Macbook A1990 820-01041-A No Power on
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    I have an Apple MacBook A1990 15" 2018 board 820-01041. It just went out during operation and won't start anymore. When I connect the charging cable, there is only 5V but it shows 1.55A see picture. I exchanged the Q3200 but it didn't help .
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    Re: Macbook A1990 820-01041-A No Power on
    remove battery and check again
    • Strolch
      • Nov 2017
      • 237
      • Deutschland
      I already have, even if it is removed 5V. It also doesn't start up in the other Mac with a full battery
      • mon2
        • Dec 2019
        • 14334
        What is the voltage to ground of PPBUS_G3H @ F7000 ?
        • Strolch
          • Nov 2017
          • 237
          • Deutschland
          Hi mon2 its 0,0002V
          • mon2
            • Dec 2019
            • 14334
            Remove all power. Measure the resistance across fuse F7000 and also F7001.
            Are any of these fuses blown? Resistance should be ~0 ohms if ok.
            Next, remove both fuses, F7000 & F7001 off the logic board.
            Power up again with your adapter and measure the voltage to ground of F7000 PCB pad, pin # 1.
            Pin #1 is the producer side of this voltage rail which is created by U7000 (ISL9240).
            What is the voltage of PPBUS_G3H now ?
            • Strolch
              • Nov 2017
              • 237
              • Deutschland
              I removed the board from the Mac
              • Strolch
                • Nov 2017
                • 237
                • Deutschland
                The fuse F7000 and F7001 are ok 0 ohms
                • Strolch
                  • Nov 2017
                  • 237
                  • Deutschland
                  ok i unsolder the fuses
                  • Strolch
                    • Nov 2017
                    • 237
                    • Deutschland
                    I had left the power supply on the board and now wanted to unsolder the fuses. I just noticed that L7030 is very hot!
                    • Strolch
                      • Nov 2017
                      • 237
                      • Deutschland
                      Here you can see the short circuit.
                      • mon2
                        • Dec 2019
                        • 14334
                        Ok - remove all power.
                        Meter in resistance mode.
                        Measure the resistance to ground @ F7000 pin # 1. Best if the fuse is removed.
                        • Strolch
                          • Nov 2017
                          • 237
                          • Deutschland
                          ok i remove
                          • Strolch
                            • Nov 2017
                            • 237
                            • Deutschland
                            but it changes by 9M ohms when measured
                            • Strolch
                              • Nov 2017
                              • 237
                              • Deutschland
                              Fuse is removed
                              • mon2
                                • Dec 2019
                                • 14334
                                Ok if the fuse is removed, the 9M ohms is on which pin of F7000 PCB pads?
                                Pin #1 is towards the U7000 (ISL chip). Pin # 2 is the consumer side.
                                Suspecting that pin #1 is with the high resistance? If yes, power up without these fuses.
                                Measure the VOLTAGE to ground @ Pin #1 of F7000 PCB pad.
                                What voltage is now present?
                                • Strolch
                                  • Nov 2017
                                  • 237
                                  • Deutschland
                                  pin 1 0,002V
                                  • Strolch
                                    • Nov 2017
                                    • 237
                                    • Deutschland
                                    the 9M ohms is on Pin1 of F7000
                                    • mon2
                                      • Dec 2019
                                      • 14334
                                      Resistance is great but voltage is not.
                                      Confirm the voltages on the input of U7000.
                                      With a 5 volt adapter voltage, this regulator should kick into BOOST voltage mode to supply a higher voltage @ pin #1 of the F7000 pad.
                                      Be sure that you are truly on pin #1 of the fuse pad.
                                      • Strolch
                                        • Nov 2017
                                        • 237
                                        • Deutschland
                                        I hope it's right
                                        R7015 Pin1=4V
                                        R7021 Pin2=4V
                                        R7022 Pin2=4V
                                        C7081 Pin1=0V
                                        • alfredodinolfo
                                          MacBook Pro 2019 (A1990)
                                          by alfredodinolfo
                                          mb code:820-01827-A;
                                          sn:C02Z349ALVDR;
                                          i9 32GB Ram 1TB
                                          Hi, I found short on one of 6 black nand (total 1TB).
                                          i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                                          I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                                          macbook with A2141 configuration run on recovery but don't complete it.​
                                          anyone can help me?
                                          05-26-2025, 09:27 AM
                                        • robka
                                          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                                          by robka
                                          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                                          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                                          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                                          After that the Macbook was dead. It isn't charging anymore.
                                          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                                          03-02-2024, 02:58 PM
                                        • DATATECH85
                                          Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                                          by DATATECH85
                                          I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                                          The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                                          I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                                          However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                                          Here are the values...
                                          07-24-2024, 06:34 AM
                                        • Cameron Kajohn
                                          A1990 MacBook no power help
                                          by Cameron Kajohn
                                          I have a a1990 2018 15 inch MacBook Pro that will not power on.
                                          I have replaced the pch bga chip because it was heating up under my thermal camera.
                                          I have replaced the battery, and replaced the small ic between the gpu and cpu as it had a direct short to ground.
                                          the MacBook now pulls 20v 2.4amps the trackpad clicks but it does not ever attempt to power on not even fan spin. After PCH replacement I was able to get it in dfu mode 1 time and restore bridge OS, but now the MacBook will no longer go into DFU mode.
                                          I have also noticed L7030 gets extremely hot yet...
                                          01-24-2024, 12:00 AM
                                        • ahoonid
                                          MacBook A1990 vertical stripes on external screen
                                          by ahoonid
                                          Hey everyone,
                                          I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                                          The board is neat. Not opened before for sure. Just a little dust, nothing more.
                                          Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                                          06-20-2025, 08:54 AM
