820-2936 PP3V42 being pulled down.
  • bridges_4u
    • Feb 2014
    • 128
    • india
    Re: 820-2936 PP3V42 being pulled down.
    Hi Mon2,
    The parts are yet to arrive. But something happened. I reballed the SMC, plugged in the charger and now I have a green light. But PPBUS_G3H is still 1.09v.
    • mon2
      • 14668
      Remove the fuse on ppbus_g3h.
      Power up again. Check the voltage to ground of ppbus_g3h at the isl side.
      What is the voltage reading?
      • bridges_4u
        • Feb 2014
        • 128
        • india
        Hi mon2,
        The diode mode reading to gnd is 0.431v.
        • mon2
          • 14668
          No, not the diode mode reading but actual voltage reading.
          Remove all power.
          Meter in DC volts scale.
          Attach the power adapter -> measure the voltage to ground of PPBUS_G3H on the ISL side. Measure on the removed fuse PCB pad.
          Do you now see a proper voltage without the fuse?
          • bridges_4u
            • Feb 2014
            • 128
            • india
            Aaah.Its still 1.019V. Is ISL6259 (u7000) to blame for?
            • mon2
              • 14668
              Confirm the resistance to ground of this same pin - with no power to the board.
              After this test, yes, suggest that you replace the ISL component and test again - without the fuse to confirm the PPBUS_G3H is within a valid range.
              Then add the fuse back and continue to test.
              Update - do also test the switching mosfets that are linked to this power rail.
              Do this with resistance checks - with no power.
              • bridges_4u
                • Feb 2014
                • 128
                • india
                #27
                I think SMC is functioning due to the green light and the SMC_ONOFF_L is up now. But PPBUS_G3H is still 1.019V.
                • mon2
                  • 14668
                  Check the voltage to ground of Q7030, DRAIN pin. This is the high side mosfet and should be with a higher voltage = adapter voltage.
                  That is, Q7030 and Q7035 work together to create the PPBUS_G3H rail. If either is defective, the voltage will be low. The ISL is the driver for each of these mosfets.
                  Confirm the resistance of each mosfet - with no power:
                  source & drain
                  source & gate
                  gate & drain
                  Check for a low resistance. If the resistance is low, the mosfet could be defective. If the mosfets are fine, the ISL is a key suspect.
                  • bridges_4u
                    • Feb 2014
                    • 128
                    • india
                    #29
                    Hi mon2,
                    I have already ordered ISL6259 and is yet to arrive. It should reach me within the next 2 - 3 days. In the meantime, I shall post the resistance at the high side mosfet.
                    • bridges_4u
                      • Feb 2014
                      • 128
                      • india
                      #30
                      OK.
                      The voltage to ground of Q7030 on the drain pin is 1.019V.
                      Resistance from Source to Drain (Q7030) - Around 5.8 MOhms
                      Resistance from Source to Gate (Q7030) - Around 6.4 Ohms
                      Resistance from Gate to Drain (Q7030) - Around 5 MOhms
                      Resistance from Source to Drain (Q7035) - Around 17.5 KOhms
                      Resistance from Source to Gate (Q7035) - Around 5.16 KOhms
                      Resistance from Gate to Drain (Q7035) - Around 4 MOhms
                      • bridges_4u
                        • Feb 2014
                        • 128
                        • india
                        #31
                        Hi mon2,
                        The results are above. Please advise.
                        • mon2
                          • 14668
                          Is this 6R4 ohms or should it be 6.4 Mohms?
                          • mon2
                            • 14668
                            From post #21
                            The voltage to ground for PPBUS_G3H is this low @ 1.09v ?
                            If yes, remove the fuse on this rail @ F7040.
                            Measure the voltage to ground @ F7040 pad # 1.
                            Do you still see this low voltage?
                            • bridges_4u
                              • Feb 2014
                              • 128
                              • india
                              #34
                              Originally posted by mon2
                              From post #21
                              Hi mon2,
                              Yes. It is still 1.09V on F7040, pad 1.
                              • mon2
                                • 14668
                                Originally at the start of this thread, the ppbus_g3h voltage was higher - right?
                                Need to check what was reworked.
                                Check the voltage to ground of the i2c lines - SCL and SDA on the isl regulator linked to this power rail.
                                Also check the mosfet details from post #32. Remove all power on checking resistance.
                                If the isl was replaced, flux and reflow it. Low air pressure.
                                • bridges_4u
                                  • Feb 2014
                                  • 128
                                  • india
                                  #36
                                  Hi mon2,
                                  I will check the voltage of the i2c lines and post it later on today. It is very strange as you said. But there was no green light at all during the start. Now we have it and the PP3V42 has come up and looks like SMC is functioning now, atleast partially.
                                  • bridges_4u
                                    • Feb 2014
                                    • 128
                                    • india
                                    #37
                                    Hi mon2,
                                    The voltage to ground on R5280 & R5281 is 3.420V. The resistance between source and gate on Q7030 is 6.4 Ohms.
                                    • mon2
                                      • 14668
                                      With such a low resistance reading, q7030 looks to be shorted. Carefully remove this part and confirm the resistance when the mosfet is on your work table.
                                      The reading should be hundreds of Kohms or higher.
                                      Be sure your meter scale is correct or is it autoranging?
                                      Perhaps you can post a picture of the front face of your meter while taking this measurement as a final check?
                                      • bridges_4u
                                        • Feb 2014
                                        • 128
                                        • india
                                        #39
                                        Hi mon2,
                                        I did check Q7030 after removing it. The resistance between source and gate on Q7030 is 16.19kOhms. I reinserted the mosfet again and the reading is the same. Might have been a dry joint/soldering.
                                        • mon2
                                          • 14668
                                          At 16k ohms, the reading very low. Suggest to replace this mosfet.
                                          Continue to check other mosfets as well in this area.
                                          • jshhh
                                            Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
                                            by jshhh
                                            Hi guys,
                                            I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
                                            03-26-2025, 07:05 PM
                                          • ktmmotocross
                                            Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
                                            by ktmmotocross
                                            Acer 515-54G
                                            DA0ZAWMB8G0
                                            Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
                                            i dont uderstand this. Charger ic BQ24780S
                                            ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
                                            What is pulling my ACDET down when i apply power even without BQ ic...
                                            12-02-2022, 12:03 PM
                                          • Vanillaboard
                                            Hantek 6022BE USB Port pulled out
                                            by Vanillaboard
                                            I'm currently working on a Hantek 6022BE where the USB port and vias have been ripped off the PCB. Here are the steps I've taken so far:
                                            1. Power Supply: I've tapped the power supply next to the via from the tracer.
                                            2. GND: I've successfully connected the GND as well.
                                            3. Data Lines: I soldered the D+ and D- lines directly to the USB controller (CY7C68013A-100AXC) at pins 17 and 18.
                                            Now I'm wondering if I need pull-up resistors. According to my observation, the tracer goes directly from D+ and D- to the USB Port. Could that be right?
                                            Despite these steps,...
                                            09-22-2024, 06:41 AM
                                          • bridges_4u
                                            A1466 820-000165-A with low PP3v42
                                            by bridges_4u
                                            I have got an 820-000165-A motherboard which has got a strange problem. I have 14.32 V at R7005. But when i check pin2 of D7005, it says 0.9V. The diode is OK. Tried changing U7090 too. Any clues?
                                            04-02-2023, 10:47 AM
                                          • Sepulmac
                                            820-3476-A Pulled resistor R8312
                                            by Sepulmac
                                            Hello everybody.
                                            First comment that I am a computer technician, not an electronics specialist, but I do like it.
                                            I tell you, by accident I have pulled the resistor R8312 and the GND pad of a motherboard 820-3476-A, the line is called DP_INT_ML_N <0> and it goes to pin 15 of the J8300 connector.
                                            The screen works and I don't know if it can be without that resistance. I guess not, but ... is it possible?
                                            Thank you.
                                            04-13-2021, 03:38 AM
