Lenovo E15 / NM-C421 Charging Problem
  • roman728
    • Jul 2018
    • 28
    • Slovakia
    Hello guys,
    I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop switch to battery power. In windows it shows PLUGGED IN, CHARGING but percentage is decreasing. I tried 2nd battery and also replaced BQ25700A and USB-C DC Jack without change. Without battery attached laptop works on charger only. Could AONY36352 be the problem or is there anything else? I am attaching schematics and boardview also.
    [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/troubl...74#post1692974
    Thanks for any ideas.
  • mon2
    • Dec 2019
    • 14839
    It is the replacement dual mosfet. The replacement part is not the same pinout as the original.
    • roman728
      • Jul 2018
      • 28
      • Slovakia
      Could you please explain where is the difference ?
      Ordered exact same mosfet, will arrive in 2-3 weeks. I will keep updated.
      • mon2
        • Dec 2019
        • 14839
        See attached. Compare the internal symbols of the dual mosfets against the schematic internal symbols. For starters, review pin # 7. On the replacement, pins 5,6,7 are tied together. This is not the same as the original.
        • roman728
          • Jul 2018
          • 28
          • Slovakia
          I ordered PQ0204, PQ0205, PQ0201 - exactly same models according schematic. They arrived today, I changed all of them but laptop behaves the same way. Any idea?
          • Sephir0th
            • Oct 2020
            • 1289
            Take a look at current sensing around the charging controller. There should be resistors present on these tracks which read low Ohms by design.
            FairRepair on YouTube
            • roman728
              • Jul 2018
              • 28
              • Slovakia
              Hello, replaced current sensing resistors. There is no change. So today i made some measurements of BQ25700A chip. Results are below.
              Laptop is working on battery only, also on charger only. With battery and adapter plugged in, system says charging but percentage is decreasing. Until now i changed PQ0204, PQ0205, PQ0201, USB-C jack, BQ25700, Current sense resistors and battery. Sometimes when i plug in charger, it will start charging for +- 10 seconds (20V@3A).
              • Sephir0th
                • Oct 2020
                • 1289
                Very odd measurements. The charging controller forces the battery to power the main power rail even if the charger present.
                I think it is time to share pictures which shows the actual physical situation on the PCB.
                • Zibbo
                  • Mar 2017
                  • 205
                  • Zimbabwe
                  Originally posted by roman728
                  Hello guys,
                  Facing exact same issue, did you ever come around to fixing this?
                  • coasterghost
                    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                    by coasterghost
                    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                    System Hardware:
                    Processor: AMD Ryzen 7 PRO 5850U
                    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                    09-08-2025, 10:46 PM
                  • nikolayu
                    Lenovo ThinkPad X1 Nano Gen 1 not charging on 1 USBC
                    by nikolayu
                    I have Lenovo ThinkPad X1 Nano Gen 1 which is not charging on 1 usbc port (the one that has mark for charging).
                    When i connect usb it switchs to 20v but no current draw (only 0.02a) and orang light is on. In windows it shows that is charging but percentage is dropping.
                    Other usbc is charging fine,
                    I installed lates bios and firmwares for thunderbolt and battery.
                    Could be faulty JHL8040R controller?
                    08-31-2024, 11:08 AM
                  • tmks2
                    Lenovo ThinkPad T14 gen1 charging problem
                    by tmks2
                    I have a think pad t14 gen1, mainboardboard NM-C931 REV 1.0, I replaced the damaged USB-C charging socket, I still have a problem with charging only 5V. Where to look for the fault? Which electronic component is responsible for charging negotiation?
                    here is schematics an boardview
                    https://www.badcaps.net/forum/troubl...98#post1768898
                    10-29-2024, 06:41 PM
                  • ay_erdi
                    Lenovo G510 Slow Charging Problem
                    by ay_erdi
                    Hi everybody,
                    I have a lenovo g510 laptop.this laptop has a slow charging problem.I check for motherboard disassembly.I checked visual inspection and I did not meet negative components.
                    At this time turn on only battery mode.Does not lit charging led and wont charging battery when attached adapter.
                    How can I do ,I need your helps.
                    04-07-2023, 03:52 PM
                  • Scoff
                    HP Probook 470 G4 - Power and Charging Problem
                    by Scoff
                    Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                    Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                    07-03-2023, 09:28 AM
