Macbook A1990 820-01041-A No Power on
  • Strolch
    • Nov 2017
    • 245
    • Deutschland
    I have an Apple MacBook A1990 15" 2018 board 820-01041. It just went out during operation and won't start anymore. When I connect the charging cable, there is only 5V but it shows 1.55A see picture. I exchanged the Q3200 but it didn't help .
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Macbook A1990 820-01041-A No Power on
    remove battery and check again
    • Strolch
      • Nov 2017
      • 245
      • Deutschland
      I already have, even if it is removed 5V. It also doesn't start up in the other Mac with a full battery
      • mon2
        • Dec 2019
        • 14636
        What is the voltage to ground of PPBUS_G3H @ F7000 ?
        • Strolch
          • Nov 2017
          • 245
          • Deutschland
          Hi mon2 its 0,0002V
          • mon2
            • Dec 2019
            • 14636
            Remove all power. Measure the resistance across fuse F7000 and also F7001.
            Are any of these fuses blown? Resistance should be ~0 ohms if ok.
            Next, remove both fuses, F7000 & F7001 off the logic board.
            Power up again with your adapter and measure the voltage to ground of F7000 PCB pad, pin # 1.
            Pin #1 is the producer side of this voltage rail which is created by U7000 (ISL9240).
            What is the voltage of PPBUS_G3H now ?
            • Strolch
              • Nov 2017
              • 245
              • Deutschland
              I removed the board from the Mac
              • Strolch
                • Nov 2017
                • 245
                • Deutschland
                The fuse F7000 and F7001 are ok 0 ohms
                • Strolch
                  • Nov 2017
                  • 245
                  • Deutschland
                  ok i unsolder the fuses
                  • Strolch
                    • Nov 2017
                    • 245
                    • Deutschland
                    I had left the power supply on the board and now wanted to unsolder the fuses. I just noticed that L7030 is very hot!
                    • Strolch
                      • Nov 2017
                      • 245
                      • Deutschland
                      Here you can see the short circuit.
                      • mon2
                        • Dec 2019
                        • 14636
                        Ok - remove all power.
                        Meter in resistance mode.
                        Measure the resistance to ground @ F7000 pin # 1. Best if the fuse is removed.
                        • Strolch
                          • Nov 2017
                          • 245
                          • Deutschland
                          ok i remove
                          • Strolch
                            • Nov 2017
                            • 245
                            • Deutschland
                            but it changes by 9M ohms when measured
                            • Strolch
                              • Nov 2017
                              • 245
                              • Deutschland
                              Fuse is removed
                              • mon2
                                • Dec 2019
                                • 14636
                                Ok if the fuse is removed, the 9M ohms is on which pin of F7000 PCB pads?
                                Pin #1 is towards the U7000 (ISL chip). Pin # 2 is the consumer side.
                                Suspecting that pin #1 is with the high resistance? If yes, power up without these fuses.
                                Measure the VOLTAGE to ground @ Pin #1 of F7000 PCB pad.
                                What voltage is now present?
                                • Strolch
                                  • Nov 2017
                                  • 245
                                  • Deutschland
                                  pin 1 0,002V
                                  • Strolch
                                    • Nov 2017
                                    • 245
                                    • Deutschland
                                    the 9M ohms is on Pin1 of F7000
                                    • mon2
                                      • Dec 2019
                                      • 14636
                                      Resistance is great but voltage is not.
                                      Confirm the voltages on the input of U7000.
                                      With a 5 volt adapter voltage, this regulator should kick into BOOST voltage mode to supply a higher voltage @ pin #1 of the F7000 pad.
                                      Be sure that you are truly on pin #1 of the fuse pad.
                                      • Strolch
                                        • Nov 2017
                                        • 245
                                        • Deutschland
                                        I hope it's right
                                        R7015 Pin1=4V
                                        R7021 Pin2=4V
                                        R7022 Pin2=4V
                                        C7081 Pin1=0V
                                        • alfredodinolfo
                                          MacBook Pro 2019 (A1990)
                                          by alfredodinolfo
                                          mb code:820-01827-A;
                                          sn:C02Z349ALVDR;
                                          i9 32GB Ram 1TB
                                          Hi, I found short on one of 6 black nand (total 1TB).
                                          i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                                          I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                                          macbook with A2141 configuration run on recovery but don't complete it.​
                                          anyone can help me?
                                          05-26-2025, 09:27 AM
                                        • robka
                                          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                                          by robka
                                          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                                          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                                          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                                          After that the Macbook was dead. It isn't charging anymore.
                                          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                                          03-02-2024, 02:58 PM
                                        • DATATECH85
                                          Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                                          by DATATECH85
                                          I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                                          The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                                          I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                                          However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                                          Here are the values...
                                          07-24-2024, 06:34 AM
                                        • falcontech
                                          Macbook Pro a1990 activation locked
                                          by falcontech
                                          I received a 2018 MacBook Pro A1990 for repair, and the motherboard was replaced, presumably purchased on AliExpress. The motherboard's activation is blocked because the previous owner didn't delete it. Does anyone have a solution to this problem? I called Apple, and as expected, they asked me to activate the process with proof of purchase for the original computer, which I find very difficult, so the proof of purchase from AliExpress will be of little use. Any suggestions? Thanks.
                                          09-29-2025, 06:57 AM
                                        • Cameron Kajohn
                                          A1990 MacBook no power help
                                          by Cameron Kajohn
                                          I have a a1990 2018 15 inch MacBook Pro that will not power on.
                                          I have replaced the pch bga chip because it was heating up under my thermal camera.
                                          I have replaced the battery, and replaced the small ic between the gpu and cpu as it had a direct short to ground.
                                          the MacBook now pulls 20v 2.4amps the trackpad clicks but it does not ever attempt to power on not even fan spin. After PCH replacement I was able to get it in dfu mode 1 time and restore bridge OS, but now the MacBook will no longer go into DFU mode.
                                          I have also noticed L7030 gets extremely hot yet...
                                          01-24-2024, 12:00 AM
