820-2936 PP3V42 being pulled down.
  • mon2
    • 14668
    Good. What is the voltage to ground of ALL_SYS_PWRGD ?
    • bridges_4u
      • Feb 2014
      • 128
      • india
      #82
      Hi mon2
      The voltage is 3.245 V.
      Regards
      • bridges_4u
        • Feb 2014
        • 128
        • india
        #83
        Hi mon2,
        Regards​
        • mon2
          • 14668
          What is the voltage to ground of SMC_BC_ACOK ?
          • bridges_4u
            • Feb 2014
            • 128
            • india
            #85
            Hi mon2,
            The SMC_BC_ACOK is 3.251V.
            Regards
            • mon2
              • 14668
              What is the voltage to ground of SMC_BC_ACOK_VCC @ U6901 (pin 4) ?
              • bridges_4u
                • Feb 2014
                • 128
                • india
                #87
                Hi mon2
                The voltage is 3.420V.
                Regards
                • bridges_4u
                  • Feb 2014
                  • 128
                  • india
                  #88
                  [QUOTE=bridges_4u;n3258712]
                  Hi mon2
                  Regards​
                  • mon2
                    • 14668
                    What is the voltage of SMC_RESET_L​ ? Do you have a green light on the magsafe connector? What is the voltage of PPBUS_G3H ?
                    • bridges_4u
                      • Feb 2014
                      • 128
                      • india
                      #90
                      Hi mon2
                      YES. I do have the green light on the charger.
                      PPBUS_G3H : 12.40 V.
                      I shall post SMC_RESET_L voltages shortly as there has been a power outage.
                      Regards
                      • bridges_4u
                        • Feb 2014
                        • 128
                        • india
                        #91
                        Hi mon2, reformatt ,
                        Please review my findings and advise.
                        Regards
                        • mon2
                          • 14668
                          As per post #60. Should be ~12v6.
                          Flux and remove F7040 off the logic board. Do not lose it. Power up without F7040 so there is no consumer side loading on this power rail.
                          What is the voltage to ground on the ISL (producer) side of this PPBUS_G3H power rail?
                          reference:
                          [SOLVED]820-2936 ppbus_g3h 16v | Rossmanngroup Forums
                          • jshhh
                            Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
                            by jshhh
                            Hi guys,
                            I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
                            03-26-2025, 07:05 PM
                          • ktmmotocross
                            Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
                            by ktmmotocross
                            Acer 515-54G
                            DA0ZAWMB8G0
                            Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
                            i dont uderstand this. Charger ic BQ24780S
                            ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
                            What is pulling my ACDET down when i apply power even without BQ ic...
                            12-02-2022, 12:03 PM
                          • Vanillaboard
                            Hantek 6022BE USB Port pulled out
                            by Vanillaboard
                            I'm currently working on a Hantek 6022BE where the USB port and vias have been ripped off the PCB. Here are the steps I've taken so far:
                            1. Power Supply: I've tapped the power supply next to the via from the tracer.
                            2. GND: I've successfully connected the GND as well.
                            3. Data Lines: I soldered the D+ and D- lines directly to the USB controller (CY7C68013A-100AXC) at pins 17 and 18.
                            Now I'm wondering if I need pull-up resistors. According to my observation, the tracer goes directly from D+ and D- to the USB Port. Could that be right?
                            Despite these steps,...
                            09-22-2024, 06:41 AM
                          • bridges_4u
                            A1466 820-000165-A with low PP3v42
                            by bridges_4u
                            I have got an 820-000165-A motherboard which has got a strange problem. I have 14.32 V at R7005. But when i check pin2 of D7005, it says 0.9V. The diode is OK. Tried changing U7090 too. Any clues?
                            04-02-2023, 10:47 AM
                          • Sepulmac
                            820-3476-A Pulled resistor R8312
                            by Sepulmac
                            Hello everybody.
                            First comment that I am a computer technician, not an electronics specialist, but I do like it.
                            I tell you, by accident I have pulled the resistor R8312 and the GND pad of a motherboard 820-3476-A, the line is called DP_INT_ML_N <0> and it goes to pin 15 of the J8300 connector.
                            The screen works and I don't know if it can be without that resistance. I guess not, but ... is it possible?
                            Thank you.
                            04-13-2021, 03:38 AM
