Asus X512F won't hold on battery charge
  • Kambi13
    • Aug 2022
    • 134
    • Portugal
    Hi all, need some help on this matter. Laptop works fine plugged in, battery still has 80% charge and won't go above that value, and as soon I remove power it won't hold on battery charge and turns off.
    Now on Battery + it has 8,37V, which is roughly the rating for the battery pack, but it should be higher. IC Charger is BQ24780S, BATDRV and BATSRC, both measure those 8,37V, but when I probe them they start with 11,53V and drop immediately to 8,37V.
    Checked the battery mosfets both High Side and Low Side (N-Channel) and they seem ok. Even replaced them to be sure. So my best guess is that the IC charger is faulty.
    Best regards all
  • mon2
    • Dec 2019
    • 14662
    Re: Asus X512F won't hold on battery charge
    Measure the voltage to ground on each pin of the battery connector. Specifically interested in the readings for the SCL / SDA lines which may be stuck.
    It is very possible that the battery is also defective. Have you tested with another? Consider to source another one from Amazon for testing and return it if it does not work for you. The return policy is great from Amazon.
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      Did you check the first and second mosfet. How much do you have at gate from the first and secont mosfet ( ac drive)
      • Kambi13
        • Aug 2022
        • 134
        • Portugal
        Hi mon, SCL / SCA both measure 3.24v and jumping to 3.28v, going back and forth
        BAT + 8.31V
        • Kambi13
          • Aug 2022
          • 134
          • Portugal
          Hi Steve. ACDRV has 24.43V
          • mon2
            • Dec 2019
            • 14662
            Both the SMBUS and ACDRV are good voltages.
            Suggest to carefully measure the voltage to ground of each pin on the charger IC.
            Post your list with the pin numbers for a review. Do connect your battery and power adapter.
            • Kambi13
              • Aug 2022
              • 134
              • Portugal
              Here it goes
              1 - ACN -> 19,49v
              2 - ACP -> 19,49v
              3 - CMSRC -> 19,02v
              4 - ACDRV -> 24,44v
              5 - ACOK -> 5,95v
              6 - ACDET -> 2,659v
              7 - IADP -> 6mv
              8 - IDCHG -> 4,5mv
              9 - PMON -> 4,6mv
              10 - PROCHOT -> 0v
              11 - SDA -> 3,24v
              12 - SCL -> 3,24v
              13 - CMPIN -> 255mv
              14 - CMPOUT -> 6v
              15 - BATPRESS -> 4,4mv
              16 - TB_STAT -> 9,6mv
              17 - BATSRC -> 8,31v
              18 - BATDRV -> 8,31v
              19 - SRN -> 8,31v
              20 - SRP -> 8,31v
              21 - ILIM -> 1,171v
              22 - GND
              23 - LODRV -> 18,4mv
              24 - REGN -> 6v
              25 - BTST -> 12,90v
              26 - HIDRV -> 8,33
              27 - PHASE -> 8,31
              28 - VCC -> 19,16v
              • mon2
                • Dec 2019
                • 14662
                1 - ACN -> 18,49v
                2 - ACP -> 19,49v
                Something is wrong here. This is too much of a voltage drop. Remove all power.
                Meter in the lowest resistance mode.
                One meter probe on ACN. Other meter probe on ACP.
                What is the resistance ?
                • Kambi13
                  • Aug 2022
                  • 134
                  • Portugal
                  Sorry both ACN and ACP measure 19,49v. Resistance between is 1.1 Ohms
                  • mon2
                    • Dec 2019
                    • 14662
                    Can you short your meter probes and post the measurement?
                    The 1R1 ohms sounds high for a current sense resistor. Often the current sensor resistors are 10 milli-ohms.
                    • Kambi13
                      • Aug 2022
                      • 134
                      • Portugal
                      Ok will do, post tomorrow. Thank you so much
                      • Kambi13
                        • Aug 2022
                        • 134
                        • Portugal
                        Good Morning here, back to business, so my probes shorted are at 0.00 Ohms, however as I haven't been able to find here where I live some good needle probes the reading I've taken is one probe at the leg of the IC and the other one at the nearest cap, so there could be some slight difference there.
                        • Kambi13
                          • Aug 2022
                          • 134
                          • Portugal
                          Probes shorted read 0.00 Ohms, however as I haven't been able to find here where I live some good needle probes the reading I've taken is one probe at the leg of the IC and the other one at the nearest cap, so it could be some slight difference there.
                          • Kambi13
                            • Aug 2022
                            • 134
                            • Portugal
                            Any other thoughts on this matter?
                            • mon2
                              • Dec 2019
                              • 14662
                              As we do not have the schematic, cannot be sure of the current sense resistor values being measured between ACN and ACP pins. The 1R1 reading seems too high for this component.
                              Can you check the resistance between SRN and SRP pins? Post the measurement. No power while checking the resistance. This resistor is used to monitor the current draw of the battery pack.
                              Post a close up pic of the area of the charger IC with the ACP and ACN pins. The current sense resistor should be close by.
                              • mon2
                                • Dec 2019
                                • 14662
                                Also, double check the voltage to ground of pin #3 in your posted list (cmsrc). It is too low.
                                There will be a resistor between this pin #3 and the dcin mosfets. Typically this resistor is expected to be ~4k ohms.
                                After checking the voltage, remove all power. Meter in resistance mode.
                                One meter probe to pin #3 pin of this charger IC. Other meter probe to the source pin of the DCin mosfets. Repeat with probing the drain pins. One of these checks must be a stable ~4k ohms else the resistor is likely defective.
                                • Kambi13
                                  • Aug 2022
                                  • 134
                                  • Portugal
                                  Resistance between SRP and SRN 20,04 Ohms
                                  CMRSC still 19,02V
                                  Resistance between Pin 3 (CMSRC) and the source of the DC In Mosfets - 4,02k wich is about right, between pin 3 and drain 180k on the first Mosfet and 7,72k on the second
                                  • mon2
                                    • Dec 2019
                                    • 14662
                                    This sounds really high for a current sense resistor. Remove all power.
                                    Meter in lowest resistance scale. Connect one meter probe to SRN.
                                    Other meter probe to the closest resistor you can find. We are hunting for the current sense resistor and the resistance between these 2 points should be ~0 ohms.
                                    Once it is found, continue to test the OTHER side of this resistor. Meter this time on SRP pin of the charger IC and other meter probe to the opposite side of the found resistor.
                                    Again, the resistance should be ~0 ohms.
                                    Finally, apply the meter probes directly across this found resistor. What is the resistance of this current sense resistor ? Is it still ~20 ohms ?
                                    Post a picture of the part for a review.
                                    • Kambi13
                                      • Aug 2022
                                      • 134
                                      • Portugal
                                      Hi again mon2, see the attached picture. The closest resistors to SRN and SRP are both 10 Ohms.
                                      Now if you're looking for the current sense resistor for the battery, from SRN and SRP to both sides of that 0 Ohm resistor, there's still those 10 Ohms before and after the current sense resistor
                                      • mon2
                                        • Dec 2019
                                        • 14662
                                        The resistor with R010 markings = 10 milli-ohms = 10/1000 ohms.
                                        Let me try to trace the path which may make sense if they have additional resistors in the current sense loop.
                                        Update:
                                        In reviewing other boardview files for Asus motherboards, they do indeed like to place 10 ohm resistors in series with each pin of the SRN and SRP for a total of 20 ohms extra in the current sense path.
                                        So total resistance between SRN & SRP = 10 ohms + current sense resistor (10 mOhms) + 10 ohms = ~20 ohms as you have measured. This leg appears to be ok.
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
                                        • Klevjetack
                                          Charge a L19D3PDA battery externally from the laptop
                                          by Klevjetack
                                          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                          03-05-2024, 07:26 AM
                                        • dclass-pro
                                          Latitude 3301 not charge battery
                                          by dclass-pro
                                          Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                                          I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                                          I noticed 2 things:
                                          1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                                          2) if I try to turn it on without the battery...
                                          05-06-2025, 06:19 AM
