Philips sunmobil HP3132/B sunbed xformer and cap shot
  • notallbad
    • Oct 2012
    • 1190
    Having a quick look at this found a 25uf cap with no cap reading and xformer with open high side winding, theres an obvious brown out spot on the windings and has no continuity.
    Should be ok getting a suitable replacement cap but seem to be having difficulty sourcing a xformer.
    Also need to identify the component in the cap wiring connector, see last photo, which is connected between the 2 cap lugs.
    From what I can make out its 240v pri, 0 - 9 - 0 - 24v sec dual output chassis mount transformer. Only markings on it is:
    P-045 PUTRANS.
    Any help finding a replacement or alternative solution please. There is limited space in the casing.
  • notallbad
    • Oct 2012
    • 1190
    Re: Philips sunmobil HP3132/B sunbed xformer and cap shot
    Part of a sm I have been able to find.
      • 31054
      the thing in the cap is a high value resistor to discharge the cap when off - so you dont get a shock off it.
      the cap is a PF (power factor) correction cap because you have an inductive choke driving each flourescent lamp
      • notallbad
        • Oct 2012
        • 1190
        Thanks, so it might not be quite so easy sourcing one of those caps either then?
          • 31054
          you dont need the resistor - it's probably fine anyway.
          • notallbad
            • Oct 2012
            • 1190
            Ok, so apart from not necessarily needing the resistor, suspect it is naff cos getting a fluctuating ohm reading from it, do you know of a suitable replacement cap?
            thanks again!
              • 31054
              https://www.rapidonline.com/ducati-4...acitor-10-2952
              maybe that
              • notallbad
                • Oct 2012
                • 1190
                Thanks, may well replace all 4 caps eventually but will see how sourcing a transformer goes first.
                I guess that dual transformer could be replaced with 2 singles, I'd just have to work out a way to mount them as I think finding a dual with 9 and 24v outputs is gonna prove unlikely.
                Any idea what I would replace it with? Not sure about the va rating. I can find 230v to 9v and 230v to 24v transformers but not sure which ones to get.
                  • 31054
                  9 and 24v is often found in chinese soldering stations.
                  so maybe look on ali-express
                  • notallbad
                    • Oct 2012
                    • 1190
                    Thanks, I had looked on ali but didnt at first find any.
                    Opened up my chinese 858d hot air station, 28v & 14v off load outputs on my dmm, obviously these will be lower under load, pcb has 9v and 24v printed on it so assuming thats what the xfrmer output will/should be under load.
                    Oddly can't find a dual 9v - 24v xformer but can find a 3 voltage output 24v 30v 10v transformer.
                    24v 30v 10v xformer - £21.37
                    858D hot air station - £29.64 or £28.98 on ebay with 3 day del.
                    Erm, wot to do? Actually the form factor of the 24-30-10 xfmr is larger and may have difficulty fitting it in.
                    • R_J
                      • 9551
                      You might get lucky and there could be a thermal fuse in the primary of the transformer, You will need to carefully peal back the tape and any insulator cardboard, and you might find the thermal fuse, If it does have one, I usually try replacing it with a 1 amp fuse TO START with to see if the transformer is or is not shorted. if the transformer seems to be ok, THEN install a new thermal fuse.
                        • 31054
                        858d is not a soldering station
                        remember - soldering irons are 24v
                        hot air is 230v
                        • notallbad
                          • Oct 2012
                          • 1190
                          Sadly no thermal fuse, and the 0-110v pri windings are also shot otherwise I may have been able to run it on 110v. Thats if it is indeed 110 and not 220, 380 etc
                          • notallbad
                            • Oct 2012
                            • 1190
                            Think I'm going to have to just order another 858D hot air station £27 incl post. Can't find anything cheaper.
                            So can either take the xfmr out of my one or the new arrival if its the same. Either way, I'll still have a hot air gun and the xfmr I need plus hot gun spares.
                              • 31054
                              not 858d
                              soldering IRON bases
                              i may have a transformer - where are you located.
                              • notallbad
                                • Oct 2012
                                • 1190
                                Uk.
                                  • 31054
                                  what city / region?
                                  • notallbad
                                    • Oct 2012
                                    • 1190
                                    wiltshire
                                      • 31054
                                      damn - have to see how much it weigh's to see how much the post office will fuck me!
                                      actually i should dig it out and check the size first.
                                      it came from a 48w soldering station.
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        All up and running!
                                        Bought an 858D hot air station for £27 and used the 24v 11v output xfmr and bought 4 x 25uf caps for £15 just in case I needed more but only used one.
                                        I guess that a dual 12v output transformer would have worked.
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • janos6662000
                                          Philips 47PFS7509/12 LCD TV problem
                                          by janos6662000
                                          Hi
                                          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                          When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                          I downloaded original firmware and applied the update, but the problem remained.
                                          From a colleague i received a "factory package software" which is a lot bigger.
                                          I made another firmware update, but still did not solve the problem.
                                          Somewhere on the way the error got worse, because at the moment the...
                                          08-12-2025, 12:54 PM
                                        • aidanmo
                                          Philips 43PUS7506/12 - Loud blown out sound
                                          by aidanmo
                                          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                          I thought maybe the speakers got damaged, so I replaced them - no dice.
                                          • Using the internal speakers, it always happens.
                                          • Using the headphone jack, it never happens.
                                          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                          02-28-2025, 03:13 PM
                                        • Cornito
                                          Philips 50PUH6400 bad color and gosting / slow motion on one side
                                          by Cornito
                                          Hello Team,
                                          New issue on LCD panel where I need to find out the cause and the potential solution.
                                          This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                          I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                          When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                          I've checked voltages, no issue found comparing right and left side of the panel driver.
                                          VHG VGL CKV... are the sames on...
                                          03-08-2024, 06:41 AM
                                        • spantor
                                          Activate power board Philips 40PFH40009/88 tv
                                          by spantor
                                          Hello partners.
                                          Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                          The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                          02-11-2024, 05:07 PM
