Philips sunmobil HP3132/B sunbed xformer and cap shot
  • notallbad
    • Oct 2012
    • 1190
    Having a quick look at this found a 25uf cap with no cap reading and xformer with open high side winding, theres an obvious brown out spot on the windings and has no continuity.
    Should be ok getting a suitable replacement cap but seem to be having difficulty sourcing a xformer.
    Also need to identify the component in the cap wiring connector, see last photo, which is connected between the 2 cap lugs.
    From what I can make out its 240v pri, 0 - 9 - 0 - 24v sec dual output chassis mount transformer. Only markings on it is:
    P-045 PUTRANS.
    Any help finding a replacement or alternative solution please. There is limited space in the casing.
  • notallbad
    • Oct 2012
    • 1190
    Re: Philips sunmobil HP3132/B sunbed xformer and cap shot
    Part of a sm I have been able to find.
      • 31291
      the thing in the cap is a high value resistor to discharge the cap when off - so you dont get a shock off it.
      the cap is a PF (power factor) correction cap because you have an inductive choke driving each flourescent lamp
      • notallbad
        • Oct 2012
        • 1190
        Thanks, so it might not be quite so easy sourcing one of those caps either then?
          • 31291
          you dont need the resistor - it's probably fine anyway.
          • notallbad
            • Oct 2012
            • 1190
            Ok, so apart from not necessarily needing the resistor, suspect it is naff cos getting a fluctuating ohm reading from it, do you know of a suitable replacement cap?
            thanks again!
              • 31291
              https://www.rapidonline.com/ducati-4...acitor-10-2952
              maybe that
              • notallbad
                • Oct 2012
                • 1190
                Thanks, may well replace all 4 caps eventually but will see how sourcing a transformer goes first.
                I guess that dual transformer could be replaced with 2 singles, I'd just have to work out a way to mount them as I think finding a dual with 9 and 24v outputs is gonna prove unlikely.
                Any idea what I would replace it with? Not sure about the va rating. I can find 230v to 9v and 230v to 24v transformers but not sure which ones to get.
                  • 31291
                  9 and 24v is often found in chinese soldering stations.
                  so maybe look on ali-express
                  • notallbad
                    • Oct 2012
                    • 1190
                    Thanks, I had looked on ali but didnt at first find any.
                    Opened up my chinese 858d hot air station, 28v & 14v off load outputs on my dmm, obviously these will be lower under load, pcb has 9v and 24v printed on it so assuming thats what the xfrmer output will/should be under load.
                    Oddly can't find a dual 9v - 24v xformer but can find a 3 voltage output 24v 30v 10v transformer.
                    24v 30v 10v xformer - £21.37
                    858D hot air station - £29.64 or £28.98 on ebay with 3 day del.
                    Erm, wot to do? Actually the form factor of the 24-30-10 xfmr is larger and may have difficulty fitting it in.
                    • R_J
                      • Jun 2012
                      • 9624
                      You might get lucky and there could be a thermal fuse in the primary of the transformer, You will need to carefully peal back the tape and any insulator cardboard, and you might find the thermal fuse, If it does have one, I usually try replacing it with a 1 amp fuse TO START with to see if the transformer is or is not shorted. if the transformer seems to be ok, THEN install a new thermal fuse.
                        • 31291
                        858d is not a soldering station
                        remember - soldering irons are 24v
                        hot air is 230v
                        • notallbad
                          • Oct 2012
                          • 1190
                          Sadly no thermal fuse, and the 0-110v pri windings are also shot otherwise I may have been able to run it on 110v. Thats if it is indeed 110 and not 220, 380 etc
                          • notallbad
                            • Oct 2012
                            • 1190
                            Think I'm going to have to just order another 858D hot air station £27 incl post. Can't find anything cheaper.
                            So can either take the xfmr out of my one or the new arrival if its the same. Either way, I'll still have a hot air gun and the xfmr I need plus hot gun spares.
                              • 31291
                              not 858d
                              soldering IRON bases
                              i may have a transformer - where are you located.
                              • notallbad
                                • Oct 2012
                                • 1190
                                Uk.
                                  • 31291
                                  what city / region?
                                  • notallbad
                                    • Oct 2012
                                    • 1190
                                    wiltshire
                                      • 31291
                                      damn - have to see how much it weigh's to see how much the post office will fuck me!
                                      actually i should dig it out and check the size first.
                                      it came from a 48w soldering station.
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        All up and running!
                                        Bought an 858D hot air station for £27 and used the 24v 11v output xfmr and bought 4 x 25uf caps for £15 just in case I needed more but only used one.
                                        I guess that a dual 12v output transformer would have worked.
                                        • Sharpa
                                          Repair attempt Philips 55OLED804/12
                                          by Sharpa
                                          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                          The symptoms when bought: Philips logo appears then tv turns off
                                          Things tried so far:
                                          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                          Today, 08:30 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • double_DD
                                          Philips curling iron - is this a common AC cable?
                                          by double_DD
                                          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                          08-18-2025, 10:04 AM
                                        • janos6662000
                                          Philips 47PFS7509/12 LCD TV problem
                                          by janos6662000
                                          Hi
                                          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                          When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                          I downloaded original firmware and applied the update, but the problem remained.
                                          From a colleague i received a "factory package software" which is a lot bigger.
                                          I made another firmware update, but still did not solve the problem.
                                          Somewhere on the way the error got worse, because at the moment the...
                                          08-12-2025, 12:54 PM
