820-2936 PP3V42 being pulled down.
  • bridges_4u
    • Feb 2014
    • 128
    • india
    #61
    Hi mon2,
    Sure. I will post those voltages within the next few hours.
    Regards
    • bridges_4u
      • Feb 2014
      • 128
      • india
      #62
      mon2
      The SMC_BC_ACOK was at 3.125V. Reballed the SMC. The SDA & SCL voltages are at 3.3V. The SMC_BC_ACOK is 3.251V. PPBUS is at 12.45V.
      ISL?????
      Regards
      • bridges_4u
        • Feb 2014
        • 128
        • india
        #63
        Hi mon2
        C7523, C7513 & C7554 appears to a verge of rupture. Will that affect the situation that we have here? I don't think so.
        Just wanted to know your expert opinion.
        Regards
        • mon2
          • 14668
          Any component in bad shape is a suspect. Remove all power. Measure the resistance to ground of these parts that are of concern. These 3 caps are linked to the CPU core. Hope that a high side mosfet is not leaky which will result in a damaged CPU. If possible, replace these caps from a donor board.
          • bridges_4u
            • Feb 2014
            • 128
            • india
            #65
            Hi mon2,
            I do not have any donor boards laying around. I shall order those caps tomorrow. What do you think about the voltages posted above the post talking about the caps?
            Regards
            • bridges_4u
              • Feb 2014
              • 128
              • india
              #66
              Originally posted by bridges_4u
              mon2
              ISL?????
              Regards
              mon2 What do u think about this?
              • mon2
                • 14668
                SMC_BC_ACOK should be 3v42 (PP3V42_G3H) to match the pull-up voltage used @ R5087. Remove all power. Meter in resistance mode. Measure the resistance of R5087. Is it ~470k ohms ?
                Next confirm that the pull-up voltage is ~3v42 (PP3V42_G3H) to ground on R5087. This same voltage is created @ L6995, pin # 2. Confirm this voltage to ground.
                Update - Also share the voltage to ground of PM_BATLOW_L. If this signal is LOW (0v) then the power adapter is not suitable. Test with another; use the original.
                • bridges_4u
                  • Feb 2014
                  • 128
                  • india
                  #68
                  Hi mon2,
                  SMC_BC_ACOK is 3.125V. The resistance of R5087 is 470K Ohms. PP3V42 is 3.420V. I will share the voltage of PM_BATLOW_L shortly.
                  Regards
                  • bridges_4u
                    • Feb 2014
                    • 128
                    • india
                    #69
                    Hi mon2,
                    Will it be good idea if we jump PP3v42 to the SM_BC_ACOK line coming from the ISL6259?
                    Regards
                    • mon2
                      • 14668
                      No, do not jump anything. The voltage on this power good line is considered to be OK but in this state, this line is supposed to be floating or high impedance (hi-z). Then the pull-up resistor @ R5087 is used to define the parked logic state and really should be 3v42.
                      What is the resistance to ground of SMC_BC_ACOK ? No power during these resistance checks.
                      • bridges_4u
                        • Feb 2014
                        • 128
                        • india
                        #71
                        Hi mon2,
                        The resistance of SM_BC_ACOK is 100.1 K Ohms.
                        • bridges_4u
                          • Feb 2014
                          • 128
                          • india
                          #72
                          Hi mon2,
                          Diode readings for R5280 & R5281 are 0.243 & 0.244V respectively.​
                          • mon2
                            • 14668
                            These are good measurements. What is the voltage to ground of PM_BATLOW_L?
                            • bridges_4u
                              • Feb 2014
                              • 128
                              • india
                              #74
                              mon2 The voltage is 3.245V.
                              • mon2
                                • 14668
                                What is the exact resistance of R7000? Measure across this part with no power.
                                • bridges_4u
                                  • Feb 2014
                                  • 128
                                  • india
                                  #76
                                  Hi mon2,
                                  The resistance of R7000 is 1.2Ohms whilst on the board, connected.
                                  Regards
                                  • mon2
                                    • 14668
                                    Short your meter probes. What is the resistance measurement?
                                    • bridges_4u
                                      • Feb 2014
                                      • 128
                                      • india
                                      #78
                                      Hi mon2,
                                      In resistance mode, the probes read 1.0 Ohms. Are my probes bad? I am using a Fluke 101.
                                      • mon2
                                        • 14668
                                        Probes are ok. What is the voltage to ground of PM_SLP_S4_L ?
                                        • bridges_4u
                                          • Feb 2014
                                          • 128
                                          • india
                                          #80
                                          mon2
                                          The voltage is 3.258V
                                          • jshhh
                                            Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
                                            by jshhh
                                            Hi guys,
                                            I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
                                            03-26-2025, 07:05 PM
                                          • ktmmotocross
                                            Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
                                            by ktmmotocross
                                            Acer 515-54G
                                            DA0ZAWMB8G0
                                            Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
                                            i dont uderstand this. Charger ic BQ24780S
                                            ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
                                            What is pulling my ACDET down when i apply power even without BQ ic...
                                            12-02-2022, 12:03 PM
                                          • Vanillaboard
                                            Hantek 6022BE USB Port pulled out
                                            by Vanillaboard
                                            I'm currently working on a Hantek 6022BE where the USB port and vias have been ripped off the PCB. Here are the steps I've taken so far:
                                            1. Power Supply: I've tapped the power supply next to the via from the tracer.
                                            2. GND: I've successfully connected the GND as well.
                                            3. Data Lines: I soldered the D+ and D- lines directly to the USB controller (CY7C68013A-100AXC) at pins 17 and 18.
                                            Now I'm wondering if I need pull-up resistors. According to my observation, the tracer goes directly from D+ and D- to the USB Port. Could that be right?
                                            Despite these steps,...
                                            09-22-2024, 06:41 AM
                                          • bridges_4u
                                            A1466 820-000165-A with low PP3v42
                                            by bridges_4u
                                            I have got an 820-000165-A motherboard which has got a strange problem. I have 14.32 V at R7005. But when i check pin2 of D7005, it says 0.9V. The diode is OK. Tried changing U7090 too. Any clues?
                                            04-02-2023, 10:47 AM
                                          • Sepulmac
                                            820-3476-A Pulled resistor R8312
                                            by Sepulmac
                                            Hello everybody.
                                            First comment that I am a computer technician, not an electronics specialist, but I do like it.
                                            I tell you, by accident I have pulled the resistor R8312 and the GND pad of a motherboard 820-3476-A, the line is called DP_INT_ML_N <0> and it goes to pin 15 of the J8300 connector.
                                            The screen works and I don't know if it can be without that resistance. I guess not, but ... is it possible?
                                            Thank you.
                                            04-13-2021, 03:38 AM
