820-2936 PP3V42 being pulled down.
  • bridges_4u
    • Feb 2014
    • 128
    • india
    #41
    Re: 820-2936 PP3V42 being pulled down.
    Originally posted by mon2
    At 16k ohms, the reading very low. Suggest to replace this mosfet.
    Continue to check other mosfets as well in this area.
    Hi mon2,
    I removed the mosfet Q7030. Resistance between source and gate is showing O.L. But when I check the resistance between the source and gate pads, it is showing 15.1k Ohm.
    The remainder of the resistance to ground on Q7030 are as follows :
    Resistance between Source and Drain is 5.11 M ohms.
    Resistance between Gate and Drain is O.L.
    Resistance on the other pads of Q7030 on mobo are
    Resistance between Source and Drain is 8 M Ohms.
    Resistance between Gate and Drain is 7.8 M Ohms.
    • bridges_4u
      • Feb 2014
      • 128
      • india
      #42
      Hi mon2,
      Out of curiosity, could you please help me with the correct procedure to check a mosfet and what readings to expect? I am learning a lot from you. Kudos to you.
      • mon2
        • 14668
        Sure, see here:
        https://electronicsbeliever.com/how-...-is-defective/
        Prefer the table with the resistance check method.
        In general a normal mosfet will be with HIGH resistance values of hundreds of Kohms or more.
        It is possible that other parts interconnected with the mosfet are causing the mosfet to appear to be shorted. For this reason, a good sanity check is to remove the mosfet off the board -> allow it to discharge (you can short the pins with a wire - so source & drain; source & gate for example) -> then check again on your work table.
        At ~15kohms, the resistance is considered to be too low and likely to be defective. Reverse the meter probes and check again to see if the readings change but would suggest to replace this mosfet.
        • bridges_4u
          • Feb 2014
          • 128
          • india
          #44
          Hi mon2,
          I think I confused you. The 15.1 Kohms resistance did not come from the mosfet but from the pad on the mobo where it was installed. The reading came by checking the pad on the mobo after removing the mosfet.
          • bridges_4u
            • Feb 2014
            • 128
            • india
            #45
            The resistance between source and gate on Q7030 is showing O.L.
            • mon2
              • 14668
              Yes, thanks for the clarification. Continue to check the other combination of pins on this removed mosfet on your work table.
              source & drain
              source & gate
              gate & drain
              If each is with a high resistance reading then this mosfet is ok.
              • bridges_4u
                • Feb 2014
                • 128
                • india
                #47
                Hi mon2,
                • mon2
                  • 14668
                  This mosfet is fine and not shorted.
                  Continue to check the low side and also the battery mosfet using the same procedure.
                  • bridges_4u
                    • Feb 2014
                    • 128
                    • india
                    #49
                    Hi mon2,
                    Readings after removing and checking Q7035
                    • mon2
                      • 14668
                      Q7035 is ok.
                      • bridges_4u
                        • Feb 2014
                        • 128
                        • india
                        #51
                        Hi mon2,
                        would you like me to remove Q7055 and check it as well.?
                        • mon2
                          • 14668
                          Remove all power and test the resistance while onboard first. Same as earlier.
                          • bridges_4u
                            • Feb 2014
                            • 128
                            • india
                            #53
                            Here are the readings from Q7055.
                            Resistance between Source and Drain is O.L.
                            Resistance between source and gate is showing 16.43 M Ohms.
                            • mon2
                              • 14668
                              This mosfet is not shorted.
                              • bridges_4u
                                • Feb 2014
                                • 128
                                • india
                                #55
                                So I think it is safe to say that ISL6259 could be the culprit.
                                • mon2
                                  • 14668
                                  Yes, it is looking that way. Has this part been replaced already? If yes, reflow it with flux. If not, replace it and test again. Still keep the fuse at the output off the logic board till the PPBUS_G3H is confirmed to be within range.
                                  • bridges_4u
                                    • Feb 2014
                                    • 128
                                    • india
                                    #57
                                    Hi mon2,
                                    I have already ordered the ISL6259 and is in transit. It leads me to think that the batch of ISL 6259 i had is from a bad batch as all of them has not yielded any results across different boards.
                                    • mon2
                                      • 14668
                                      That is sad to hear and the parts may be fake but of course continue with the review and update this thread. From the videos by Louis, he said these parts break often on the logic board. You can try to flux and reflow the part as well. Be sure that pin #1 orientation is correct.
                                      Perhaps you can post a close up picture of this part on your board for a review?
                                      • bridges_4u
                                        • Feb 2014
                                        • 128
                                        • india
                                        #59
                                        Hi mon2,
                                        mon2
                                        Just wanted to give you an update on this as well. Now I have 3.420 volts at pp3v42_g3h and ppbus_g3h is now 12.45volts.
                                        Any suggestions?
                                        Regards
                                        • mon2
                                          • 14668
                                          PPBUS_G3H is too low and should be 12v6. This is controlled through SMC over the I2C bus. Confirm the voltage to ground of the SDA / SCL lines that mate with the ISL chip that is building the PPBUS_G3H rail.
                                          820-2936 with 12,23V on ppbus_g3h | Rossmanngroup Forums
                                          • jshhh
                                            Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
                                            by jshhh
                                            Hi guys,
                                            I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
                                            03-26-2025, 07:05 PM
                                          • ktmmotocross
                                            Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
                                            by ktmmotocross
                                            Acer 515-54G
                                            DA0ZAWMB8G0
                                            Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
                                            i dont uderstand this. Charger ic BQ24780S
                                            ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
                                            What is pulling my ACDET down when i apply power even without BQ ic...
                                            12-02-2022, 12:03 PM
                                          • Vanillaboard
                                            Hantek 6022BE USB Port pulled out
                                            by Vanillaboard
                                            I'm currently working on a Hantek 6022BE where the USB port and vias have been ripped off the PCB. Here are the steps I've taken so far:
                                            1. Power Supply: I've tapped the power supply next to the via from the tracer.
                                            2. GND: I've successfully connected the GND as well.
                                            3. Data Lines: I soldered the D+ and D- lines directly to the USB controller (CY7C68013A-100AXC) at pins 17 and 18.
                                            Now I'm wondering if I need pull-up resistors. According to my observation, the tracer goes directly from D+ and D- to the USB Port. Could that be right?
                                            Despite these steps,...
                                            09-22-2024, 06:41 AM
                                          • bridges_4u
                                            A1466 820-000165-A with low PP3v42
                                            by bridges_4u
                                            I have got an 820-000165-A motherboard which has got a strange problem. I have 14.32 V at R7005. But when i check pin2 of D7005, it says 0.9V. The diode is OK. Tried changing U7090 too. Any clues?
                                            04-02-2023, 10:47 AM
                                          • Sepulmac
                                            820-3476-A Pulled resistor R8312
                                            by Sepulmac
                                            Hello everybody.
                                            First comment that I am a computer technician, not an electronics specialist, but I do like it.
                                            I tell you, by accident I have pulled the resistor R8312 and the GND pad of a motherboard 820-3476-A, the line is called DP_INT_ML_N <0> and it goes to pin 15 of the J8300 connector.
                                            The screen works and I don't know if it can be without that resistance. I guess not, but ... is it possible?
                                            Thank you.
                                            04-13-2021, 03:38 AM
