Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
  • DATATECH85
    • Dec 2021
    • FRANCE
    I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
    The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
    I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
    However, I can't work out exactly why I don't have the PPBUS_G3H rail.
    Here are the values I measured:
    PPBUS_G3H: Diode = 0.006 / Resistance to ground = 6.7 ohm
    PP20V_USBC_XB_VBUS = 5V
    PP3V3_UPC_XB_LDO = 3.3V
    PP1V8_UPC_XB/XA/TB/TA_LDOA = 1.8V
    PP1V8_UPC_XB/XA/TB/TA_LDOD = 1.8V
    PP1V1_UPC_XB_LDO_BMC = 0V
    PPDCIN_G3H = 5V
    SMBUS_SMC_4_G3H_SDA = 0V
    PP3V3_G3H_RTC_X = 0V /Diode = 0.4 / Resistance to ground = 800kOhm
    I noticed that the RB703 and RB731 resistors have lower values than expected: RB703 = 7.3kOhm and RB731 = 16kOhm (instead of 27.4kOhm).
    I've tried injecting 1.0V on the PPBUS_G3H rail but nothing heats up and it draws 0.330 Amps maximum.
    Don't hesitate to ask me if you need any further information. Thanks in advance!
  • mon2
    • 14721
    Remove all power. Meter in resistance mode.
    Measure the resistance from the PPBUS_G3H rail where you are measuring 6R7 ohms (one meter probe) to the any inductor on the board. You are hunting for a low resistance path.
    Continue to test from the same PPBUS_G3H point to each and every inductor. Start with the CPU region. If you find a low resistance then most likely you have a defective high side mosfet which usually means the CPU and/or parts on that power rail are dead. Also usually a no-fix situation.
    • DATATECH85
      • Dec 2021
      • FRANCE
      Thank you very much for your prompt reply.
      If I've understood correctly, I need to measure the resistance between the point where I measured 6.7ohm and all the inductors near the CPU? For example, I put my multimeter in resistance mode, one probe on fuse F7000 where PPBUS_G3H goes and the other probe on inductor L7420 (where there is CPUGT_SW2 on one side and PPVCCGT_CPU_PH2 on the other)? I'm getting 0.01ohm on this inductor.​
      • mon2
        • 14721
        Yes. This is of concern. The PPBUS_G3H = PPBUS_HS_CPU = Vin on U7420 buck regulator. Internal to U7420 is a high and low side mosfet pair. If there is a leaky mosfet internal to this regulator, then you will show this low resistance. Respectively, the high voltage of PPBUS_G3H would have powered this very low voltage (~1 volt) CPU core voltage rail. Usually his means the CPU is dead and this will be a no-fix case.
        Can you confirm if F7000 is removed off the board? You are measuring from F7000 PCB pad # 2 (aka downstream / consumer side of the regulator circuit) to the inductor L7420 (either side of this inductor is ok)?
        Also, when you inject 1 volt (nothing higher) onto PPBUS_G3H pin # 2 downstream side, do you see this same voltage @ L7420? You will need extra hands to perform this measurement but important to know. If yes, then it appears the internal high side mosfet has leaked for the Vcore rail.
        Next, without power, measure the resistance of L7420 to ground. Most likely the CPU is dead but let us check a bit more.
        • DATATECH85
          • Dec 2021
          • FRANCE
          Yes F7000 is removed off the board and I'm measuring from F7000 PCB pad#2 to the inductor L7420 and I'm getting 0.01 ohm.
          When i inject 1.0V on the F7000 pad#2 (F7000 removed) i'm getting the same voltage on L7420.
          Now, without power, the resistance to ground of L7420 is 6.7ohm (same as PPBUS_G3H rail).
          So the first problem came from the U7420, which then fried the CPU? Is there any way of replacing the CPU without losing the data?
          • silver60618
            Macbook Pro A1990 - Battery not detected after connector torn off
            by silver60618
            Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
            Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
            11-12-2025, 06:36 PM
          • alfredodinolfo
            MacBook Pro 2019 (A1990)
            by alfredodinolfo
            mb code:820-01827-A;
            sn:C02Z349ALVDR;
            i9 32GB Ram 1TB
            Hi, I found short on one of 6 black nand (total 1TB).
            i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
            I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
            macbook with A2141 configuration run on recovery but don't complete it.​
            anyone can help me?
            05-26-2025, 09:27 AM
          • robka
            MacBook Pro 2018 - A1990 Dead - not charging - only 5V
            by robka
            my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
            I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
            The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
            After that the Macbook was dead. It isn't charging anymore.
            The USB-C Port where the charger was plugged is burned. Also The Cable and the...
            03-02-2024, 02:58 PM
          • falcontech
            Macbook Pro a1990 activation locked
            by falcontech
            I received a 2018 MacBook Pro A1990 for repair, and the motherboard was replaced, presumably purchased on AliExpress. The motherboard's activation is blocked because the previous owner didn't delete it. Does anyone have a solution to this problem? I called Apple, and as expected, they asked me to activate the process with proof of purchase for the original computer, which I find very difficult, so the proof of purchase from AliExpress will be of little use. Any suggestions? Thanks.
            09-29-2025, 06:57 AM
          • Cameron Kajohn
            A1990 MacBook no power help
            by Cameron Kajohn
            I have a a1990 2018 15 inch MacBook Pro that will not power on.
            I have replaced the pch bga chip because it was heating up under my thermal camera.
            I have replaced the battery, and replaced the small ic between the gpu and cpu as it had a direct short to ground.
            the MacBook now pulls 20v 2.4amps the trackpad clicks but it does not ever attempt to power on not even fan spin. After PCH replacement I was able to get it in dfu mode 1 time and restore bridge OS, but now the MacBook will no longer go into DFU mode.
            I have also noticed L7030 gets extremely hot yet...
            01-24-2024, 12:00 AM
