Asus X512F won't hold on battery charge
  • mon2
    • 14000
    Re: Asus X512F won't hold on battery charge
    Remove all power. Meter in resistance mode.
    Suggest to review the mosfet resistance values to confirm if they are normal.
    Check the resistance of:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Review the high side, low side and also the battery mosfet that are linked to the charger IC.
    Post each measurement. For the battery mosfet (n-channel) to be turned ON, the BATDRV voltage should be ~6 volts higher than the BATSRC voltage.
    When the power adapter is removed, the battery mosfet gate pin should be at BATSRC voltage + 6 volts. This is the BATDRV pin on the charger IC. Confirm it.
    Given that REGN is not supplying the expected 6 volts, suspicion is on the charger IC being defective. The LDO should offer this voltage unless there is an excessive load but this will lead to the internal LDO heating up and shutting down.
    Q: If you REMOVE the battery and use only the power adapter, does REGN supply the 6 volts ? You can try the LDO without the cap for a quick test but do not believe this cap is the show stopper.
    • Kambi13
      • Aug 2022
      • 132
      • Portugal
      Right, maybe I'll try to source a new BQ chip, as it feels that this one is messed up.
      • mon2
        • 14000
        It is a good idea and they are cheap. Be sure to flux and be patient in the surgery to replace it. Low air pressure. Aliexpress will have these.
        Do check the mosfets and it does not hurt to order spares. We often order a bunch of the mosfets that surround the charger IC to cover our bases. Be prepared (GI Joe).
        • Kambi13
          • Aug 2022
          • 132
          • Portugal
          Indeed, can you provide a good vendor that you use in Alixepress. Last one I got from one vendor was crap. the ic legs were recessed and it was a pain to get it soldered, and in the end none of them worked fine.
          • Kambi13
            • Aug 2022
            • 132
            • Portugal
            Update,
            So got a brand new charger IC BQ24780s, change both the high side and low side mosfets, and also the battery one
            Just cant get BATDRV to get 6V above BATSRC. I also changed both 2 10k resistors that Asus uses at BATSRC / SRN and SRP (this last one was ok)
            The battery has 80% charge and it won't go above it, if I remove power the laptop turns off.
            Puzzling stuff
            • mon2
              • 14000
              Attach power adapter and battery.
              Carefully measure the voltage to ground of each pin on the charger IC.
              Post your readings with their pin numbers.
              • Kambi13
                • Aug 2022
                • 132
                • Portugal
                #27
                1 - ACN -> 19,37v
                2 - ACP -> 19,37v
                3 - CMSRC -> 18,91v
                4 - ACDRV -> 24,29v
                5 - ACOK -> 5,98v
                6 - ACDET -> 2,642v
                7 - IADP -> 10.1mv
                8 - IDCHG -> 9,4mv
                9 - PMON -> 6,0mv
                10 - PROCHOT -> 0v
                11 - SDA -> 3,24v
                12 - SCL -> 3,24v
                13 - CMPIN -> 252.8mv
                14 - CMPOUT -> 6.3v
                15 - BATPRESS -> 9,5mv
                16 - TB_STAT -> 9,8mv
                17 - BATSRC -> 8,31v
                18 - BATDRV -> 8,31v
                19 - SRN -> 8,31v
                20 - SRP -> 8,31v
                21 - ILIM -> 1,171v
                22 - GND
                23 - LODRV -> 0v
                24 - REGN -> 6.04v
                25 - BTST -> 14.55v
                26 - HIDRV -> 8,56
                27 - PHASE -> 8,31
                28 - VCC -> 18,99v
                • Sephir0th
                  • Oct 2020
                  • 1262
                  For me everything looked and looks in specs and the variations might be simply caused by the multimeter. Well, you can proceed dig around, or force the twist with a known good battery. It is the first thing which should have been ruled out as even stated in piernov's charging circuit guide, pinned in this forum.
                  FairRepair on YouTube
                  • Kambi13
                    • Aug 2022
                    • 132
                    • Portugal
                    #29
                    True, the fact is that the battery was working before, but I'm guessing that something is faulty in the battery itself. Maybe it's locked... I'll see if I can get a spare one.
                    • mon2
                      • 14000
                      Yes, agreed. Test with a known good battery. Perhaps you can get it from your local Amazon stores? Then return it if it is not required.
                      • Kambi13
                        • Aug 2022
                        • 132
                        • Portugal
                        #31
                        Hi all, final update on this one, and when you thought you've seen it all, something new will prove you wrong. So yesterday I had a costumer that brought an Asus laptop for a screen replacement, while working on it saw that the battery pack, although different in shape had the same connector and rating, so I thought, why not? let me try this one.
                        So I plugged it in and pressed the power button, the power led came on, and after a few seconds it started flashing white along with the battery led, nothing came up on screen, turned it off and tried again, same result, though the cpu cooler was getting warm!!! Well no good I guess, so I removed the battery and tried to plugged it with the charger alone, this time only the power led was flashing because there was no battery in of course, but what the hell!? Now it doesn't even work with the charger!!!! It used to... Was about to throw the laptop out the window but I just let it sat for a while with everything disconnected.
                        After 10 minutes tried to plug in the charger and this time it power cicled, power led light now solid white and after a few seconds it booted up, sigh of relief, it's still working
                        Turned it off again, plugged in original battery, turn on again, boots up, gets into windows and this time I'm getting info on remaining charging time until it's full... Unplugged the charger and it dind't turn off, it's holding on battery charge!!!! What the actual FU$%K, it charged to 100% after a couple of minutes. Now its fully working, even tried again the battery from the other Asus laptop and it worked perfectly.
                        So, bottom line, some neurons burnt for nothing...
                        • techfreak9356
                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                          by techfreak9356
                          09-14-2023, 11:10 PM
                        • razenxd
                          How can I charge that battery pack?
                          by razenxd
                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                          Now, I have noticed a few things.
                          The "dead" battery, while connected to charger and NOT Charging will...
                          12-05-2024, 06:11 AM
                        • ruletero
                          Acer a515-43 low battery charge voltage
                          by ruletero
                          Hi
                          Acer A515-43
                          LA-H801P
                          Fail: Does not charge battery, has low voltaje on connector.
                          Laptop didn't want to turn on, only charge led blinked.
                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                          10-24-2022, 02:31 PM
                        • Klevjetack
                          Charge a L19D3PDA battery externally from the laptop
                          by Klevjetack
                          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                          03-05-2024, 07:26 AM
                        • dclass-pro
                          Latitude 3301 not charge battery
                          by dclass-pro
                          Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                          I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                          I noticed 2 things:
                          1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                          2) if I try to turn it on without the battery...
                          05-06-2025, 06:19 AM
