A1990 MacBook no power help
  • Cameron Kajohn
    • Aug 2022
    • United Stated
    I have a a1990 2018 15 inch MacBook Pro that will not power on.
    I have replaced the pch bga chip because it was heating up under my thermal camera.
    I have replaced the battery, and replaced the small ic between the gpu and cpu as it had a direct short to ground.
    the MacBook now pulls 20v 2.4amps the trackpad clicks but it does not ever attempt to power on not even fan spin. After PCH replacement I was able to get it in dfu mode 1 time and restore bridge OS, but now the MacBook will no longer go into DFU mode.
    I have also noticed L7030 gets extremely hot yet there is no short to ground and it has 465ohms on both sides. I have also noticed that pp2v5 rail is missing and is showing 65 ohms on the rail. Not sure where to go from here if anyone has any suggestions.
  • mon2
    • 14618
    20v 2.4amps
    Is this an immediate current consumption of 2.4A? Or does the current gradually climb up to this value? If it is an immediate current measurement of 2.4A then you have a short on the board.
    • Cameron Kajohn
      • Aug 2022
      • United Stated
      It gradually climbs up, starting at .645 amps and then rising to 2.4.
      • Cameron Kajohn
        • Aug 2022
        • United Stated
        Bump
        • mon2
          • 14618
          What is the voltage to ground of ppbus_g3h?
          is the board power looping?
          • leovalpo
            • May 2014
            • 18
            • chile
            Can you indicate the motherboard number?
            820-01041-A or 820-01814-A?
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • Schluchti45
              MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
              by Schluchti45
              i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
              Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
              11-18-2024, 02:05 AM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • bcstedt
              LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
              by bcstedt
              LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
              Problem:
              On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
              It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
              01-18-2024, 01:03 PM
