Toshiba P855 only works with battery
  • mon2
    • 14662
    Re: Toshiba P855 only works with battery
    Monitor the voltage to ground of pin #6 on the charger IC with only the adapter.
    Then again with both the adapter and the battery.
    The last post shows that the voltage was lower when both power sources were attached.
    Can you confirm?
    • zioricci
      • Jan 2023
      • 125
      • Italy
      #62
      Post #5 only adapter 3.36V
      Post #15 only adapter 3.36V , only battery 0V
      Post #47 adapter + battery 2.69V.
      Now:
      only adapter 2.69 V
      adapter + battery 2.68 V
      • zioricci
        • Jan 2023
        • 125
        • Italy
        #63
        What is the signal that says, perhaps in the form of voltage, how full the battery is, is it by any chance one of the pins of the charger ic?
        It is evident that it is that signal that does not work for some hardware reason, because I also started Windows using only the fully charged battery and it never turned off.
        But there is a contradiction in that, on the one hand there is the altered signal which tells the software to inform me that the battery has almost finished charging and this, in many ways... opens a blue warning window for low battery, the led indicator blinks, the battery icon next to the clock says 0 % charge .
        The same software should shut down the laptop but it won't shut it down probably because it will get some other signal telling it there is no problem because the battery is charged.
        • mon2
          • 14662
          Try the following and confirm if the details of your battery are being detected.
          https://www.pcmag.com/how-to/how-to-...-in-windows-10
          • piernov
            • Jan 2016
            • 4439
            • France
            #65
            Battery statistics are reported by the BMS of the battery itself through SMBUS.
            • zioricci
              • Jan 2023
              • 125
              • Italy
              #66
              Yes, everything about my battery is in the report. But now I install Windows again, sometimes even an update can cause damage.
              • zioricci
                • Jan 2023
                • 125
                • Italy
                #67
                I installed Windows again and a strange thing is happening, looking at the percentage of charge, this at the end of the installation was at 5%, a value never seen ... lately it was 0%, so it seems that Windows now communicates that the battery is in charge. But I don't understand three things:
                1) the battery icon near the clock, inside it is motionless with no dynamic fill visible.
                2) Now it shows 31% and there are 5 minutes left to complete the charge, same time as in the beginning which showed 5%
                3) If I put maximum performance the brightness does not increase or even decrease if I put the maximum battery life
                • mon2
                  • 14662
                  Go to the Toshiba or whatever they are called today website and grab the full driver package for this laptop. These drivers are required to communicate with the custom hardware implanted on this logic board.
                  • zioricci
                    • Jan 2023
                    • 125
                    • Italy
                    #69
                    Toshiba was taken over by Dynabook who I had already contacted about the touchpad driver and they said support for consumer devices has been discontinued so they can't help me. All of this is business.
                    • zioricci
                      • Jan 2023
                      • 125
                      • Italy
                      #70
                      What can I say, now Windows tells me that the battery is charged, the icon on the taskbar is full, problem solved? Am I to assume that it was Windows that upset the balance? Maybe, but I think so due to several updates made after installation. I don't know, maybe I'll come back here.
                      • zioricci
                        • Jan 2023
                        • 125
                        • Italy
                        #71
                        thx
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • bykanovm
                          Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                          by bykanovm
                          Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                          If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                          If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                          even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                          Also, the laptop does not turn on without...
                          04-02-2025, 02:45 AM
                        • techfreak9356
                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                          by techfreak9356
                          09-14-2023, 11:10 PM
                        • ZixuTech
                          Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
                          by ZixuTech
                          Hi Guys, a weird case here.
                          This laptop came with damaged hinges, but no liquid signs.
                          It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
                          I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
                          I have replaced bq24780S battery charging chip, no difference.
                          With a connected new battery,...
                          04-03-2022, 04:03 AM
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
