Lenovo G510 Slow Charging Problem
  • ay_erdi
    • Feb 2013
    • 74
    • turkey
    Re: Lenovo G510 Slow Charging Problem
    after remove diode,Ground of the regn pin 0,750 kohm.
    First time I fixed it.
    • mon2
      • 14837
      Power up with the adapter and measure the voltage to ground of the REGN pin on the charger IC (without the diode).
      What is the measurement?
      • ay_erdi
        • Feb 2013
        • 74
        • turkey
        0.015 v dc
        • mon2
          • 14837
          PU301 should be replaced.
          https://www.aliexpress.com/item/3289...d=Y21vfUTHioJh
          * be sure to select the BQ737 part #
          Also review the part numbers of the mosfets linked to this charger IC. They are not expensive and should be available from the same store.
          Consider to buy spares of all such parts.
          AO4407AL @ PQ312, PQ301, PQ302
          MDS1521URH @ PQ309, PQ310
          • ay_erdi
            • Feb 2013
            • 74
            • turkey
            I bought them all but estimated delivery date very late
            If these still don't work when I change them?
            • mon2
              • 14837
              Start with the charger IC replacement. The LDO on pin #6 is a simple buck regulator that is required to accept the 19v from the adapter and lower it to ~6 volts. This part is failing to do this simple voltage output.
              While waiting, perhaps consider to measure each voltage to ground reading of each pin on the charger IC again. Post the updated list.
              The REGN pin must be ~6 volts to initiate the boost circuit required to enable the DCin mosfets. The gate pins of the DCin mosfets must be:
              adapter voltage + boost voltage (REGN) = 19v + 6v = ~25v at the gate to ENABLE the power path between the power connector and the main logic board power rail.
              If the gate pin remains at 19v or lower, the 2 * DCin mosfets will remain OFF. This is the voltage you are measuring at ACN / ACP, etc., etc.
              ACDET must be > 2v4 as this is built on 2 resistors powered directly from the adapter. The resistors lower the 19v to a safe value for the charger IC.
              All other indicators look to me to be ok but yet, REGN remains at 0 volts.
              • ay_erdi
                • Feb 2013
                • 74
                • turkey
                #27
                Hi mon2
                Pu301 aftrr replacement,measurements attached.failure goes on.plug in adapter no adapter or charge led does not lit and no start with adapter.only power on battery.
                • ay_erdi
                  • Feb 2013
                  • 74
                  • turkey
                  #28
                  Should I buy a new laptop ?
                  • mon2
                    • 14837
                    Review pin #20 of the charger IC. This pin should fed by a 3 pin device which will be a dual common cathode diode.
                    One anode will be fed by the power rail supplied by the power adapter. The other anode will be fed by the battery.
                    Locate this part. Apply the power adapter only. Meter in dc volts mode (30v or higher is ok).
                    Measure the voltage to ground on each pin of this 3 pin device. The side with the 2 pins on the package will be the dual anode side.
                    In summary, the higher of the 2 power rails will power this charger IC.
                    Post the measurements of each pin. Confirm if the measurements are stable.
                    • ay_erdi
                      • Feb 2013
                      • 74
                      • turkey
                      #30
                      Are you talking about pq304,305,314?
                      • mon2
                        • 14837
                        My bad, pin #20 is fed by the first DCin mosfet via P2. Confirm this voltage is stable.
                        Confirm again the voltage to ground of REGN pin #16. This should be ~6v under these conditions.
                        If not, remove all power. Meter in resistance mode.
                        Measure the resistance to ground of the same REGN pin.
                        • mon2
                          • 14837
                          Forgot from earlier rework, the cap was removed from the REGN pin?
                          It must be placed back as the cap is required for the operation of this rail.
                          • ay_erdi
                            • Feb 2013
                            • 74
                            • turkey
                            #33
                            I already placed the cap and diode back,after the replacement pu301.
                            Regn to gnd resistance 540ohm
                            • mon2
                              • 14837
                              REGN is with a low resistance.
                              Are you confident of the soldering of the PU301 replacement?
                              • ay_erdi
                                • Feb 2013
                                • 74
                                • turkey
                                #35
                                I am waiting 6 may ,because coming new 24737 ic
                                • ay_erdi
                                  • Feb 2013
                                  • 74
                                  • turkey
                                  #36
                                  Hi ever body,
                                  I replaced new charger ic after
                                  Laptop start and works only battery.I plugged in adapter not lit charger led and dont charge battery.Does not work only plugged in adapter.
                                  What can I do?
                                  • mon2
                                    • 14837
                                    Measure the voltage to ground of:
                                    REGN
                                    ACDET
                                    ACOK
                                    VCC
                                    On the charger IC.
                                    • ay_erdi
                                      • Feb 2013
                                      • 74
                                      • turkey
                                      #38
                                      Regn 5.914V
                                      Acdet 2.905V
                                      Acok 5.889V
                                      Vcc 19.96 V
                                      • mon2
                                        • 14837
                                        Good values.
                                        What is the ACDRV voltage?
                                        • ay_erdi
                                          • Feb 2013
                                          • 74
                                          • turkey
                                          #40
                                          I can not find it,which pin is acdrv?
                                          • coasterghost
                                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                            by coasterghost
                                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                            System Hardware:
                                            Processor: AMD Ryzen 7 PRO 5850U
                                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                            09-08-2025, 10:46 PM
                                          • roman728
                                            Lenovo E15 / NM-C421 Charging Problem
                                            by roman728
                                            Hello guys,
                                            I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
                                            02-20-2024, 03:40 AM
                                          • tmks2
                                            Lenovo ThinkPad T14 gen1 charging problem
                                            by tmks2
                                            I have a think pad t14 gen1, mainboardboard NM-C931 REV 1.0, I replaced the damaged USB-C charging socket, I still have a problem with charging only 5V. Where to look for the fault? Which electronic component is responsible for charging negotiation?
                                            here is schematics an boardview
                                            https://www.badcaps.net/forum/troubl...98#post1768898
                                            10-29-2024, 06:41 PM
                                          • Scoff
                                            HP Probook 470 G4 - Power and Charging Problem
                                            by Scoff
                                            Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                            Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                            07-03-2023, 09:28 AM
                                          • ravi_1617
                                            Lenovo B540 ,Starting Problem
                                            by ravi_1617
                                            Hello !
                                            Model Lenovo B540
                                            Board Details 09244-1
                                            LA14 DIS MB
                                            48.4DMO4.01.1
                                            This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
                                            when connected CMOS dont start.
                                            3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
                                            One more thing i want to mention ( by mistake i started at...
                                            10-14-2025, 02:08 AM
