCOLO_IUVD =1.8m as expected). I have P2V7NAND=2.7v. here something else is preventing the initialization from going through.
                  • PITERPENY
                    • Jul 2023
                    • 461
                    • Ukraine
                    #29
                    I changed the U9300 again and the result was zero.
                    • reformatt
                      • Feb 2020
                      • 1506
                      Yes. On the boards I have here, these are underfilled and are double decker with RAM on top. The one I took off the A1707 was underfilled between the RAM and controller too. So depending on where you got the replacement, you may need to reball the RAM layer.
                      The one I put the kit on, I got it off eBay as MDM locked, and the seller destroys this section by using a knife on the NAND's and controller. The beauty of this kit is that you don't need to worry too much about ripping pads or sourcing new chips. The only pads you need to worry about are the PCIe lanes to the PCH and they aren't even under any of the chips.
                      • PITERPENY
                        • Jul 2023
                        • 461
                        • Ukraine
                        #31
                        https://iboffrcc.com/pages/-guide-so...#1084;п:
                        By the way, there are step-by-step instructions, but I would still like not a simple solution, but to figure out why these components do not work, what is wrong and I will be grateful for ideas on troubleshooting
                        • PITERPENY
                          • Jul 2023
                          • 461
                          • Ukraine
                          #32
                          so let's continue the execution.
                          after the last measurements, I don’t know whether this is normal or not, but I have PP0V9_SSD_REG = 0.9V on the signal, but the resistance seems too high to me 330 ohms. 0.132V in diode mode.
                          • mon2
                            • Dec 2019
                            • 14672
                            If PP0V9_SSD_REG @ 0v9 is stable then the resistance on this rail is fine. Keep in mind that low voltage rails are often with a low resistance so 330 ohms is ok.
                            For example, CPU & GPU power rails will often be under 100 ohms to ground for their resistance.
                            • PITERPENY
                              • Jul 2023
                              • 461
                              • Ukraine
                              #34
                              Well then I'm confused. what else could be preventing the SSD from initializing?
                              • mon2
                                • Dec 2019
                                • 14672
                                What is the voltage to ground for the following?
                                PCIE_SSD_D2R_P
                                PCIE_SSD_D2R_N
                                Remove all power. Then check the above lines in DIODE mode.
                                Red meter probe to GROUND - yes ground.
                                Black meter probe to PCIE_SSD_D2R_P. What is the voltage ?
                                Then repeat with PCIE_SSD_D2R_N.
                                Checking to see if these lines are shorted or not.
                                I am assuming that the PCIe SSD is a high speed model so it will demand that both the Pair #0 and Pair #1 lines will be active to kick up the transfer speed.
                                x1 = PCIe slowest interface
                                x2 (SSD) = faster
                                x4 = faster than above
                                x16 = faster than above
                                • PITERPENY
                                  • Jul 2023
                                  • 461
                                  • Ukraine
                                  #36
                                  PCIE_SSD_D2R_P
                                  PCIE_SSD_D2R_N
                                  x2 (SSD) = faster
                                  PCIE_SSD_D2R_P=0.388V
                                  PCIE_SSD_D2R_N=0.389V
                                  no short circuit
                                  • mon2
                                    • Dec 2019
                                    • 14672
                                    In dc meter voltage mode, do you see a voltage to ground on these lines?
                                    • PITERPENY
                                      • Jul 2023
                                      • 461
                                      • Ukraine
                                      #38
                                      When the power is connected, both lines are equal to 0V.
                                      without connecting to the power supply, the power is 0.019V on both lines.
                                      • mon2
                                        • Dec 2019
                                        • 14672
                                        Confused. With no power, there should be no voltage.
                                        Can you confirm that your meter is in DC volts mode? Select the lowest voltage scale since these pins should be under 3v3 for each. Then measure again.
                                        Red probe on the pin to measure; black probe to ground. What is the voltage?
                                        • PITERPENY
                                          • Jul 2023
                                          • 461
                                          • Ukraine
                                          #40
                                          there is no voltage on these lines
                                          • Danielreinaa
                                            HELP need password bios Macbook A1706
                                            by Danielreinaa
                                            Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                            Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                            Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                            gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                            Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                            09-07-2024, 03:47 PM
                                          • capon5153
                                            Macbook A1706 works perfectly but no data on USB C
                                            by capon5153
                                            hello,
                                            so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                                            i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                                            06-22-2025, 09:42 AM
                                          • B2L_Repairs
                                            Macbook A1706 touchpad and keyboard not working. Please help
                                            by B2L_Repairs
                                            Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                            10-09-2023, 04:56 AM
                                          • obelix24
                                            A1706 - Macbook pro - one USB-C port only 20V 0A
                                            by obelix24
                                            I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                                            I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                                            There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                                            There were some broken pads under CD3215 but i've recreated them.
                                            What should be...
                                            05-22-2024, 08:04 AM
                                          • johnbeton
                                            Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
                                            by johnbeton
                                            I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
                                            Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
                                            This is what I measure so far:
                                            Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
                                            PPBUS_G3H = 0,79v
                                            PPBUS_HS_CPU = 0,79v
                                            PPBUS_HS_OTH5V = 0,79v
                                            PPBUS_HS_OTH3V3...
                                            05-21-2024, 02:06 PM
