Lenovo G510 Slow Charging Problem
  • mon2
    • Dec 2019
    • 14142
    Re: Lenovo G510 Slow Charging Problem
    Try to force enable these mosfets again.
    Ground wire to the gate pin of either mosfet. Keep the wire in pin #4 to keep the mosfets enabled.
    When you do this, what is the voltage to ground of the 2nd DCin mosfets? This is the main power rail for the laptop.
    • ay_erdi
      • Feb 2013
      • 74
      • turkey
      #62
      ground to pq301 and pq302 ping 4.
      pq302 source voltages 20V,
      drain voltages 20V.
      • mon2
        • Dec 2019
        • 14142
        This method is now powering the logic board. Power down and connect the battery.
        Does it charge when you manually enable these DCin mosfets?
        • ay_erdi
          • Feb 2013
          • 74
          • turkey
          #64
          no
          • mon2
            • Dec 2019
            • 14142
            Post more details. Any video? Any sign of life?
            • ay_erdi
              • Feb 2013
              • 74
              • turkey
              #66
              works plugged with battery everythink normal.
              I think this motherboard can not detect adapter plugged in.Because
              pq206-207-208-pq205 no voltages with plugged adapter.
              • mon2
                • Dec 2019
                • 14142
                Question was if the logic board powers up with only the power adapter with the manual enable of the DCin mosfet. No battery (for now).
                • ay_erdi
                  • Feb 2013
                  • 74
                  • turkey
                  #68
                  No powers up ,manual enable of the dc in mosfet.
                  • mon2
                    • Dec 2019
                    • 14142
                    Interesting. Remove all power.
                    Meter in resistance mode. Measure the resistance across the mosfet pins of the other mosfets mated with the charger IC.
                    Check the high / low side charger mosfets.
                    Check the battery enable mosfet.
                    Post each measurement.
                    If the battery is able to power the logic board then the power adapter with the manual bypass should also have worked.
                    • ay_erdi
                      • Feb 2013
                      • 74
                      • turkey
                      #70
                      Sorry sir,
                      Can you give details one by one?
                      • ay_erdi
                        • Feb 2013
                        • 74
                        • turkey
                        #71
                        I solved the problem because replaced again new pu301 ic.
                        But ı have new little problem.I broken the way point pin8
                        • mon2
                          • Dec 2019
                          • 14142
                          Can you clarify? Post a picture.
                          Broke pin #8 on PU301 charger IC?
                          • ay_erdi
                            • Feb 2013
                            • 74
                            • turkey
                            #73
                            Motherboard works with adapter but I plugged in battery;battery leds flash orange led.
                            • roman728
                              Lenovo E15 / NM-C421 Charging Problem
                              by roman728
                              Hello guys,
                              I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
                              02-20-2024, 03:40 AM
                            • tmks2
                              Lenovo ThinkPad T14 gen1 charging problem
                              by tmks2
                              I have a think pad t14 gen1, mainboardboard NM-C931 REV 1.0, I replaced the damaged USB-C charging socket, I still have a problem with charging only 5V. Where to look for the fault? Which electronic component is responsible for charging negotiation?
                              here is schematics an boardview
                              https://www.badcaps.net/forum/troubl...98#post1768898
                              10-29-2024, 06:41 PM
                            • Scoff
                              HP Probook 470 G4 - Power and Charging Problem
                              by Scoff
                              Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                              Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                              07-03-2023, 09:28 AM
                            • s_specialist
                              Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                              by s_specialist
                              Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                              07-07-2025, 11:47 AM
                            • perzyk23
                              Lenovo T580 - LCD Panel problem - error 0288
                              by perzyk23
                              Good morning,
                              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                              10-25-2024, 12:42 AM
